    Unable to install dependencies, NPM install not working
    66 Posts 19 Posters 128.0k Views 16 Watching
      cpramhofer
      1 verbose cli [ ‘/usr/bin/nodejs’, ‘/usr/bin/npm’, ‘start’ ]
      2 info using npm@3.10.8
      3 info using node@v6.9.1
      4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
      5 info lifecycle magicmirror@2.0.0~prestart: magicmirror@2.0.0
      6 silly lifecycle magicmirror@2.0.0~prestart: no script for prestart, continuing
      7 info lifecycle magicmirror@2.0.0~start: magicmirror@2.0.0
      8 verbose lifecycle magicmirror@2.0.0~start: unsafe-perm in lifecycle true
      9 verbose lifecycle magicmirror@2.0.0~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:$
      10 verbose lifecycle magicmirror@2.0.0~start: CWD: /home/pi/MagicMirror
      11 silly lifecycle magicmirror@2.0.0~start: Args: [ ‘-c’, ‘electron js/electron.js’ ]
      12 silly lifecycle magicmirror@2.0.0~start: Returned: code: 1 signal: null
      13 info lifecycle magicmirror@2.0.0~start: Failed to exec start script
      14 verbose stack Error: magicmirror@2.0.0 start: electron js/electron.js
      14 verbose stack Exit status 1
      14 verbose stack at EventEmitter. (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
      14 verbose stack at emitTwo (events.js:106:13)
      14 verbose stack at EventEmitter.emit (events.js:191:7)
      14 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
      14 verbose stack at ChildProcess.emit (events.js:191:7)
      14 verbose stack at maybeClose (internal/child_process.js:877:16)
      14 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
      15 verbose pkgid magicmirror@2.0.0
      16 verbose cwd /home/pi/MagicMirror
      17 error Linux 4.4.21-v7+
      18 error argv “/usr/bin/nodejs” “/usr/bin/npm” “start”
      19 error node v6.9.1
      20 error npm v3.10.8
      21 error code ELIFECYCLE
      22 error magicmirror@2.0.0 start: electron js/electron.js
      22 error Exit status 1
      23 error Failed at the magicmirror@2.0.0 start script ‘electron js/electron.js’.
      23 error Make sure you have the latest version of node.js and npm installed.
      23 error If you do, this is most likely a problem with the magicmirror package,
      23 error not with npm itself.
      23 error Tell the author that this fails on your system:
      23 error electron js/electron.js
      23 error You can get information on how to open an issue for this project with:
      23 error npm bugs magicmirror
      23 error Or if that isn’t available, you can get their info via:
      23 error npm owner ls magicmirror
      23 error There is likely additional logging output above.
      24 verbose exit [ 1, true ]
        cpramhofer
        next try…
        1., installed NOOBS
        2., installed JESSIE LITE
        3., Setup WLAN, IP, Internalisation, Update, Upgrade
        4., Setup MM2:
        pi@MM:~ $ curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
        $$$\ $$$ | _| $$$\ $$$ |_| $$ $$
        $$$$\ $$$$ | $$$$$$\ $$$$$$\ $$\ $$$$$$$\ $$$$\ $$$$ |$$\ $$$$$$\ $$$$$$\ $$$$$$\ $$$$$$\ _/ $$ |
        $$$$$$ $$ | _
        $$ $$$ $$ | $$$$$$$ |$$ / $$ |$$ |$$ / $$ $$$ $$ |$$ |$$ | _|$$ | _|$$ / $$ |$$ | _|$$ /
        $$ |$ /$$ |$$ __$$ |$$ | $$ |$$ |$$ | $$ |$ /$$ |$$ |$$ | $$ | $$ | $$ |$$ | $$ |
        $$ | _/ $$ |$$$$$$$ |$$$$$$$ |$$ |$$$$$$$\ $$ | _/ $$ |$$ |$$ | $$ | $$$$$$ |$$ | $$$$$$$$
        _
        | _
        | _
        | _
        $$ |_| _
        |_| _|_|_| __| _
        / _| _______|
        _
        ____/
        Installing helper tools …
        Paketlisten werden gelesen… Fertig
        Abhängigkeitsbaum wird aufgebaut.
        Statusinformationen werden eingelesen… Fertig
        build-essential ist schon die neueste Version.
        curl ist schon die neueste Version.
        unzip ist schon die neueste Version.
        wget ist schon die neueste Version.
        Vorgeschlagene Pakete:
        gettext-base git-daemon-run git-daemon-sysvinit git-doc git-el git-email
        git-gui gitk gitweb git-arch git-cvs git-mediawiki git-svn
        Die folgenden NEUEN Pakete werden installiert:
        git git-man libcurl3-gnutls liberror-perl rsync
        0 aktualisiert, 5 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
        Es müssen 4.613 kB an Archiven heruntergeladen werden.
        Nach dieser Operation werden 21,5 MB Plattenplatz zusätzlich benutzt.
        Holen: 1 http://mirrordirector.raspbian.org/raspbian/ jessie/main libcurl3-gnutls armhf 7.38.0-4+deb8u4 [225 kB]
        Holen: 2 http://mirrordirector.raspbian.org/raspbian/ jessie/main liberror-perl all 0.17-1.1 [22,4 kB]
        Holen: 3 http://mirrordirector.raspbian.org/raspbian/ jessie/main git-man all 1:2.1.4-2.1+deb8u2 [1.267 kB]
        Holen: 4 http://mirrordirector.raspbian.org/raspbian/ jessie/main git armhf 1:2.1.4-2.1+deb8u2 [2.725 kB]
        Holen: 5 http://mirrordirector.raspbian.org/raspbian/ jessie/main rsync armhf 3.1.1-3 [373 kB]
        Es wurden 4.613 kB in 2 s geholt (1.577 kB/s).
        Vormals nicht ausgewähltes Paket libcurl3-gnutls:armhf wird gewählt.
        (Lese Datenbank … 31227 Dateien und Verzeichnisse sind derzeit installiert.)
        Vorbereitung zum Entpacken von …/libcurl3-gnutls_7.38.0-4+deb8u4_armhf.deb …
        Entpacken von libcurl3-gnutls:armhf (7.38.0-4+deb8u4) …
        Vormals nicht ausgewähltes Paket liberror-perl wird gewählt.
        Vorbereitung zum Entpacken von …/liberror-perl_0.17-1.1_all.deb …
        Entpacken von liberror-perl (0.17-1.1) …
        Vormals nicht ausgewähltes Paket git-man wird gewählt.
        Vorbereitung zum Entpacken von …/git-man_1%3a2.1.4-2.1+deb8u2_all.deb …
        Entpacken von git-man (1:2.1.4-2.1+deb8u2) …
        Vormals nicht ausgewähltes Paket git wird gewählt.
        Vorbereitung zum Entpacken von …/git_1%3a2.1.4-2.1+deb8u2_armhf.deb …
        Entpacken von git (1:2.1.4-2.1+deb8u2) …
        Vormals nicht ausgewähltes Paket rsync wird gewählt.
        Vorbereitung zum Entpacken von …/rsync_3.1.1-3_armhf.deb …
        Entpacken von rsync (3.1.1-3) …
        Trigger für man-db (2.7.0.2-5) werden verarbeitet …
        Trigger für systemd (215-17+deb8u5) werden verarbeitet …
        libcurl3-gnutls:armhf (7.38.0-4+deb8u4) wird eingerichtet …
        liberror-perl (0.17-1.1) wird eingerichtet …
        git-man (1:2.1.4-2.1+deb8u2) wird eingerichtet …
        git (1:2.1.4-2.1+deb8u2) wird eingerichtet …
        rsync (3.1.1-3) wird eingerichtet …
        Trigger für libc-bin (2.19-18+deb8u6) werden verarbeitet …
        Check current Node installation …
        Node.js is not installed.
        Installing Node.js …
        Installing the NodeSource Node.js v6.x repo…
        Populating apt-get cache…
        • apt-get update
          OK http://archive.raspberrypi.org jessie InRelease
          OK http://mirrordirector.raspbian.org jessie InRelease
          OK http://mirrordirector.raspbian.org jessie/main armhf Packages
          OK http://mirrordirector.raspbian.org jessie/contrib armhf Packages
          OK http://mirrordirector.raspbian.org jessie/non-free armhf Packages
          OK http://mirrordirector.raspbian.org jessie/rpi armhf Packages
          Ign http://mirrordirector.raspbian.org jessie/contrib Translation-de_AT
          Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en
          Ign http://mirrordirector.raspbian.org jessie/main Translation-de_AT
          Ign http://mirrordirector.raspbian.org jessie/main Translation-en
          Ign http://mirrordirector.raspbian.org jessie/non-free Translation-de_AT
          Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en
          Ign http://mirrordirector.raspbian.org jessie/rpi Translation-de_AT
          Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en
          OK http://archive.raspberrypi.org jessie/main armhf Packages
          OK http://archive.raspberrypi.org jessie/ui armhf Packages
          Ign http://archive.raspberrypi.org jessie/main Translation-de_AT
          Ign http://archive.raspberrypi.org jessie/main Translation-en
          Ign http://archive.raspberrypi.org jessie/ui Translation-de_AT
          Ign http://archive.raspberrypi.org jessie/ui Translation-en
        Installing packages required for setup: apt-transport-https…
        • apt-get install -y apt-transport-https > /dev/null 2>&1
        Confirming “jessie” is supported…
        • curl -sLf -o /dev/null ‘https://deb.nodesource.com/node_6.x/dists/jessie/Release’
        Adding the NodeSource signing key to your keyring…
        • curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
          OK
        Creating apt sources list file for the NodeSource Node.js v6.x repo…
        • echo ‘deb https://deb.nodesource.com/node_6.x jessie main’ > /etc/apt/sources.list.d/nodesource.list
        • echo ‘deb-src https://deb.nodesource.com/node_6.x jessie main’ >> /etc/apt/sources.list.d/nodesource.list
        Running apt-get update for you…
        • apt-get update
          Holen: 1 https://deb.nodesource.com jessie InRelease [3.914 B]
          Holen: 2 https://deb.nodesource.com jessie/main Sources [760 B]
          Holen: 3 https://deb.nodesource.com jessie/main armhf Packages [962 B]
          Holen: 4 https://deb.nodesource.com jessie/main Translation-de_AT [162 B]
          Holen: 5 https://deb.nodesource.com jessie/main Translation-de [162 B]
          Holen: 6 https://deb.nodesource.com jessie/main Translation-en [162 B]
          Holen: 7 https://deb.nodesource.com jessie/main Translation-de_AT [162 B]
          Holen: 8 https://deb.nodesource.com jessie/main Translation-de [162 B]
          Holen: 9 https://deb.nodesource.com jessie/main Translation-en [162 B]
          Holen: 10 https://deb.nodesource.com jessie/main Translation-de_AT [162 B]
          Holen: 11 https://deb.nodesource.com jessie/main Translation-de [162 B]
          Holen: 12 https://deb.nodesource.com jessie/main Translation-en [162 B]
          Holen: 13 https://deb.nodesource.com jessie/main Translation-de_AT [162 B]
          Holen: 14 https://deb.nodesource.com jessie/main Translation-de [162 B]
          Holen: 15 https://deb.nodesource.com jessie/main Translation-en [162 B]
          Holen: 16 https://deb.nodesource.com jessie/main Translation-de_AT [162 B]
          Ign https://deb.nodesource.com jessie/main Translation-de_AT
          Holen: 17 https://deb.nodesource.com jessie/main Translation-de [162 B]
          Holen: 18 https://deb.nodesource.com jessie/main Translation-en [162 B]
          Ign https://deb.nodesource.com jessie/main Translation-en
          Es wurden 5.636 B in 8 s geholt (688 B/s).
        Run apt-get install nodejs (as root) to install Node.js v6.x and npm
        nodejs
        0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
        Es müssen 8.932 kB an Archiven heruntergeladen werden.
        Nach dieser Operation werden 45,5 MB Plattenplatz zusätzlich benutzt.
        Holen: 1 https://deb.nodesource.com/node_6.x/ jessie/main nodejs armhf 6.9.1-1nodesource1~jessie1 [8.932 kB]
        Es wurden 8.932 kB in 6 s geholt (1.367 kB/s).
        Vormals nicht ausgewähltes Paket nodejs wird gewählt.
        (Lese Datenbank … 32046 Dateien und Verzeichnisse sind derzeit installiert.)
        Vorbereitung zum Entpacken von …/nodejs_6.9.1-1nodesource1~jessie1_armhf.deb …
        Entpacken von nodejs (6.9.1-1nodesource1~jessie1) …
        nodejs (6.9.1-1nodesource1~jessie1) wird eingerichtet …
        Node.js installation Done!
        Cloning MagicMirror …
        Klone nach ‘MagicMirror’…
        remote: Counting objects: 4363, done.
        remote: Compressing objects: 100% (5/5), done.
        remote: Total 4363 (delta 0), reused 0 (delta 0), pack-reused 4358
        Empfange Objekte: 100% (4363/4363), 10.43 MiB | 920.00 KiB/s, Fertig.
        Löse Unterschiede auf: 100% (2288/2288), Fertig.
        Prüfe Konnektivität… Fertig.
        Cloning MagicMirror Done!
        Installing dependencies …
        npm WARN deprecated electron-prebuilt@1.3.8: electron-prebuilt has been renamed to electron. For more details, see http://electron.atom.io/blog/2016/08/16/npm-install-electron
        npm WARN prefer global coffee-script@1.10.0 should be installed with -g
        npm WARN prefer global colorguard@1.2.0 should be installed with -g
        npm WARN prefer global jsonlint@1.6.2 should be installed with -g
        electron-prebuilt@1.3.8 postinstall /home/pi/MagicMirror/node_modules/electron-prebuilt
        node install.js
        Downloading SHASUMS256.txt
        [============================================>] 100.0% of 2.77 kB (2.77 kB/s)
        magicmirror@2.0.0 prepublish /home/pi/MagicMirror
        npm run snyk-protect
        magicmirror@2.0.0 snyk-protect /home/pi/MagicMirror
        snyk protect
        Successfully applied Snyk patches
        magicmirror@2.0.0 /home/pi/MagicMirror
        ├─┬ electron-prebuilt@1.3.8
        │ ├─┬ electron-download@3.0.1
        │ │ ├─┬ fs-extra@0.30.0
        │ │ │ ├── jsonfile@2.4.0
        │ │ │ ├── klaw@1.3.1
        │ │ │ └── rimraf@2.5.4
        │ │ ├── home-path@1.0.3
        │ │ ├── minimist@1.2.0
        │ │ ├─┬ nugget@2.0.1
        │ │ │ ├── pretty-bytes@1.0.4
        │ │ │ ├─┬ progress-stream@1.2.0
        │ │ │ │ ├── speedometer@0.1.4
        │ │ │ │ └─┬ through2@0.2.3
        │ │ │ │ └─┬ xtend@2.1.2
        │ │ │ │ └── object-keys@0.4.0
        │ │ │ ├── single-line-log@1.1.2
        │ │ │ └── throttleit@0.0.2
        │ │ ├── path-exists@2.1.0
        │ │ ├─┬ rc@1.1.6
        │ │ │ ├── deep-extend@0.4.1
        │ │ │ └── ini@1.3.4
        │ │ └── sumchecker@1.2.0
        │ └─┬ extract-zip@1.5.0
        │ ├─┬ concat-stream@1.5.0
        │ │ ├─┬ readable-stream@2.0.6
        │ │ │ ├── core-util-is@1.0.2
        │ │ │ ├── isarray@1.0.0
        │ │ │ ├── process-nextick-args@1.0.7
        │ │ │ ├── string_decoder@0.10.31
        │ │ │ └── util-deprecate@1.0.2
        │ │ └── typedarray@0.0.6
        │ ├── debug@0.7.4
        │ ├─┬ mkdirp@0.5.0
        │ │ └── minimist@0.0.8
        │ └─┬ yauzl@2.4.1
        │ └─┬ fd-slicer@1.0.1
        │ └── pend@1.2.0
        ├─┬ express@4.14.0
        │ ├─┬ accepts@1.3.3
        │ │ └── negotiator@0.6.1
        │ ├── array-flatten@1.1.1
        │ ├── content-disposition@0.5.1
        │ ├── content-type@1.0.2
        │ ├── cookie@0.3.1
        │ ├── cookie-signature@1.0.6
        │ ├─┬ debug@2.2.0
        │ │ └── ms@0.7.1
        │ ├── depd@1.1.0
        │ ├── encodeurl@1.0.1
        │ ├── escape-html@1.0.3
        │ ├── etag@1.7.0
        │ ├─┬ finalhandler@0.5.0
        │ │ ├── statuses@1.3.0
        │ │ └── unpipe@1.0.0
        │ ├── fresh@0.3.0
        │ ├── merge-descriptors@1.0.1
        │ ├── methods@1.1.2
        │ ├─┬ on-finished@2.3.0
        │ │ └── ee-first@1.1.1
        │ ├── parseurl@1.3.1
        │ ├── path-to-regexp@0.1.7
        │ ├─┬ proxy-addr@1.1.2
        │ │ ├── forwarded@0.1.0
        │ │ └── ipaddr.js@1.1.1
        │ ├── qs@6.2.0
        │ ├── range-parser@1.2.0
        │ ├─┬ send@0.14.1
        │ │ ├── destroy@1.0.4
        │ │ ├─┬ http-errors@1.5.0
        │ │ │ ├── inherits@2.0.1
        │ │ │ └── setprototypeof@1.0.1
        │ │ └── mime@1.3.4
        │ ├── serve-static@1.11.1
        │ ├─┬ type-is@1.6.13
        │ │ └── media-typer@0.3.0
        │ ├── utils-merge@1.0.0
        │ └── vary@1.1.0
        ├─┬ feedme@0.3.2
        │ ├── clarinet@0.11.0
        │ ├── eventyoshi@0.1.6
        │ └── sax@1.2.1
        ├─┬ UNMET PEER DEPENDENCY grunt@1.0.1
        │ ├── coffee-script@1.10.0
        │ ├─┬ dateformat@1.0.12
        │ │ ├── get-stdin@4.0.1
        │ │ └─┬ meow@3.7.0
        │ │ ├─┬ camelcase-keys@2.1.0
        │ │ │ └── camelcase@2.1.1
        │ │ ├── decamelize@1.2.0
        │ │ ├─┬ loud-rejection@1.6.0
        │ │ │ ├─┬ currently-unhandled@0.4.1
        │ │ │ │ └── array-find-index@1.0.2
        │ │ │ └── signal-exit@3.0.1
        │ │ ├── map-obj@1.0.1
        │ │ ├─┬ normalize-package-data@2.3.5
        │ │ │ ├─┬ is-builtin-module@1.0.0
        │ │ │ │ └── builtin-modules@1.1.1
        │ │ │ └─┬ validate-npm-package-license@3.0.1
        │ │ │ ├─┬ spdx-correct@1.0.2
        │ │ │ │ └── spdx-license-ids@1.2.2
        │ │ │ └── spdx-expression-parse@1.0.4
        │ │ ├─┬ read-pkg-up@1.0.1
        │ │ │ ├── find-up@1.1.2
        │ │ │ └─┬ read-pkg@1.1.0
        │ │ │ ├─┬ load-json-file@1.1.0
        │ │ │ │ └─┬ strip-bom@2.0.0
        │ │ │ │ └── is-utf8@0.2.1
        │ │ │ └── path-type@1.1.0
        │ │ ├─┬ redent@1.0.0
        │ │ │ ├─┬ indent-string@2.1.0
        │ │ │ │ └── repeating@2.0.1
        │ │ │ └── strip-indent@1.0.1
        │ │ └── trim-newlines@1.0.0
        │ ├── eventemitter2@0.4.14
        │ ├── exit@0.1.2
        │ ├─┬ findup-sync@0.3.0
        │ │ └── glob@5.0.15
        │ ├─┬ glob@7.0.6
        │ │ ├── fs.realpath@1.0.0
        │ │ ├─┬ inflight@1.0.6
        │ │ │ └── wrappy@1.0.2
        │ │ ├── inherits@2.0.3
        │ │ └── once@1.4.0
        │ ├─┬ grunt-cli@1.2.0
        │ │ └── resolve@1.1.7
        │ ├── grunt-known-options@1.1.0
        │ ├─┬ grunt-legacy-log@1.0.0
        │ │ ├── colors@1.1.2
        │ │ ├─┬ grunt-legacy-log-utils@1.0.0
        │ │ │ └── lodash@4.3.0
        │ │ ├── lodash@3.10.1
        │ │ └── underscore.string@3.2.3
        │ ├─┬ grunt-legacy-util@1.0.0
        │ │ ├── async@1.5.2
        │ │ ├── getobject@0.1.0
        │ │ ├── lodash@4.3.0
        │ │ └─┬ which@1.2.11
        │ │ └── isexe@1.1.2
        │ ├─┬ js-yaml@3.5.5
        │ │ ├─┬ argparse@1.0.9
        │ │ │ └── sprintf-js@1.0.3
        │ │ └── esprima@2.7.3
        │ ├─┬ minimatch@3.0.3
        │ │ └─┬ brace-expansion@1.1.6
        │ │ └── concat-map@0.0.1
        │ ├── nopt@3.0.6
        │ ├── path-is-absolute@1.0.1
        │ └── rimraf@2.2.8
        ├─┬ grunt-eslint@19.0.0
        │ ├─┬ chalk@1.1.3
        │ │ ├── ansi-styles@2.2.1
        │ │ ├── escape-string-regexp@1.0.5
        │ │ ├─┬ has-ansi@2.0.0
        │ │ │ └── ansi-regex@2.0.0
        │ │ ├── strip-ansi@3.0.1
        │ │ └── supports-color@2.0.0
        │ └─┬ eslint@3.9.0
        │ ├─┬ babel-code-frame@6.16.0
        │ │ └── js-tokens@2.0.0
        │ ├─┬ doctrine@1.5.0
        │ │ └── isarray@1.0.0
        │ ├─┬ escope@3.6.0
        │ │ ├─┬ es6-map@0.1.4
        │ │ │ ├── d@0.1.1
        │ │ │ ├── es5-ext@0.10.12
        │ │ │ ├── es6-iterator@2.0.0
        │ │ │ ├── es6-set@0.1.4
        │ │ │ ├── es6-symbol@3.1.0
        │ │ │ └── event-emitter@0.3.4
        │ │ ├── es6-weak-map@2.0.1
        │ │ └─┬ esrecurse@4.1.0
        │ │ └── estraverse@4.1.1
        │ ├─┬ espree@3.3.2
        │ │ ├── acorn@4.0.3
        │ │ └─┬ acorn-jsx@3.0.1
        │ │ └── acorn@3.3.0
        │ ├── estraverse@4.2.0
        │ ├── esutils@2.0.2
        │ ├─┬ file-entry-cache@2.0.0
        │ │ └─┬ flat-cache@1.2.1
        │ │ ├── circular-json@0.3.1
        │ │ ├─┬ del@2.2.2
        │ │ │ ├── globby@5.0.0
        │ │ │ ├── is-path-cwd@1.0.0
        │ │ │ └─┬ is-path-in-cwd@1.0.0
        │ │ │ └── is-path-inside@1.0.0
        │ │ └─┬ write@0.2.1
        │ │ └─┬ mkdirp@0.5.1
        │ ├── glob@7.1.1
        │ ├── globals@9.12.0
        │ ├── ignore@3.2.0
        │ ├── imurmurhash@0.1.4
        │ ├─┬ inquirer@0.12.0
        │ │ ├─┬ readline2@1.0.1
        │ │ │ └── mute-stream@0.0.5
        │ │ ├── run-async@0.1.0
        │ │ └── rx-lite@3.1.2
        │ ├─┬ is-my-json-valid@2.15.0
        │ │ ├── generate-function@2.0.0
        │ │ ├─┬ generate-object-property@1.2.0
        │ │ │ └── is-property@1.0.2
        │ │ ├── jsonpointer@4.0.0
        │ │ └── xtend@4.0.1
        │ ├─┬ is-resolvable@1.0.0
        │ │ └── tryit@1.0.3
        │ ├─┬ json-stable-stringify@1.0.1
        │ │ └── jsonify@0.0.0
        │ ├─┬ levn@0.3.0
        │ │ ├── prelude-ls@1.1.2
        │ │ └── type-check@0.3.2
        │ ├── lodash@4.16.4
        │ ├── natural-compare@1.4.0
        │ ├─┬ optionator@0.8.2
        │ │ ├── deep-is@0.1.3
        │ │ ├── fast-levenshtein@2.0.5
        │ │ └── wordwrap@1.0.0
        │ ├── path-is-inside@1.0.2
        │ ├── pluralize@1.2.1
        │ ├── progress@1.1.8
        │ ├─┬ require-uncached@1.0.2
        │ │ ├─┬ caller-path@0.1.0
        │ │ │ └── callsites@0.2.0
        │ │ └── resolve-from@1.0.1
        │ ├─┬ shelljs@0.7.5
        │ │ ├── interpret@1.0.1
        │ │ └── rechoir@0.6.2
        │ ├── strip-bom@3.0.0
        │ ├── strip-json-comments@1.0.4
        │ ├─┬ table@3.8.3
        │ │ ├─┬ ajv@4.8.2
        │ │ │ └── co@4.6.0
        │ │ ├── ajv-keywords@1.1.1
        │ │ ├── slice-ansi@0.0.4
        │ │ └─┬ string-width@2.0.0
        │ │ └── is-fullwidth-code-point@2.0.0
        │ └─┬ user-home@2.0.0
        │ └── os-homedir@1.0.2
        ├─┬ grunt-jsonlint@1.1.0
        │ ├─┬ jsonlint@1.6.2
        │ │ ├── JSV@4.0.2
        │ │ └─┬ nomnom@1.8.1
        │ │ ├─┬ chalk@0.4.0
        │ │ │ ├── ansi-styles@1.0.0
        │ │ │ ├── has-color@0.1.7
        │ │ │ └── strip-ansi@0.1.1
        │ │ └── underscore@1.6.0
        │ └── strip-json-comments@2.0.1
        ├─┬ grunt-markdownlint@1.0.9
        │ └─┬ markdownlint@0.2.0
        │ └─┬ markdown-it@7.0.1
        │ ├── entities@1.1.1
        │ ├── linkify-it@2.0.2
        │ ├── mdurl@1.0.1
        │ └── uc.micro@1.0.3
        ├─┬ grunt-stylelint@0.6.0
        │ └─┬ stylelint@7.5.0
        │ ├─┬ autoprefixer@6.5.1
        │ │ ├── browserslist@1.4.0
        │ │ ├── caniuse-db@1.0.30000570
        │ │ ├── normalize-range@0.1.2
        │ │ └── num2fraction@1.2.2
        │ ├── balanced-match@0.4.2
        │ ├─┬ colorguard@1.2.0
        │ │ ├── color-diff@0.1.7
        │ │ ├─┬ pipetteur@2.0.3
        │ │ │ ├── onecolor@3.0.4
        │ │ │ └─┬ synesthesia@1.0.1
        │ │ │ └── css-color-names@0.0.3
        │ │ ├─┬ plur@2.1.2
        │ │ │ └── irregular-plurals@1.2.0
        │ │ └── yargs@1.3.3
        │ ├─┬ cosmiconfig@2.1.0
        │ │ ├─┬ parse-json@2.2.0
        │ │ │ └─┬ error-ex@1.3.0
        │ │ │ └── is-arrayish@0.2.1
        │ │ └── require-from-string@1.2.1
        │ ├─┬ doiuse@2.5.0
        │ │ ├─┬ css-rule-stream@1.1.0
        │ │ │ ├── css-tokenize@1.0.1
        │ │ │ ├── duplexer2@0.0.2
        │ │ │ └─┬ through2@0.6.5
        │ │ │ ├── readable-stream@1.0.34
        │ │ │ └── xtend@4.0.1
        │ │ ├─┬ duplexer2@0.0.2
        │ │ │ └── readable-stream@1.1.14
        │ │ ├─┬ jsonfilter@1.1.2
        │ │ │ ├─┬ JSONStream@0.8.4
        │ │ │ │ └── jsonparse@0.0.5
        │ │ │ ├─┬ stream-combiner@0.2.2
        │ │ │ │ └── duplexer@0.1.1
        │ │ ├─┬ ldjson-stream@1.2.1
        │ │ │ ├─┬ split2@0.2.1
        │ │ │ │ └─┬ through2@0.6.5
        │ │ │ │ ├── readable-stream@1.0.34
        │ │ │ │ └── xtend@4.0.1
        │ │ ├─┬ source-map@0.4.4
        │ │ │ └── amdefine@1.0.0
        │ │ ├─┬ through2@0.6.5
        │ │ └─┬ yargs@3.15.0
        │ │ ├── camelcase@1.2.1
        │ │ ├─┬ cliui@2.1.0
        │ │ │ ├─┬ center-align@0.1.3
        │ │ │ │ ├─┬ align-text@0.1.4
        │ │ │ │ │ ├─┬ kind-of@3.0.4
        │ │ │ │ │ │ └── is-buffer@1.1.4
        │ │ │ │ │ ├── longest@1.0.1
        │ │ │ │ │ └── repeat-string@1.6.1
        │ │ │ │ └── lazy-cache@1.0.4
        │ │ │ ├── right-align@0.1.3
        │ │ │ └── wordwrap@0.0.2
        │ │ └── window-size@0.1.4
        │ ├─┬ execall@1.0.0
        │ │ └─┬ clone-regexp@1.0.0
        │ │ ├── is-regexp@1.0.0
        │ │ └── is-supported-regexp-flag@1.0.0
        │ ├── get-stdin@5.0.1
        │ ├─┬ globby@6.0.0
        │ │ └── pify@2.3.0
        │ ├── globjoin@0.1.4
        │ ├── html-tags@1.1.1
        │ ├── known-css-properties@0.0.5
        │ ├── log-symbols@1.0.2
        │ ├─┬ multimatch@2.1.0
        │ │ ├── array-differ@1.0.0
        │ │ ├─┬ array-union@1.0.2
        │ │ │ └── array-uniq@1.0.3
        │ │ └── arrify@1.0.1
        │ ├── normalize-selector@0.2.0
        │ ├─┬ postcss@5.2.5
        │ │ ├── js-base64@2.1.9
        │ │ ├── source-map@0.5.6
        │ │ └─┬ supports-color@3.1.2
        │ │ └── has-flag@1.0.0
        │ ├── postcss-less@0.14.0
        │ ├── postcss-media-query-parser@0.2.3
        │ ├── postcss-reporter@1.4.1
        │ ├── postcss-resolve-nested-selector@0.1.1
        │ ├── postcss-scss@0.3.1
        │ ├─┬ postcss-selector-parser@2.2.1
        │ │ ├── flatten@1.0.2
        │ │ ├── indexes-of@1.0.1
        │ │ └── uniq@1.0.1
        │ ├── postcss-value-parser@3.3.0
        │ ├── resolve-from@2.0.0
        │ ├── specificity@0.3.0
        │ ├─┬ string-width@2.0.0
        │ ├── style-search@0.1.0
        │ ├─┬ stylehacks@2.3.1
        │ │ ├─┬ read-file-stdin@0.2.1
        │ │ │ └── gather-stream@1.0.0
        │ │ └── write-file-stdout@0.0.2
        │ ├── sugarss@0.2.0
        │ └── svg-tags@1.0.0
        ├─┬ grunt-yamllint@0.2.0
        │ ├── async@0.9.2
        │ ├─┬ chalk@0.5.1
        │ │ ├── ansi-styles@1.1.0
        │ │ ├─┬ has-ansi@0.1.0
        │ │ │ └── ansi-regex@0.2.1
        │ │ ├── strip-ansi@0.3.0
        │ │ └── supports-color@0.2.0
        │ └── js-yaml@3.6.1
        ├── iconv-lite@0.4.13
        ├── moment@2.15.2
        ├─┬ request@2.76.0
        │ ├── aws-sign2@0.6.0
        │ ├── aws4@1.5.0
        │ ├── caseless@0.11.0
        │ ├─┬ combined-stream@1.0.5
        │ │ └── delayed-stream@1.0.0
        │ ├── extend@3.0.0
        │ ├── forever-agent@0.6.1
        │ ├─┬ form-data@2.1.1
        │ │ └── asynckit@0.4.0
        │ ├─┬ har-validator@2.0.6
        │ │ ├─┬ commander@2.9.0
        │ │ │ └── graceful-readlink@1.0.1
        │ │ └─┬ pinkie-promise@2.0.1
        │ │ └── pinkie@2.0.4
        │ ├─┬ hawk@3.1.3
        │ │ ├── boom@2.10.1
        │ │ ├── cryptiles@2.0.5
        │ │ ├── hoek@2.16.3
        │ │ └── sntp@1.0.9
        │ ├─┬ http-signature@1.1.1
        │ │ ├── assert-plus@0.2.0
        │ │ ├─┬ jsprim@1.3.1
        │ │ │ ├── extsprintf@1.0.2
        │ │ │ ├── json-schema@0.2.3
        │ │ │ └── verror@1.3.6
        │ │ └─┬ sshpk@1.10.1
        │ │ ├── asn1@0.2.3
        │ │ ├── assert-plus@1.0.0
        │ │ ├── bcrypt-pbkdf@1.0.0
        │ │ ├─┬ dashdash@1.14.0
        │ │ │ └── assert-plus@1.0.0
        │ │ ├── ecc-jsbn@0.1.1
        │ │ ├─┬ getpass@0.1.6
        │ │ ├── jodid25519@1.0.2
        │ │ ├── jsbn@0.1.0
        │ │ └── tweetnacl@0.14.3
        │ ├── is-typedarray@1.0.0
        │ ├── isstream@0.1.2
        │ ├── json-stringify-safe@5.0.1
        │ ├─┬ mime-types@2.1.12
        │ │ └── mime-db@1.24.0
        │ ├── node-uuid@1.4.7
        │ ├── oauth-sign@0.8.2
        │ ├── qs@6.3.0
        │ ├── stringstream@0.0.5
        │ ├─┬ tough-cookie@2.3.2
        │ │ └── punycode@1.4.1
        │ └── tunnel-agent@0.4.3
        ├── rrule@2.1.0
        ├─┬ snyk@1.19.1
        │ ├── abbrev@1.0.9
        │ ├── ansi-escapes@1.4.0
        │ ├─┬ configstore@1.4.0
        │ │ ├── graceful-fs@4.1.9
        │ │ ├── object-assign@4.1.0
        │ │ ├── os-tmpdir@1.0.2
        │ │ ├── osenv@0.1.3
        │ │ ├── uuid@2.0.3
        │ │ ├─┬ write-file-atomic@1.2.0
        │ │ │ └── slide@1.1.6
        │ │ └── xdg-basedir@2.0.0
        │ ├── es6-promise@3.3.1
        │ ├── hasbin@1.2.3
        │ ├─┬ inquirer@1.0.3
        │ │ ├─┬ cli-cursor@1.0.2
        │ │ │ └─┬ restore-cursor@1.0.1
        │ │ │ ├── exit-hook@1.1.1
        │ │ │ └── onetime@1.1.0
        │ │ ├── cli-width@2.1.0
        │ │ ├── mute-stream@0.0.6
        │ │ ├─┬ run-async@2.2.0
        │ │ │ └── is-promise@2.1.0
        │ │ ├── rx@4.1.0
        │ │ ├─┬ string-width@1.0.2
        │ │ │ ├── code-point-at@1.0.1
        │ │ │ └── is-fullwidth-code-point@1.0.0
        │ │ └── through@2.3.8
        │ ├── open@0.0.5
        │ ├─┬ os-name@1.0.3
        │ │ ├── osx-release@1.1.0
        │ │ └── win-release@1.1.1
        │ ├── semver@5.3.0
        │ ├─┬ snyk-config@1.0.1
        │ │ └─┬ nconf@0.7.2
        │ │ └── async@0.9.2
        │ ├─┬ snyk-module@1.7.0
        │ │ ├── hosted-git-info@2.1.5
        │ │ └─┬ validate-npm-package-name@2.2.2
        │ │ └── builtins@0.0.7
        │ ├─┬ snyk-policy@1.5.2
        │ │ └── lodash.clonedeep@4.5.0
        │ ├─┬ snyk-recursive-readdir@2.0.0
        │ │ └── minimatch@3.0.2
        │ ├── snyk-resolve@1.0.0
        │ ├─┬ snyk-resolve-deps@1.7.0
        │ │ ├── ansicolors@0.3.2
        │ │ ├─┬ clite@0.3.0
        │ │ │ ├── lodash.defaults@4.2.0
        │ │ │ ├── lodash.defaultsdeep@4.6.0
        │ │ │ ├── lodash.mergewith@4.6.0
        │ │ │ ├─┬ update-notifier@0.6.3
        │ │ │ │ ├─┬ boxen@0.3.1
        │ │ │ │ │ ├── filled-array@1.1.0
        │ │ │ │ │ └── widest-line@1.0.0
        │ │ │ │ ├─┬ configstore@2.1.0
        │ │ │ │ │ └─┬ dot-prop@3.0.0
        │ │ │ │ │ └── is-obj@1.0.1
        │ │ │ │ └─┬ latest-version@2.0.0
        │ │ │ │ └─┬ package-json@2.4.0
        │ │ │ │ ├─┬ got@5.6.0
        │ │ │ │ │ ├─┬ create-error-class@3.0.2
        │ │ │ │ │ │ └── capture-stack-trace@1.0.0
        │ │ │ │ │ ├─┬ duplexer2@0.1.4
        │ │ │ │ │ │ └─┬ readable-stream@2.1.5
        │ │ │ │ │ │ └── isarray@1.0.0
        │ │ │ │ │ ├── is-plain-obj@1.1.0
        │ │ │ │ │ ├── is-retry-allowed@1.1.0
        │ │ │ │ │ ├── node-status-codes@1.0.0
        │ │ │ │ │ ├─┬ readable-stream@2.1.5
        │ │ │ │ │ ├── unzip-response@1.0.1
        │ │ │ │ │ └── url-parse-lax@1.0.0
        │ │ │ │ └── registry-auth-token@3.1.0
        │ │ │ └─┬ yargs@4.8.1
        │ │ │ ├─┬ cliui@3.2.0
        │ │ │ │ └── wrap-ansi@2.0.0
        │ │ │ ├── get-caller-file@1.0.2
        │ │ │ ├── lodash.assign@4.2.0
        │ │ │ ├─┬ os-locale@1.4.0
        │ │ │ │ └─┬ lcid@1.0.0
        │ │ │ │ └── invert-kv@1.0.0
        │ │ │ ├── require-directory@2.1.1
        │ │ │ ├── require-main-filename@1.0.1
        │ │ │ ├── set-blocking@2.0.0
        │ │ │ ├── which-module@1.0.0
        │ │ │ ├── window-size@0.2.0
        │ │ │ ├── y18n@3.2.1
        │ │ │ └─┬ yargs-parser@2.4.1
        │ │ │ └── camelcase@3.0.0
        │ │ └─┬ lru-cache@4.0.1
        │ │ ├── pseudomap@1.0.2
        │ │ └── yallist@2.0.0
        │ ├─┬ snyk-tree@1.0.0
        │ │ └── archy@1.0.0
        │ ├── snyk-try-require@1.1.1
        │ ├── tempfile@1.1.1
        │ ├─┬ then-fs@2.0.0
        │ │ └─┬ promise@7.1.1
        │ │ └── asap@2.0.5
        │ ├── undefsafe@0.0.3
        │ ├─┬ update-notifier@0.5.0
        │ │ ├── is-npm@1.0.0
        │ │ ├─┬ latest-version@1.0.1
        │ │ │ └─┬ package-json@1.2.0
        │ │ │ ├─┬ got@3.3.1
        │ │ │ │ ├─┬ duplexify@3.5.0
        │ │ │ │ │ ├─┬ end-of-stream@1.0.0
        │ │ │ │ │ │ └── once@1.3.3
        │ │ │ │ │ │ ├── buffer-shims@1.0.0
        │ │ │ │ │ └── stream-shift@1.0.0
        │ │ │ │ ├── infinity-agent@2.0.3
        │ │ │ │ ├── is-redirect@1.0.0
        │ │ │ │ ├── is-stream@1.1.0
        │ │ │ │ ├── lowercase-keys@1.0.0
        │ │ │ │ ├── nested-error-stacks@1.0.2
        │ │ │ │ ├── object-assign@3.0.0
        │ │ │ │ ├── prepend-http@1.0.4
        │ │ │ │ ├─┬ read-all-stream@3.1.0
        │ │ │ │ └── timed-out@2.0.0
        │ │ │ └── registry-url@3.1.0
        │ │ ├── repeating@1.1.3
        │ │ ├── semver-diff@2.1.0
        │ │ └── string-length@1.0.1
        │ └─┬ url@0.11.0
        │ ├── punycode@1.3.2
        │ └── querystring@0.2.0
        ├─┬ socket.io@1.5.1
        │ ├─┬ engine.io@1.7.2
        │ │ ├── base64id@0.1.0
        │ │ ├─┬ engine.io-parser@1.3.1
        │ │ │ ├── after@0.8.1
        │ │ │ ├── arraybuffer.slice@0.0.6
        │ │ │ ├── base64-arraybuffer@0.1.5
        │ │ │ ├── blob@0.0.4
        │ │ │ ├── has-binary@0.1.6
        │ │ │ └── wtf-8@1.0.0
        │ │ └─┬ ws@1.1.1
        │ │ ├── options@0.0.6
        │ │ └── ultron@1.0.2
        │ ├─┬ has-binary@0.1.7
        │ │ └── isarray@0.0.1
        │ ├─┬ socket.io-adapter@0.4.0
        │ │ └─┬ socket.io-parser@2.2.2
        │ │ ├── benchmark@1.0.0
        │ │ ├── debug@0.7.4
        │ │ └── json3@3.2.6
        │ ├─┬ socket.io-client@1.5.1
        │ │ ├── backo2@1.0.2
        │ │ ├── component-bind@1.0.0
        │ │ ├── component-emitter@1.2.0
        │ │ ├─┬ engine.io-client@1.7.2
        │ │ │ ├── component-inherit@0.0.3
        │ │ │ ├── has-cors@1.1.0
        │ │ │ ├── parsejson@0.0.1
        │ │ │ ├── parseqs@0.0.2
        │ │ │ ├── xmlhttprequest-ssl@1.5.1
        │ │ │ └── yeast@0.1.2
        │ │ ├── indexof@0.0.1
        │ │ ├── object-component@0.0.3
        │ │ ├─┬ parseuri@0.0.4
        │ │ │ └─┬ better-assert@1.0.2
        │ │ │ └── callsite@1.0.0
        │ │ └── to-array@0.1.4
        │ └─┬ socket.io-parser@2.3.1
        │ ├── component-emitter@1.1.2
        │ └── json3@3.3.2
        ├── stylelint-config-standard@14.0.0
        ├─┬ time-grunt@1.4.0
        │ ├─┬ date-time@1.1.0
        │ │ └── time-zone@0.1.0
        │ ├── figures@1.7.0
        │ ├── hooker@0.2.3
        │ ├── number-is-nan@1.0.1
        │ ├─┬ pretty-ms@2.1.0
        │ │ ├── is-finite@1.0.2
        │ │ ├── parse-ms@1.0.1
        │ │ └── plur@1.0.0
        │ └── text-table@0.2.0
        ├── valid-url@1.0.9
        └─┬ walk@2.3.9
        └── foreachasync@3.0.0
        npm WARN grunt-yamllint@0.2.0 requires a peer of grunt@~0.4.0 but none was installed.
        Dependencies installation Done!
        We’re ready! Run DISPLAY=:0 npm start from the ~/MagicMirror directory to start your MagicMirror.
        pi@MM:~ $
        • bheplerB
          bhepler Module Developer
          All right. It looks like the next step is to copy the sample config.js file to it’s final location and then run this puppy.
          Are you doing this directly on the Pi or via SSH?
          C 1 Reply Last reply
          • K
            kiefersmith
            Maybe use something like pastebin for verbose output? Just for thread readability.
              cpramhofer @bhepler
              @bhepler
              the problem is that i (and many others) get an electron error. (compare the posting of @FlorianRD )
              i tried both: direkt an ssh
              kind regards!
                cpramhofer @kiefersmith
                @kiefersmith sorry, i will try it the next time! Thank you for the hint!
                • KirAsh4K
                  KirAsh4 Moderator
                  Fail! I did not get time this weekend to try this. I got as far as downloading the new Raspbian image. I need to get another project done first, and it’s taking a lot of my time to complete. I will get to the testing, be patient.
                  • K
                    kiefersmith
                    Okay, guys, I got it working. Not sure exactly how. However, I have the basic steps:
                    • re-imaged Raspbian
                    • sudo apt-update, sudo apt-get upgrade, sudo apt-get autoremove
                    • reboot
                    • install latest versions of nodejs and npm (make sure they are actually up to date with --version)
                    • install electron from source (I believe I did this globally -g.)
                    • build MagicMirror from source (not using auto-install script)
                    • create your config.js file.
                    • RUN ELECTRON FROM CONSOLE (just type electron)
                    • cd MagicMirror
                    • now run sudo npm install && npm start.
                    This worked for me! Hopefully it will work for you guys too.
                    Edit: This also works without electron running. I think the issue comes when electron does not install properly?
                      cpramhofer
                      @KirAsh4 well time is very precious in times like these ;) don´t get stressed due to our bug reports!
                      thanks a lot that you are getting a look on it.
                      KirAsh4K 1 Reply Last reply
                      • KirAsh4K
                        KirAsh4 Moderator @cpramhofer
                        @cpramhofer, not particularly stressed, just a matter of time … and life moving on.
                        M 1 Reply Last reply
                          MarkAlisch @KirAsh4
                          Gotcha!
                          I got it running: D
                          The difference to the 20 previous try was that I did not make the whole in the pure console, but in a terminal under the graphical surface.
                          This can also be seen in the instructions under the URL https://forum.magicmirror.builders/topic/236/complete-setup-tutorial/6
                            cpramhofer
                            Hi All,
                            after my holiday i gave the thing another chance with a fresh install:
                            Raspbian Jessie with Pixel
                            2016-09-23
                            (is this the problem???)
                            npm ERR! Linux 4.4.21-v7+
                            npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “install”
                            npm ERR! node v6.9.1
                            npm ERR! npm v3.10.8
                            npm ERR! code ELIFECYCLE
                            npm ERR! electron-prebuilt@1.3.9 postinstall: node install.js
                            npm ERR! Exit status 1
                            npm ERR!
                            npm ERR! Failed at the electron-prebuilt@1.3.9 postinstall script ‘node install.js’.
                            npm ERR! If you do, this is most likely a problem with the electron-prebuilt package,
                            npm ERR! not with npm itself.
                            npm ERR! node install.js
                            npm ERR! npm bugs electron-prebuilt
                            npm ERR! Or if that isn’t available, you can get their info via:
                            npm ERR! npm owner ls electron-prebuilt
                            npm ERR! /root/MagicMirror/npm-debug.log
                            Unable to install dependencies!
                            or is it the problem that the installer is still using eletron-prebuild instead of electron??
                            • T
                              tajno
                              Did you tried the followed:
                              npm install npm@latest -g
                              npm install -g grunt
                              npm install -g electron
                                cpramhofer
                                IT WORKS!!
                                thanks @tajno for the hint!
                                My Steps to working MM:
                                • Fresh Card with latest Version of Raspian (PIXEL)
                                • [running the installer Script]
                                • MMM DID NOT WORK AT THIS STAGE
                                • running
                                  sudo npm install npm@latest -g
                                  sudo npm install -g grunt
                                  sudo npm install -g electron
                                • manual install of MMM (git clone / sudo npm install / npm start)
                                kind regards
                                Christoph
                                • SharkbyteS
                                  Sharkbyte
                                  here is what worked for me
                                  git reset --hard and then git pull && npm install
                                  Technically challenged all day everyday.
                                  So then I just go here Evolution MMA
                                  Of course though spending time with the son is always the best of the best!
                                    sdetweil @Sharkbyte
                                    @sharkbyte yeh, if you use my upgrade script it handles all that. Reset hard is, in my opinion, a bad thing to do, unless you KNOW why you are doing it.
                                    see
                                    • 3 / 4
