    MMM-AssistantMk2
    421 Posts 61 Posters 624.3k Views 57 Watching
      A Former User @komodoteler
      @komodoteler
      Unless using other awakener or touchscreen, you need MMM-Hotword &MMM-NotificationTrigger.
      • K Offline
        komodoteler
        Apparently my microphone was not setup correctly. without MMM-Hotword and MMM-NotificationTrigger, it works but i have manually click the mic icon on every interaction with GA.
        All i need is to use the hotword module to trigger the GA. The sample config file is too complicated for me and i don’t use IFTTT, GAction, etc.
        Please help.
          @komodoteler
          How can I help you? Give me a detail.
          If you need personal contact;
          Mail: eouia0819@gmail.com
          Telegram: @eouia
          • K Offline
            komodoteler
            Sean, thanks for the help and patience, finally managed to work out the issue.
            it was mainly with improper setting on .asoundrc and config.js
            This is hands down the best voice recognition with visual there is.
            One small thing I noticed is the youtube video opened sometimes throw “invalid parameter”. Could it be default youtube parameter on config.js?
            ? 1 Reply Last reply Reply Quote 3
              @komodoteler Most of those cases are, “Not allowed playing on ‘embeded player(out of youtube)’ by Authorities”.
                Sun
                1. Start Create Project, what option to choose, is it for Home control ?
                2. During the process of register a device model, What to choose in Device Type?
                  A Former User @Sun
                  @sun
                  1. You can skip that part or select whatever you want.
                  2. That is also whatever you want. Usually, I set as “TV”. (because it definitely has screen to display something)
                    Sun
                    Finally, Got the microphone icon in my mirror. Didn’t detect the voice yet I still have to install mmm-hotword.
                    But I can ask one question by click the microphone icon and see the pop-up.
                    I use hdmi on my tv as well. Still no sound.
                    I will install mmm-hotword and test.
                    Also the mmm-gaction if it make the mirror better.
                    I will keep you update and might need your help if I got struck in some part.
                    Thank you very much Mr.Sean.
                      Sun
                      Install mmm-hotword everything went fine during installation and load magic mirror normally. But no hotword detected.
                      also show in command promt.
                      Refreshed access token because it has expired. Expired at: 18:57:26 now is: 18:57:29
                      Refreshed access token because it has expired. Expired at: 19:57:29 now is: 18:57:29
                      Refreshed access token because it has expired. Expired at: 19:57:29 now is: 18:57:30
                      and when click the microphone icon. I can only click once after restart and ask question. Hotword didn’t detect smart mirror, snowboy.
                      in command promt shows
                      at Speaker._write (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:183:23)
                      at doWrite (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                      at writeOrBuffer (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                      at Speaker.Writable.write (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:334:11)
                      at Conversation.conversation.on (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:75:16)
                      at emitOne (events.js:116:13)
                      at Conversation.emit (events.js:211:7)
                      at ClientDuplexStream.Conversation.conversation.on (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/google-assistant/components/conversation.js:154:12)
                      Conversation Completed
                      [HOTWORD] << snowboy >> is detected.
                      [HOTWORD] stops listening
                        A Former User @Sun
                        @sun
                        have you removed or refreshed your credentials.json or default.json in MMM-AssistantMk2?
                        I suggest you remove or disable all other modules (including MMM-AssistantMk2) except MMM-Hotword in config.js and test it.
                        Definitely success with MMM-Hotword could make things simple and easy.
                        After removing all modules except MMM-Hotword in config.js, run MM.(npm start)
                        You can see;
                        [HOTWORD] begins listening
                        say smart mirror
                        You can see;
                        [HOTWORD] << smart mirror >> is detected.
                        [HOTWORD] stop listening
                        You should confirm this before going forward.
                        • 42
                        • 43
                        • 1 / 43
