    MMM-AssistantMk2
    421 Posts 61 Posters 804.0k Views 57 Watching
      A Former User @jomwells
      @jomwells is there any suspicious errors?
      S J 2 Replies Last reply
        Sun @jomwells
        @jomwells Are you using rp3 as magic mirror? I did get sound respond now and it really ugly. I do try both sound on tv via hdmi and from usb sound card. Assume that too much modules from magic mirror load.
          Sun @Guest
          @sean I would like to know more about MMM-Gaction regarding the deviceModelId - this should be done since register the device in mmm-assistantmk2. What about deviceInstanceId, where and how to?
          ? 2 Replies Last reply
            A Former User @Sun
            @sun read this page carefully.
            https://developers.google.com/assistant/sdk/reference/device-registration/register-device-manual#get-access-token
              A Former User @Sun
              @sun But In most cases, you might not need instance, because your mirror might be only one instance of your project. Instance is needed when action should select specific device for response. Try without instanceid first.
                Sun @Guest
                @sean Thank you so much.
                • J
                  jomwells @Guest
                  @sean Yes, the pm2 error logs show some alsa related errors, I assume this is why the assistant doesn’t produce audio?
                  /home/pi/.pm2/logs/MagicMirror-error.log:
                  [../deps/mpg123/src/output/alsa.c:90] error: initialize_device(): cannot set format S16_LE
                  MESA-LOADER: failed to retrieve device information
                  libGL error: MESA-LOADER: failed to retrieve device information
                  [../deps/mpg123/src/output/alsa.c:94] error: initialize_device(): cannot set 1 channels
                  I have a pretty fresh install of MagicMirror so shouldn’t be an issue of too many modules, im using an RPI3, and a USB sound card, thanks
                  on a side note, to get the Hotword and Assistant module to choose the correct microphone, I have had to change the input device to
                  device: 'plughw:1',
                  however each time I reboot, the input devices change order and I need to edit the config file again, is there a way to stop them changing device number?
                  ? 1 Reply Last reply
                    @jomwells
                    Frankly says, I’m not an expert of system administration. Especially Alsa configuration is out of my ability.
                    Anyway you should success this test.
                    arecord -d 10 test.wav & aplay test.wav
                    It should record your voice and play again.
                    It means, your mic and speaker should be default device.
                    • J
                      jomwells
                      To anyone having issues with RPI3 and a USB sound card, the solution to this was to change ‘/home/pi/.asoundrc’ to:
                      pcm.!default {
                        type plug
                        slave {
                          pcm "hw:1,0"
                      ctl.!default {
                          type hw
                          card 1
                      (where the USB device is card 1)
                      Thank you @Sean for your help, it is now working brilliantly, this is by far the best voice assistant module for MM!
                      Is there any way to configure how long the result card displays on screen before hiding itself? If not, could this be added in a later version? thanks!
                      ? S T 3 Replies Last reply
                        @jomwells
                        Card display time is decided by card itself. Maybe I can hook the duration, but with some painful effort, not even clearly.
                        The card itself is hardcoded, so there isn’t enough margin to manipulate. Originally the card would be planned to be used on specific device - smart tv, so ours has some limitation for full usage.
                        For example, In smart tv, a user can decide to play or not the result of a YouTube search by remote controller, but we haven’t. That is why I implement YouTube player in this module. Other functions are the same.
                        J 1 Reply Last reply
                        • J
                          jomwells @Guest
                          @sean Ah I see, its not essential at all! one minor bug I seem to have, that I have noticed does not occur for you in your demonstration video is that now, having finished the audio reply, there is often a very short sound, it sounds like the last half a second of text is repeated, sometimes it is more of a ‘buzz’, I attempted changing the encodingOut setting to one of the other options (MP3 or OPUS_IN_OGG) but both of these just give white noise (like an old tv with no signal) in place of any audio, is this something you have come across at all, and is there anything you can suggest to fix it? maybe getting the alternative encoding to work? thanks
                          ? J 3 Replies Last reply
                            @jomwells
                            I’m not sure.
                            Voice output is just buffered stream, so just piping it to the speaker is all of mechanism. So at the moment I have no idea why last data is duplicated(?) in your environment.
                            Voice output stream comes chunked, so there is some possibility of the time gap between incoming stream chunks.
                            Maybe instead piping Linear16 to speaker directly, writing response stream to mp3(or ogg) file then playing that file could be one of solutions.(sorry, I didn’t implement that)
                              @jomwells
                              For the Speaker, research this.
                              https://github.com/TooTallNate/node-speaker
                                Sun @jomwells
                                @jomwells Mine is a little bit different as I use the hdmi on tv as speaker as well. the default device fall on card 0 with alsa. For microphone is usb on card 1. I don’t have problem with microphone but I did have problem with sound via hdmi. Sometime sound just come out right through the hdmi but with lag sound, sometime no sound at all and say device busy. Also, to avoid hdmi device busy, I use usb sound card instead of hdmi sound also very lag.
                                pcm.!default {
                                type asym
                                playback.pcm
                                type hw
                                card 0
                                device 1
                                capture.pcm
                                type hw
                                card 1
                                device 0
                                  Sun @Guest
                                  @sean How to change the piping Linear 16 to ogg. Can I just put ogg in the
                                  encodingOut: “OPUS_IN_OGG”,
                                    A Former User @Sun
                                    @sun
                                    No, mp3 and Ogg should be written to file or piping to proper player, frankly I didn’t implement those function, because I thought nobody needs.
                                    I’ll try those till next update.
                                    • J
                                      jomwells
                                      Thank you, I will look into piping the audio, but its unlikely I will get very far :)
                                      Question: is it possible to run terminal commands at the different stages of MMM-AssistantMk2, such as running a command to turn on a GPIO pin (using the built in ‘GPIO write X 1’ ) when the module begins listening, and turning it off again when it is understanding, or speaking perhaps? the use case for which would be a status LED on the mirror. Thanks again.
                                        @jomwells
                                        You can fork my repository to yours and modify it.
                                        When you want to relay status to other modules, add .sendNotification() in ’socketNotificationReceived()’ of AssistantMk2.js where proper event is located.
                                        When you want to do something directly, add your job in ’Conversation.on(EVENT)’ of node_helper.js.
                                          Sun
                                          1. What else do I need to do for install for mmm-assistantmk2 to play youtube.
                                          2. I try the same command say Celine Dion The power of love. Then pop up below detail about Celine Dion and the youtube video automatically pop up but cannot play anything.
                                          3. My magic mirror is vertical mode, rotate = 1 . I try to adjust from your height 480 width 854 of display but it also show in vertical mode height 480 with 640 also height 640 width 480. No different.
                                            A Former User @Sun
                                            @sun
                                            • Some youtube videos are not allowed for embedded player.
                                            • some videos are not caught, it will be fixed.
                                            • some videos are not only video but playlist, so it is not caught, but it will be fixed also.
                                            • sometime Google gives no information about youtube. I guess smart tv is using not only YouTube but also other dedicated apps for music and video, yogether
                                            D 1 Reply Last reply
                                            • 21
                                            • 22
                                            • 2 / 22
