    MMM-AssistantMk2
    421 Posts 61 Posters 762.4k Views 57 Watching
    • O Offline
      otto @Guest
      @Sean do i need to reinstall it all, or can i just jump to electron-rebuild ?
      • ? Offline
        A Former User @otto
        @otto
        I think if there is no other issue, just doing electron-rebuild be enough.
        • O Offline
          otto @Guest
          @Sean
          just to be sure i havent miss understanding the guide,
          sudo apt-get install gcc-5 #or gcc-7 what sholde i have 5 or 7 i am running the latest Raspbian Buster 2019-07-10
          ? 2 Replies Last reply Reply Quote 0
          • ? Offline
            A Former User @otto
            @otto
            Raspbian Buster has gcc8 as default. Unfortunately with gcc8, grpc wouldn’t be compiled easily. so You need to downgrade to gcc7
            • ? Offline
              A Former User @otto
              @otto
              sudo apt-get install gcc-7
              sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-7 10
              sudo update-alternatives --config gcc
              This may work to change current gcc version to 7.
              • O Offline
                otto @Guest
                @Sean
                pi@raspberrypi:~ $ sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-7 10
                pi@raspberrypi:~ $ sudo update-alternatives --config gcc
                There is only one option in the gcc link group (provides / usr / bin / gcc): / usr / bin / gcc-7
                Nothing to configure.
                i using google translate
                • ? Offline
                  A Former User @otto
                  @otto
                  In that case your gcc be version 7. check it with gcc -v (You probably downgraded global gcc to 7 already)
                  • O Offline
                    otto @Guest
                    @Sean said in MMM-AssistantMk2:
                    gcc -v
                    gcc version 7.3.0 (Raspbian 7.3.0-19) then i guess ist just electron-rebuild left to do
                    • ? Offline
                      A Former User @otto
                      @otto said in MMM-AssistantMk2:
                      right. jump to adventure. :D
                      • O Offline
                        otto @Guest
                        @Sean yepp i hope this will go better then last time, i was trying
                        • ? Offline
                          A Former User @otto
                          @otto
                          It will take 10~30 minutes to complete. Keep the power and network connection during rebuilding. Wish you a good luck!
                          • O Offline
                            otto @Guest
                            @Sean works lika a charm,
                            2 thing i whant to make changes on.
                            1. hava a other word like mirror mirror on the wall to activiet it
                            2. Now i have 2 icon in the top corner, on is flasing, gussing its looking for word to activet. can i hide them?
                            • ? Offline
                              A Former User @otto
                              @otto
                              1. Make your own hotword model with trainer included in MMM-Hotword. Read the docs.
                              2. For MMM-Hotword, set useDisplay:false
                                For MMM-AssistantMk2, sorry, not supported. I’m building a new updates about it but not finished yet. (nowadays I have not enough time to focus that module.)
                              • O Offline
                                otto @Guest
                                @otto
                                okej so i need to creaat a trainer.sh to change the wakeup work, now its smart mirror,
                                i am using home assistent an a google hub… and i works so good. i can tell my mirror to turnigen on all light… i am in love:D
                                GREAT JOB and thanks for al the help
                                  raedonlpa @Guest
                                  set pauseOnYoutube:false.
                                  Hello.
                                  -Where do I set this parameter? “set pauseOnYoutube:false”
                                  • T Offline
                                    teitlebot
                                    @Sean
                                    Is there anyway to have a Google home show its results on the magic mirror?
                                    • ? Offline
                                      A Former User @teitlebot
                                      @teitlebot
                                      do you mean real google home? In other words, you have already a real google home, and you can command it by voice, and you want to display the result from your google home to MagicMirror. right?
                                      Sorry, it is not possible.
                                      If you make some specific command for your google Home through IFTTT or google Action, in that case, your result could be transferred to MagicMirror(and be shown).
                                      But the usual and random commands - like “What time is it?”, “My next schedule”,… couldn’t
                                      • T Offline
                                        teitlebot @Guest
                                        @Sean thanks for responding. I assume this is a limitation on Google ends? Also how would I tell ifttt to show on magic mirror?
                                        • ? Offline
                                          @teitlebot
                                          There are several posts in this forum. search “ifttt” and read them
                                          • ? Offline
                                            @teitlebot
                                            https://forum.magicmirror.builders/topic/10917/guide-control-mm-via-google-home
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 18 / 22
