    MMM-AssistantMk2
    421 Posts 61 Posters 712.7k Views 57 Watching
    • T Offline
      teitlebot @Guest
      @Sean thanks that looks awesome. Going to save it for a rainy day to install.
      • W Offline
        wellwhatever
        Hello @Sean I’ve successfully rebuild the module but when I tried to activate it in the config, the module doesn’t load. The log says ‘No helper found for module: MMM-AssistantMk2’ (pretty sure the file is there inside the module folder). Have any idea whats the cause of this problem?
        Thanks in advance!
        • ? Offline
          A Former User @wellwhatever
          @wellwhatever
          Never seen that kind. Loading node_helper.js is MM’s job itself. If there is the file, regardless it has some errors or not, MM should try to load that file. (And if it has an error, it would spit out the error)
          • W Offline
            wellwhatever @Guest
            This post is deleted!
              acimail01
              How can I stop a video?
              config is
              youtubeAutoplay	: true,
              pauseOnYoutube : false,
              But it does not help.
              • ? Offline
                A Former User @acimail01
                @acimail01
                with these options, you can re activate hotword again, and then, the current YT player will stop and be hidden.
                Anyway, I’ll remove YT related feature on next updates.
                • K Offline
                  Keith
                  I’m trying to create a recipe that with a single command will hide “module A” and show “module B”. Another command will reverse this action. I can hide and show single modules or all modules but I can’t figure out hide one and show another. Any suggestions would be appreciated.
                  • T Offline
                    tanvir586
                    hi everyone,
                    how to get my YOUR_MODEL_ID. couldn’t find it any ware.
                    • ? Offline
                      A Former User @Keith
                      @Keith
                      Almost same. :D
                      command: {
                        "HIDE_A_REVEAL_B": {
                          moduleExec: {
                            module: [], // For all modules,
                            exec: (module, params, key) => {
                              if (module.name == "MODULE_A") { // if module name is...
                                module.hide()
                              if (module.name == "MODULE_B") {
                                module.show()
                      Not tested code, but I believe you can catch the idea.
                      K 2 Replies Last reply Reply Quote 0
                      • ? Offline
                        A Former User @tanvir586
                        @tanvir586
                        Read this doc.
                        https://developers.google.com/assistant/sdk/guides/service/python/embed/register-device
                        • T Offline
                          tanvir586
                          Ive already registered. But now i can’t find the model id.
                          • ? Offline
                            @tanvir586
                            T J 2 Replies Last reply Reply Quote 0
                            • T Offline
                              tanvir586 @Guest
                              @Sean thanks for reply.
                              My screen is like this.!0_1575303692872_Screenshot_20191202-162015_Samsung Internet.jpg
                              I don’t have registration section.
                                sdetweil @tanvir586
                                @tanvir586 back a couple pages, you created an application, right?
                                at https://console.actions.google.com/u/0/?pli=1
                                • T Offline
                                  tanvir586
                                  Sorry guys i think i didn’t register it.
                                  I followed this video https://youtu.be/UBgH5hejYtM.
                                  • K Offline
                                    Keith @Guest
                                    @Sean I’ll give that a try and let you know. Thanks
                                    • K Offline
                                      Keith @Guest
                                      @Sean I got it working, thanks for your help. The code that worked for me is below
                                      command: {
                                            "HIDECALENDAR": {
                                                moduleExec: {
                                                     module:()=>{
                                            return []
                                          }, // For all modules,
                                                        if (module.name == "MMM-GooglePhotos") { // if module name is...
                                                            module.show()
                                                        if (module.name == "MMM-CalendarExt2") {
                                                            module.hide()
                                            "SHOWCALENDAR": {
                                                moduleExec: {
                                                     module:()=>{
                                            return []
                                                            module.hide()
                                                            module.show()
                                      • T Offline
                                        tanvir586
                                        Is it possible to make AssistantMk2 to show my ip camera feed? If i ask AssistantMk2 to show my front door, it says to select output display.
                                          juantata
                                            juantata
                                            Good. I have a problem, it has started happening today.
                                            magicmirror@2.8.0 start /home/pi/MagicMirror
                                            sh run-start.sh
                                            Starting MagicMirror: v2.8.0
                                            Loading config …
                                            Loading module helpers …
                                            Initializing new module helper …
                                            Module helper loaded: MMM-GoogleMapsTraffic
                                            No helper found for module: MMM-YouTube.
                                            No helper found for module: MMM-connection-status.
                                            Module helper loaded: MMM-Remote-Control
                                            Module helper loaded: MMM-Hotword
                                            Module helper loaded: MMM-AssistantMk2
                                            Module helper loaded: MMM-Spotify
                                            All module helpers loaded.
                                            Starting server on port 8080 …
                                            You’re using a full whitelist configuration to allow for all IPs
                                            Server started …
                                            Connecting socket for: MMM-GoogleMapsTraffic
                                            Starting node_helper for module: MMM-GoogleMapsTraffic
                                            Starting module: newsfeed
                                            Connecting socket for: MMM-Remote-Control
                                            Starting node helper for: MMM-Remote-Control
                                            Connecting socket for: MMM-Hotword
                                            [HOTWORD] MMM-Hotword starts
                                            Connecting socket for: MMM-AssistantMk2
                                            Connecting socket for: MMM-Spotify
                                            [SPOTIFY_AUTH] Token is fresh.
                                            Sockets connected & modules started …
                                            Launching application.
                                            ERROR! Could not find main module js file for pir
                                            Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/juanan+++ioiglesias21%40gmail.com/private-225241cce3b9ecf***011ef3193f0934/basic.ics - Interval: 300000
                                            Working notification system. Notification: MMM-GOOGLE_MAPS_TRAFFIC-GET payload: { style: ‘standard’ }
                                            Create new news fetcher for url: https://okdiario.com/feed - Interval: 300000
                                            [AMK2] Recipe is loaded: hide_and_show_all_modules.js
                                            [AMK2] Recipe is loaded: reboot.js
                                            [AMK2] Recipe is loaded: recipe.template.js
                                            [AMK2] Recipe is loaded: screen_onoff.js
                                            [AMK2] Recipe is loaded: shutdown.js
                                            [AMK2] Recipe is loaded: spotify.js
                                            [AMK2] Temporal storage directory is clearing.
                                            [HOTWORD] begins.
                                            [HOTWORD] Detector starts listening.
                                            [HOTWORD] stops.
                                            [HOTWORD] Final Result: { detected: false }
                                            [AMK2] assistant ready
                                            [AMK2] Conversation starts.
                                            [AMK2] Started with text query: brief today
                                            { requestId: ‘5deab96c-0000-2e12-9cee-f403043d40d8’ } { profileFile: ‘default.json’, lang: ‘es-ES’ }
                                            [AMK2] Device Action: { requestId: ‘5deab96c-0000-2e12-9cee-f403043d40d8’ }
                                            [AMK2] Assistant Text Response:
                                            [AMK2] Conversation Completed
                                            [HOTWORD] begins.
                                            [AMK2] Conversation Error: { Error: 14 UNAVAILABLE: Service unavailable.
                                            at Object.exports.createStatusError (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/common.js:91:15)
                                            at ClientDuplexStream._emitStatusIfDone (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js:233:26)
                                            at ClientDuplexStream._receiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js:211:8)
                                            at Object.onReceiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1306:15)
                                            at InterceptingListener._callNext (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:568:42)
                                            at InterceptingListener.onReceiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:618:8)
                                            at /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1123:18
                                            code: 14,
                                            metadata:
                                            Metadata { _internal_repr: { ‘content-disposition’: [Array] }, flags: 0 },
                                            details: ‘Service unavailable.’ }
                                            [HOTWORD] begins.
                                            code: 14,
                                            metadata:
                                            [HOTWORD] begins.
                                            ^C
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 19 / 22
