    MMM-AssistantMk2
    421 Posts 61 Posters 796.8k Views 57 Watching
    • A
      acimail01
      How can I stop a video?
      config is
      youtubeAutoplay	: true,
      pauseOnYoutube : false,
      But it does not help.
      ? 1 Reply Last reply
        A Former User @acimail01
        @acimail01
        with these options, you can re activate hotword again, and then, the current YT player will stop and be hidden.
        Anyway, I’ll remove YT related feature on next updates.
        • K
          Keith
          I’m trying to create a recipe that with a single command will hide “module A” and show “module B”. Another command will reverse this action. I can hide and show single modules or all modules but I can’t figure out hide one and show another. Any suggestions would be appreciated.
          • T
            tanvir586
            hi everyone,
            how to get my YOUR_MODEL_ID. couldn’t find it any ware.
              A Former User @Keith
              @Keith
              Almost same. :D
              command: {
                "HIDE_A_REVEAL_B": {
                  moduleExec: {
                    module: [], // For all modules,
                    exec: (module, params, key) => {
                      if (module.name == "MODULE_A") { // if module name is...
                        module.hide()
                      if (module.name == "MODULE_B") {
                        module.show()
              Not tested code, but I believe you can catch the idea.
              K 2 Replies Last reply
                A Former User @tanvir586
                @tanvir586
                Read this doc.
                https://developers.google.com/assistant/sdk/guides/service/python/embed/register-device
                • T
                  tanvir586
                  Ive already registered. But now i can’t find the model id.
                    @tanvir586
                    T J 2 Replies Last reply
                    • T
                      tanvir586 @Guest
                      @Sean thanks for reply.
                      My screen is like this.!0_1575303692872_Screenshot_20191202-162015_Samsung Internet.jpg
                      I don’t have registration section.
                        sdetweil @tanvir586
                        @tanvir586 back a couple pages, you created an application, right?
                        at https://console.actions.google.com/u/0/?pli=1
                        • T
                          tanvir586
                          Sorry guys i think i didn’t register it.
                          I followed this video https://youtu.be/UBgH5hejYtM.
                          • K
                            Keith @Guest
                            @Sean I’ll give that a try and let you know. Thanks
                            • K
                              Keith @Guest
                              @Sean I got it working, thanks for your help. The code that worked for me is below
                              command: {
                                    "HIDECALENDAR": {
                                        moduleExec: {
                                             module:()=>{
                                    return []
                                  }, // For all modules,
                                                if (module.name == "MMM-GooglePhotos") { // if module name is...
                                                    module.show()
                                                if (module.name == "MMM-CalendarExt2") {
                                                    module.hide()
                                    "SHOWCALENDAR": {
                                        moduleExec: {
                                             module:()=>{
                                    return []
                                                    module.hide()
                                                    module.show()
                              • T
                                tanvir586
                                Is it possible to make AssistantMk2 to show my ip camera feed? If i ask AssistantMk2 to show my front door, it says to select output display.
                                  juantata
                                    juantata
                                    Good. I have a problem, it has started happening today.
                                    magicmirror@2.8.0 start /home/pi/MagicMirror
                                    sh run-start.sh
                                    Starting MagicMirror: v2.8.0
                                    Loading config …
                                    Loading module helpers …
                                    Module helper loaded: MMM-GoogleMapsTraffic
                                    No helper found for module: MMM-YouTube.
                                    No helper found for module: MMM-connection-status.
                                    Module helper loaded: MMM-Remote-Control
                                    Module helper loaded: MMM-Hotword
                                    Module helper loaded: MMM-AssistantMk2
                                    Module helper loaded: MMM-Spotify
                                    All module helpers loaded.
                                    Starting server on port 8080 …
                                    You’re using a full whitelist configuration to allow for all IPs
                                    Server started …
                                    Connecting socket for: MMM-GoogleMapsTraffic
                                    Starting node_helper for module: MMM-GoogleMapsTraffic
                                    Starting module: newsfeed
                                    Connecting socket for: MMM-Remote-Control
                                    Starting node helper for: MMM-Remote-Control
                                    Connecting socket for: MMM-Hotword
                                    [HOTWORD] MMM-Hotword starts
                                    Connecting socket for: MMM-AssistantMk2
                                    Connecting socket for: MMM-Spotify
                                    [SPOTIFY_AUTH] Token is fresh.
                                    Sockets connected & modules started …
                                    Launching application.
                                    ERROR! Could not find main module js file for pir
                                    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/juanan+++ioiglesias21%40gmail.com/private-225241cce3b9ecf***011ef3193f0934/basic.ics - Interval: 300000
                                    Working notification system. Notification: MMM-GOOGLE_MAPS_TRAFFIC-GET payload: { style: ‘standard’ }
                                    Create new news fetcher for url: https://okdiario.com/feed - Interval: 300000
                                    [AMK2] Recipe is loaded: hide_and_show_all_modules.js
                                    [AMK2] Recipe is loaded: reboot.js
                                    [AMK2] Recipe is loaded: recipe.template.js
                                    [AMK2] Recipe is loaded: screen_onoff.js
                                    [AMK2] Recipe is loaded: shutdown.js
                                    [AMK2] Recipe is loaded: spotify.js
                                    [AMK2] Temporal storage directory is clearing.
                                    [HOTWORD] begins.
                                    [HOTWORD] Detector starts listening.
                                    [HOTWORD] stops.
                                    [HOTWORD] Final Result: { detected: false }
                                    [AMK2] assistant ready
                                    [AMK2] Conversation starts.
                                    [AMK2] Started with text query: brief today
                                    { requestId: ‘5deab96c-0000-2e12-9cee-f403043d40d8’ } { profileFile: ‘default.json’, lang: ‘es-ES’ }
                                    [AMK2] Device Action: { requestId: ‘5deab96c-0000-2e12-9cee-f403043d40d8’ }
                                    [AMK2] Assistant Text Response:
                                    [AMK2] Conversation Completed
                                    [HOTWORD] begins.
                                    [AMK2] Conversation Error: { Error: 14 UNAVAILABLE: Service unavailable.
                                    at Object.exports.createStatusError (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/common.js:91:15)
                                    at ClientDuplexStream._emitStatusIfDone (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js:233:26)
                                    at ClientDuplexStream._receiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js:211:8)
                                    at Object.onReceiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1306:15)
                                    at InterceptingListener._callNext (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:568:42)
                                    at InterceptingListener.onReceiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:618:8)
                                    at /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1123:18
                                    code: 14,
                                    metadata:
                                    Metadata { _internal_repr: { ‘content-disposition’: [Array] }, flags: 0 },
                                    details: ‘Service unavailable.’ }
                                    [HOTWORD] begins.
                                    code: 14,
                                    metadata:
                                    [HOTWORD] begins.
                                    ^C
                                      juantata @Guest
                                      @Sean
                                      Today’s summary works perfectly, but then the microphone does not listen and therefore there is no conversation.
                                      sh run-start.sh
                                      Loading config …
                                      Server started …
                                      [HOTWORD] begins.
                                      [HOTWORD] stops.
                                      [HOTWORD] begins.
                                      code: 14,
                                      metadata:
                                      [HOTWORD] begins.
                                      code: 14,
                                      metadata:
                                      [HOTWORD] begins.
                                      ^C
                                        A Former User @juantata
                                        @juantata
                                        Just remove useWelcomeMessage. That feature needs more configuration when using together MMM-Hotword. Not difficult but if you don’t understand what’s going on, just remove it.
                                        J 1 Reply Last reply
                                          juantata @Guest
                                          @Sean
                                          Thanks for the reply. But one question, if there has never been a problem with the daily summary, why now?
                                            @juantata
                                            Just random.
                                            When using useWelcomMessage, MMM-Hotword’s Mic should be closed. But by physical limitation, Sometimes MMM-Hotword’s mic was not completely closed when MMM-AssistantMk2 activation started. It’s not unpredictable. On the next version, it will be solved.
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 19 / 22
