    MMM-AssistantMk2
    421 Posts 61 Posters 645.2k Views 57 Watching
      maxbachmann
      @Sean I know the trouble gets a nightmare to maintain code thats not splitted properly
      • K Offline
        komodoteler @Guest
        @sean
        I followed installation step by step until configuration part. credentials works fine when test.js ran.
        Once reboot, i initially had blank screen but once electron build completed, i have mic icon on MM but unable to activate google assistant. I am using default config.js with single default profile.
        I am using HDMI as output from TV which confirmed working after forcing HDMI output via raspi-config.
        As input, I use USB Mini Microphone which confirmed after command “arecord -l” ran.
        Do i need to install MMM-Hotword & MMM-NotificationTrigger too?
          A Former User @komodoteler
          @komodoteler
          Unless using other awakener or touchscreen, you need MMM-Hotword &MMM-NotificationTrigger.
          • K Offline
            komodoteler
            Apparently my microphone was not setup correctly. without MMM-Hotword and MMM-NotificationTrigger, it works but i have manually click the mic icon on every interaction with GA.
            All i need is to use the hotword module to trigger the GA. The sample config file is too complicated for me and i don’t use IFTTT, GAction, etc.
            Please help.
              @komodoteler
              How can I help you? Give me a detail.
              If you need personal contact;
              Mail: eouia0819@gmail.com
              Telegram: @eouia
              • K Offline
                komodoteler
                Sean, thanks for the help and patience, finally managed to work out the issue.
                it was mainly with improper setting on .asoundrc and config.js
                This is hands down the best voice recognition with visual there is.
                One small thing I noticed is the youtube video opened sometimes throw “invalid parameter”. Could it be default youtube parameter on config.js?
                ? 1 Reply Last reply Reply Quote 3
                  @komodoteler Most of those cases are, “Not allowed playing on ‘embeded player(out of youtube)’ by Authorities”.
                    Sun
                    1. Start Create Project, what option to choose, is it for Home control ?
                    2. During the process of register a device model, What to choose in Device Type?
                      A Former User @Sun
                      @sun
                      1. You can skip that part or select whatever you want.
                      2. That is also whatever you want. Usually, I set as “TV”. (because it definitely has screen to display something)
                        Sun
                        Finally, Got the microphone icon in my mirror. Didn’t detect the voice yet I still have to install mmm-hotword.
                        But I can ask one question by click the microphone icon and see the pop-up.
                        I use hdmi on my tv as well. Still no sound.
                        I will install mmm-hotword and test.
                        Also the mmm-gaction if it make the mirror better.
                        I will keep you update and might need your help if I got struck in some part.
                        Thank you very much Mr.Sean.
                          Sun
                          Install mmm-hotword everything went fine during installation and load magic mirror normally. But no hotword detected.
                          also show in command promt.
                          Refreshed access token because it has expired. Expired at: 18:57:26 now is: 18:57:29
                          Refreshed access token because it has expired. Expired at: 19:57:29 now is: 18:57:29
                          Refreshed access token because it has expired. Expired at: 19:57:29 now is: 18:57:30
                          and when click the microphone icon. I can only click once after restart and ask question. Hotword didn’t detect smart mirror, snowboy.
                          in command promt shows
                          at Speaker._write (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:183:23)
                          at doWrite (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                          at writeOrBuffer (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                          at Speaker.Writable.write (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:334:11)
                          at Conversation.conversation.on (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:75:16)
                          at emitOne (events.js:116:13)
                          at Conversation.emit (events.js:211:7)
                          at ClientDuplexStream.Conversation.conversation.on (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/google-assistant/components/conversation.js:154:12)
                          Conversation Completed
                          [HOTWORD] << snowboy >> is detected.
                          [HOTWORD] stops listening
                            A Former User @Sun
                            @sun
                            have you removed or refreshed your credentials.json or default.json in MMM-AssistantMk2?
                            I suggest you remove or disable all other modules (including MMM-AssistantMk2) except MMM-Hotword in config.js and test it.
                            Definitely success with MMM-Hotword could make things simple and easy.
                            After removing all modules except MMM-Hotword in config.js, run MM.(npm start)
                            You can see;
                            [HOTWORD] begins listening
                            say smart mirror
                            You can see;
                            [HOTWORD] << smart mirror >> is detected.
                            [HOTWORD] stop listening
                            You should confirm this before going forward.
                              A Former User @Sun
                              @sun
                              OK. have you installed “MMM-NotificationTrigger” ?
                              Or give me a chat in this forum, or telegram me (@eouia)
                                Sun
                                Not yet install mmm-notificationtrigger.
                                Do I have to install mmm-notificationtrigger as well?
                                I manage to get
                                but when I say something. it won’t detect what I said. Only detect the hotword.
                                  Sun
                                  Got it done. Very nice. However, the sound is so lag. Might be because I run on rp3 and quite many modules in magic mirror.
                                    A Former User @Sun
                                    @sun
                                    Maybe. I always use BT speaker for my RPI and ATB. I cannot bear the crumpled sounds from analog or USB.
                                      jomwells
                                      This is fantastic thank you, I have got everything set up, it hears and responds (on screen) to every request - but unfortunately I get no sound (no speaking feedback), when a youtube video plays, the sound works fine, do I need to change the output device somewhere? I’m struggling to find the config for it.
                                      ? S 2 Replies Last reply Reply Quote 0
                                        A Former User @jomwells
                                        @jomwells is there any suspicious errors?
                                        S J 2 Replies Last reply Reply Quote 0
                                          Sun @jomwells
                                          @jomwells Are you using rp3 as magic mirror? I did get sound respond now and it really ugly. I do try both sound on tv via hdmi and from usb sound card. Assume that too much modules from magic mirror load.
                                            Sun @Guest
                                            @sean I would like to know more about MMM-Gaction regarding the deviceModelId - this should be done since register the device in mmm-assistantmk2. What about deviceInstanceId, where and how to?
                                            • 21
                                            • 22
                                            • 1 / 22
