    MMM-AssistantMk2
    421 Posts 61 Posters 626.9k Views 57 Watching
    • T Offline
      tontonchow @Guest
      @Sean my app is correctly configure for me. If he don’t understand histoire reply is in french but if i speak french he don’t understand.
      Étrange
      • ? Offline
        A Former User @tontonchow
        @tontonchow
        Weird. Transcription on the log is returned as French as expected?
        • T Offline
          tontonchow @Guest
          @Sean Yes
          I don’t know why but it seems to work after adjust config.js and reboot
          add , after lang line
          profiles: {
                   "default" : {
                              profileFile: "default.json",
                              lang: "fr-FR",
          • ? Offline
            @tontonchow
            Can you show me the log of transcription part when you said some phrases as French? To see whether transcription was recognized as French or not.
              MisterT
              Hi Sean,
              Nice works for MK2 update but i have a problem to install it. I launched the auto installation but a packet is not found. gcc-7 is missing. when a try to install manually the answer is (in french):
              pi@raspberrypi:~/MagicMirror/modules/MMM-AssistantMk2 $ sudo apt-get install gcc-7
              Lecture des listes de paquets... Fait
              Construction de l'arbre des dépendances
              Lecture des informations d'état... Fait
              E: Impossible de trouver le paquet gcc-7
              when i write gcc -v the result is:
              gcc version 6.3.0 20170516 (Raspbian 6.3.0-18+rpi1+deb9u1)
              And without this my Magic mirror turn into a black screen
              How i can install gcc-7 ?
              Do i need an update of raspbian to install gcc-7. I’m on last version of raspbian Stretch
              Thanks for your support and your next answers
              • ? Offline
                A Former User @MisterT
                @MisterT
                first, try to install without gcc7. usually gcc8 on buster was a reason of problem, so gcc6 on stretch might be ok(not tested currently but it worked a year ago)
                  MisterT
                  hi @Sean thanks for your reply. So retry auto installation with gc6 and rebuild electron. Then finish the config with my audio and mic. Great
                  After these, i download my credentials then make my default profile.
                  So everithing seem to bo good. that’t why i start MM and:
                  MK2v3 logo is on my Magic mirror with animation but when i say a simple sentence, nothing happen.
                  I changed hotword word to Jarvis and html5 to mpg321 but it’s the same thing.
                  See below my config js for hotword and MK2
                  	module: "MMM-Hotword",
                  	useDisplay: false,
                  	chimeOnFinish: null,
                  	recipes: ["with-AMk2v3_Jarvis.js"],
                  	mic: {
                  		recordProgram: "arecord",
                  		device: "plughw:1",
                    	module: "MMM-AssistantMk2",
                  	debug: true,
                  	 ui: "Classic",
                  	assistantConfig: {
                  	latitude: 43.64074, // -90.0 - +90.0
                  	longitude: 5.09545, // -180.0 - +180.0
                  	responseConfig: {
                  	useHTML5: false, // sound render by HTML5
                  	playProgram: "mpg321",
                  	micConfig: {
                  	recorder: "arecord",
                  	device: "plughw:1",
                  	recipes: [
                  	"with-MMM-Hotword.js"
                  	profiles: {
                  	"default": {
                  			lang: "fr-FR"
                  have you an idea ?
                  • ? Offline
                    @MisterT
                    Need a log to know what happens.
                      MisterT @Guest
                      @Sean after uninstall, re install, rebuilt electron from MK2 and from Hotword, it was always the same.
                      So i decided to start a simple config.js with only default modules and Mk2 and hotword. Finaly…Tada !!! it works.
                      The guilty module is MMM-GooglemapsTraffic. So I hid it in my config.js
                      I have no console log about Mk2 if MMM-GooglemapsTraffic is on.
                      Have you an idea?
                        sdetweil @MisterT
                        @MisterT said in MMM-AssistantMk2:
                        yes, it has a bug, download the fixed version from my repo (the author has not updated from my changes, last updated 2 years ago)
                        rename the existing module folder out of the way
                        cd ~/MagicMirror/modules
                        mv MMM-GooglemapsTraffic MMM-GooglemapsTraffic.original
                        git clone https://github.com/sdetweil/MMM-GoogleMapsTraffic.git
                        cd MMM-GooglemapsTraffic
                        npm install
                        • 39
                        • 40
                        • 41
                        • 42
                        • 43
                        • 41 / 43
