    MMM-AssistantMk2
    421 Posts 61 Posters 796.8k Views 57 Watching
      Sun
      Finally, Got the microphone icon in my mirror. Didn’t detect the voice yet I still have to install mmm-hotword.
      But I can ask one question by click the microphone icon and see the pop-up.
      I use hdmi on my tv as well. Still no sound.
      I will install mmm-hotword and test.
      Also the mmm-gaction if it make the mirror better.
      I will keep you update and might need your help if I got struck in some part.
      Thank you very much Mr.Sean.
        Sun
        Install mmm-hotword everything went fine during installation and load magic mirror normally. But no hotword detected.
        also show in command promt.
        Refreshed access token because it has expired. Expired at: 18:57:26 now is: 18:57:29
        Refreshed access token because it has expired. Expired at: 19:57:29 now is: 18:57:29
        Refreshed access token because it has expired. Expired at: 19:57:29 now is: 18:57:30
        and when click the microphone icon. I can only click once after restart and ask question. Hotword didn’t detect smart mirror, snowboy.
        in command promt shows
        at Speaker._write (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:183:23)
        at doWrite (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:428:64)
        at writeOrBuffer (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:417:5)
        at Speaker.Writable.write (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:334:11)
        at Conversation.conversation.on (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:75:16)
        at emitOne (events.js:116:13)
        at Conversation.emit (events.js:211:7)
        at ClientDuplexStream.Conversation.conversation.on (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/google-assistant/components/conversation.js:154:12)
        Conversation Completed
        [HOTWORD] << snowboy >> is detected.
        [HOTWORD] stops listening
        ? 2 Replies Last reply
          A Former User @Sun
          @sun
          have you removed or refreshed your credentials.json or default.json in MMM-AssistantMk2?
          I suggest you remove or disable all other modules (including MMM-AssistantMk2) except MMM-Hotword in config.js and test it.
          Definitely success with MMM-Hotword could make things simple and easy.
          After removing all modules except MMM-Hotword in config.js, run MM.(npm start)
          You can see;
          [HOTWORD] begins listening
          say smart mirror
          You can see;
          [HOTWORD] << smart mirror >> is detected.
          [HOTWORD] stop listening
          You should confirm this before going forward.
            A Former User @Sun
            @sun
            OK. have you installed “MMM-NotificationTrigger” ?
            Or give me a chat in this forum, or telegram me (@eouia)
              Sun
              Not yet install mmm-notificationtrigger.
              Do I have to install mmm-notificationtrigger as well?
              I manage to get
              but when I say something. it won’t detect what I said. Only detect the hotword.
                Sun
                Got it done. Very nice. However, the sound is so lag. Might be because I run on rp3 and quite many modules in magic mirror.
                ? 1 Reply Last reply
                  A Former User @Sun
                  @sun
                  Maybe. I always use BT speaker for my RPI and ATB. I cannot bear the crumpled sounds from analog or USB.
                    jomwells
                    This is fantastic thank you, I have got everything set up, it hears and responds (on screen) to every request - but unfortunately I get no sound (no speaking feedback), when a youtube video plays, the sound works fine, do I need to change the output device somewhere? I’m struggling to find the config for it.
                    ? S 2 Replies Last reply
                      A Former User @jomwells
                      @jomwells is there any suspicious errors?
                      S J 2 Replies Last reply
                        Sun @jomwells
                        @jomwells Are you using rp3 as magic mirror? I did get sound respond now and it really ugly. I do try both sound on tv via hdmi and from usb sound card. Assume that too much modules from magic mirror load.
                          Sun @Guest
                          @sean I would like to know more about MMM-Gaction regarding the deviceModelId - this should be done since register the device in mmm-assistantmk2. What about deviceInstanceId, where and how to?
                            A Former User @Sun
                            @sun read this page carefully.
                            https://developers.google.com/assistant/sdk/reference/device-registration/register-device-manual#get-access-token
                              A Former User @Sun
                              @sun But In most cases, you might not need instance, because your mirror might be only one instance of your project. Instance is needed when action should select specific device for response. Try without instanceid first.
                                Sun @Guest
                                @sean Thank you so much.
                                  jomwells @Guest
                                  @sean Yes, the pm2 error logs show some alsa related errors, I assume this is why the assistant doesn’t produce audio?
                                  /home/pi/.pm2/logs/MagicMirror-error.log:
                                  [../deps/mpg123/src/output/alsa.c:90] error: initialize_device(): cannot set format S16_LE
                                  MESA-LOADER: failed to retrieve device information
                                  libGL error: MESA-LOADER: failed to retrieve device information
                                  [../deps/mpg123/src/output/alsa.c:94] error: initialize_device(): cannot set 1 channels
                                  I have a pretty fresh install of MagicMirror so shouldn’t be an issue of too many modules, im using an RPI3, and a USB sound card, thanks
                                  on a side note, to get the Hotword and Assistant module to choose the correct microphone, I have had to change the input device to
                                  device: 'plughw:1',
                                  however each time I reboot, the input devices change order and I need to edit the config file again, is there a way to stop them changing device number?
                                    @jomwells
                                    Frankly says, I’m not an expert of system administration. Especially Alsa configuration is out of my ability.
                                    Anyway you should success this test.
                                    arecord -d 10 test.wav & aplay test.wav
                                    It should record your voice and play again.
                                    It means, your mic and speaker should be default device.
                                      jomwells
                                      To anyone having issues with RPI3 and a USB sound card, the solution to this was to change ‘/home/pi/.asoundrc’ to:
                                      pcm.!default {
                                        type plug
                                        slave {
                                          pcm "hw:1,0"
                                      ctl.!default {
                                          type hw
                                          card 1
                                      (where the USB device is card 1)
                                      Thank you @Sean for your help, it is now working brilliantly, this is by far the best voice assistant module for MM!
                                      Is there any way to configure how long the result card displays on screen before hiding itself? If not, could this be added in a later version? thanks!
                                      ? S T 3 Replies Last reply
                                        @jomwells
                                        Card display time is decided by card itself. Maybe I can hook the duration, but with some painful effort, not even clearly.
                                        The card itself is hardcoded, so there isn’t enough margin to manipulate. Originally the card would be planned to be used on specific device - smart tv, so ours has some limitation for full usage.
                                        For example, In smart tv, a user can decide to play or not the result of a YouTube search by remote controller, but we haven’t. That is why I implement YouTube player in this module. Other functions are the same.
                                        J 1 Reply Last reply
                                          jomwells @Guest
                                          @sean Ah I see, its not essential at all! one minor bug I seem to have, that I have noticed does not occur for you in your demonstration video is that now, having finished the audio reply, there is often a very short sound, it sounds like the last half a second of text is repeated, sometimes it is more of a ‘buzz’, I attempted changing the encodingOut setting to one of the other options (MP3 or OPUS_IN_OGG) but both of these just give white noise (like an old tv with no signal) in place of any audio, is this something you have come across at all, and is there anything you can suggest to fix it? maybe getting the alternative encoding to work? thanks
                                          ? J 3 Replies Last reply
                                            @jomwells
                                            I’m not sure.
                                            Voice output is just buffered stream, so just piping it to the speaker is all of mechanism. So at the moment I have no idea why last data is duplicated(?) in your environment.
                                            Voice output stream comes chunked, so there is some possibility of the time gap between incoming stream chunks.
                                            Maybe instead piping Linear16 to speaker directly, writing response stream to mp3(or ogg) file then playing that file could be one of solutions.(sorry, I didn’t implement that)
                                            • 21
                                            • 22
                                            • 2 / 22
