    MMM-AssistantMk2
    421 Posts 61 Posters 627.2k Views 57 Watching
    • ? Offline
      A Former User @costascontis
      @costascontis
      But in that case, Other modules cannot use speaker-out. I rather recommend to use other speaker instead HDMI.
      • C Offline
        costascontis
        yes i understand,i just think that is a MMM-AssistantMk2 's problem because when i trigger MMM-Hotword it makes a ding sound to show that its listening and that sound i can always hear it so hdmi is awake ,then i make a request to MMM-AssistantMk2 and when it answers i cant hear the first word or the first letters of it anyway…
        • L Offline
          Lowis
          Hello
          how can MMM-AssistantMk2 start a webradio stream ? i tell the Assistant to play radio 1live. Respone is “OK” but nothing will come up.
          I say "show me a picture from a Dog . Respone “OK” but nothing comes up.
          BTW : Great Module !
          • ? Offline
            A Former User @Lowis
            @lowis
            Those features are allowed to REAL GOOGLE HOME devices at this moment. I hope somedays it could be allowed to Assistant SDK.
            • L Offline
              Lowis
              But a something like your youtube search and playing Should be possible for a webradio
              • ? Offline
                @lowis Youtube features are added by myself with Youtube API.
                • L Offline
                  Lowis
                  @Sean Yes i know. Great work ! Maybe it could expand with a webradio directory like shoutcast.com
                    Jmh474
                    I’m guessing that this question has been asked quite a few times so I’m sorry for the repeat.
                    I’ve got my mirror up and running using latest resabian, MagicMirror2, modules MMM-AssistantMk2 and MMM-HOTWORD.
                    Adding more modules soon just taking a step at a time as I’m a total beginner.
                    Seems to be running OK apart from the Google Assistant, its running so slow when asking questions and waiting for replies, and I don’t get voice response back just like a humming sound (I’m guessing this is when Google is answering), I know sound and mic are working as I can her myself talk when testing the mic.
                    Also what is the best setup for mic and speakers in using a USB sound card
                    Mic is just standard 3.5mm jack type
                    Speakers are running through a separate amp after the sound card.
                    One more this is there a way to add an Led for when the Google Assistant is listening??
                    Sorry for the long post I’m just so close
                    • ? Offline
                      A Former User @Jmh474
                      @jmh474
                      For slow speed, I have no idea about it. Maybe it is related with your network status. Usually others have no problem about speed.
                      I think, it is not about speed. You just couldn’t get the response with some reason.
                      Test like this;
                      • Stop the pm2 (If you are using)
                      • Execute MM with npm start dev on MagicMirror directory.
                      • See what happens on terminal shell.
                        There could be errors or some useful messages to examine.
                      • LicoriniL Offline
                        Licorini
                        Hello … I am a beginner, I am trying to install Mk2 following the instructions, however it presents errors as below:
                        magicmirror@2.6.0 start /home/pi/MagicMirror
                        sh run-start.sh
                        Starting MagicMirror: v2.6.0
                        Loading config …
                        Loading module helpers …
                        Initializing new module helper …
                        WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
                        Expected directory: electron-v2.0-linux-arm-glibc
                        Found: [node-v64-linux-arm-glibc]
                        This problem can often be fixed by running “npm rebuild” on the current system
                        Original error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v2.0-linux-arm-glibc/grpc_node.node’
                        App threw an error during load
                        at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:53:17)
                        at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:63:3)
                        at Module._compile (module.js:642:30)
                        at Object.Module._extensions…js (module.js:653:10)
                        at Module.load (module.js:561:32)
                        at tryModuleLoad (module.js:504:12)
                        at Function.Module._load (module.js:496:3)
                        at Module.require (module.js:586:17)
                        at require (internal/module.js:11:18)
                        at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:144:12)
                        Whoops! There was an uncaught exception…
                        { Error: Failed to load gRPC binary module because it was not installed for the current system
                        at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:144:12) code: ‘MODULE_NOT_FOUND’ }
                        Launching application.
                        Can someone help me ??
                        • 21
                        • 22
                        • 23
                        • 24
                        • 25
                        • 42
                        • 43
                        • 23 / 43
