    MMM-AssistantMk2
    421 Posts 61 Posters 593.3k Views 57 Watching
      MisterT @sdetweil
      @sdetweil ok i installed MMM-GoogleMapsTraffic from your repo and i launched my MM. The result is :
      • MMM-MK2 works very well
      • MMM-GoogleMapsTraffic not works. I haven’t maps on the screen
      When i installed from your repo i had some “warn” message.See below
      npm notice created a lockfile as package-lock.json. You should commit this file.
      npm WARN grunt-stylelint@0.14.0 requires a peer of stylelint@^13.2.0 but none is installed. You must install peer dependencies yourself.
      npm WARN stylelint-config-standard@20.0.0 requires a peer of stylelint@>=10.1.0 but none is installed. You must install peer dependencies yourself.
      npm WARN stylelint-config-recommended@3.0.0 requires a peer of stylelint@>=10.1.0 but none is installed. You must install peer dependencies yourself.
      npm WARN MMM-GoogleMapsTraffic@1.0.0 No repository field.
      is it possible that these “warn” are the problem ?
      My config if need:
      module: 'MMM-GoogleMapsTraffic',
               position: 'bottom_left',
                    key: 'xxxxxxxxx',
                     lat: 4x.470485,
                      lng: x.231369,
                      height: '300px',
                      width: '300px',
      		zoom: 14,
                      styledMapType: "transparent",
                      disableDefaultUI: true,
                      backgroundColor: 'hsla(0, 0%, 0%, 0)',
                      	markers: [
                              lat: 4x.470485,
                              lng: x.231369,
                              fillColor: '#9966ff'
        sdetweil @MisterT
        @MisterT if you use the sample config with your apikey does it work? (my api key below)
        if you look at the console log, do you see any errors reported
        pm2 logs, if you use pm2 to start the mirror, else the terminal window where you do npm start
                    position: 'top_left',
                        key: 'AIzaSyCJyY3ijaw9X9xJis62XWsbz32PXIk8krI',     /// put your key here
                        lat: 37.8262306,
                        lng: -122.2920096,
                        height: '300px',
                        width: '300px'
                        markers: [
                                lat: 37.8262316,
                                lng: -122.2920196,
          MisterT
          @sdetweil everything is fine now :smiling_face_with_open_mouth_cold_sweat:
          With a lot of tests and modification in my confis.js, i forgot to enable MMM-GoogleMapsTraffic in MMM-Pages module config file :dizzy_face:
          So now it’s great
          Thx for your support
          See you next time
          • K Offline
            kondef
            @Sean thanks for your work in relationship with the google assisstant. I am quite new in all of these set ups and i am facing a problem now which i can’t by pass. I tried to Register-my-Mirror-as-Google-Assistant-related-device but when i insert the foolowing code :curl -s -X POST -H “Content-Type: application/json”
            -H “Authorization: Bearer $ACCESSTOKEN” -d @deviceInstance.json
            https://embeddedassistant.googleapis.com/v1alpha2/projects/YOUR_PROJECT_ID/devices/
            i am getting the following error "bash: https://embeddedassistant.googleapis.com/v1alpha2/projects/(my_project_id)/devices/: No such file or directory
            Do you have any idea how i can resolve that issue??
            Thank you guys in advance
            • ? Offline
              A Former User @kondef
              @kondef said in MMM-AssistantMk2:
              This should be done in one line. I think you probably break line before https://embeddedassistant....
                airart
                where I find a different UI, maybe transparent, I saw bars and bubbles with a transparent background
                thanks a lot and great job
                  banbutcher
                  howdy,
                  ive seen a couple of people running assistantmk2 v2 and i liked the interface better than the v3 and i was wondering if its possible to install the v2 instead of v3. how would i go about downgrading to v2?
                  thanks
                  Richie
                    acimail01
                    Can you trigger a sound output from a recipe while the Assistantmk2 is active?
                    For me sound output only works when the assistant is not active e.g. when I trigger sound output via web service (e.g. MMM-Sound or MMM-Text-To-Speech).
                    My use case is:
                    A recipe that listens to “mirror mirror on the wall” and then either plays an mp3 / wav or speak TTS
                      acimail01
                      does anyone have any idea how to trigger sound output with the Assitantmk2?
                        Mrtrol2013
                        Does this module support Russian?
                        • 39
                        • 40
                        • 41
                        • 42
                        • 43
                        • 42 / 43
