    MMM-AssistantMk2
    421 Posts 61 Posters 801.4k Views 57 Watching
      A Former User @wellwhatever
      @wellwhatever
      Never seen that kind. Loading node_helper.js is MM’s job itself. If there is the file, regardless it has some errors or not, MM should try to load that file. (And if it has an error, it would spit out the error)
      W 1 Reply Last reply
      • W
        wellwhatever @Guest
        • A
          acimail01
          How can I stop a video?
          config is
          youtubeAutoplay	: true,
          pauseOnYoutube : false,
          But it does not help.
          ? 1 Reply Last reply
            A Former User @acimail01
            @acimail01
            with these options, you can re activate hotword again, and then, the current YT player will stop and be hidden.
            Anyway, I’ll remove YT related feature on next updates.
            • K
              Keith
              I’m trying to create a recipe that with a single command will hide “module A” and show “module B”. Another command will reverse this action. I can hide and show single modules or all modules but I can’t figure out hide one and show another. Any suggestions would be appreciated.
              • T
                tanvir586
                hi everyone,
                how to get my YOUR_MODEL_ID. couldn’t find it any ware.
                  A Former User @Keith
                  @Keith
                  Almost same. :D
                  command: {
                    "HIDE_A_REVEAL_B": {
                      moduleExec: {
                        module: [], // For all modules,
                        exec: (module, params, key) => {
                          if (module.name == "MODULE_A") { // if module name is...
                            module.hide()
                          if (module.name == "MODULE_B") {
                            module.show()
                  Not tested code, but I believe you can catch the idea.
                  K 2 Replies Last reply
                    A Former User @tanvir586
                    @tanvir586
                    Read this doc.
                    https://developers.google.com/assistant/sdk/guides/service/python/embed/register-device
                    • T
                      tanvir586
                      Ive already registered. But now i can’t find the model id.
                        @tanvir586
                        T J 2 Replies Last reply
                        • T
                          tanvir586 @Guest
                          @Sean thanks for reply.
                          My screen is like this.!0_1575303692872_Screenshot_20191202-162015_Samsung Internet.jpg
                          I don’t have registration section.
                            sdetweil @tanvir586
                            @tanvir586 back a couple pages, you created an application, right?
                            at https://console.actions.google.com/u/0/?pli=1
                            • T
                              tanvir586
                              Sorry guys i think i didn’t register it.
                              I followed this video https://youtu.be/UBgH5hejYtM.
                              • K
                                Keith @Guest
                                @Sean I’ll give that a try and let you know. Thanks
                                • K
                                  Keith @Guest
                                  @Sean I got it working, thanks for your help. The code that worked for me is below
                                  command: {
                                        "HIDECALENDAR": {
                                            moduleExec: {
                                                 module:()=>{
                                        return []
                                      }, // For all modules,
                                                    if (module.name == "MMM-GooglePhotos") { // if module name is...
                                                        module.show()
                                                    if (module.name == "MMM-CalendarExt2") {
                                                        module.hide()
                                        "SHOWCALENDAR": {
                                            moduleExec: {
                                                 module:()=>{
                                        return []
                                                        module.hide()
                                                        module.show()
                                  • T
                                    tanvir586
                                    Is it possible to make AssistantMk2 to show my ip camera feed? If i ask AssistantMk2 to show my front door, it says to select output display.
                                      juantata
                                        juantata
                                        Good. I have a problem, it has started happening today.
                                        magicmirror@2.8.0 start /home/pi/MagicMirror
                                        sh run-start.sh
                                        Starting MagicMirror: v2.8.0
                                        Loading config …
                                        Loading module helpers …
                                        Module helper loaded: MMM-GoogleMapsTraffic
                                        No helper found for module: MMM-YouTube.
                                        No helper found for module: MMM-connection-status.
                                        Module helper loaded: MMM-Remote-Control
                                        Module helper loaded: MMM-Hotword
                                        Module helper loaded: MMM-AssistantMk2
                                        Module helper loaded: MMM-Spotify
                                        All module helpers loaded.
                                        Starting server on port 8080 …
                                        You’re using a full whitelist configuration to allow for all IPs
                                        Server started …
                                        Connecting socket for: MMM-GoogleMapsTraffic
                                        Starting node_helper for module: MMM-GoogleMapsTraffic
                                        Starting module: newsfeed
                                        Connecting socket for: MMM-Remote-Control
                                        Starting node helper for: MMM-Remote-Control
                                        Connecting socket for: MMM-Hotword
                                        [HOTWORD] MMM-Hotword starts
                                        Connecting socket for: MMM-AssistantMk2
                                        Connecting socket for: MMM-Spotify
                                        [SPOTIFY_AUTH] Token is fresh.
                                        Sockets connected & modules started …
                                        Launching application.
                                        ERROR! Could not find main module js file for pir
                                        Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/juanan+++ioiglesias21%40gmail.com/private-225241cce3b9ecf***011ef3193f0934/basic.ics - Interval: 300000
                                        Working notification system. Notification: MMM-GOOGLE_MAPS_TRAFFIC-GET payload: { style: ‘standard’ }
                                        Create new news fetcher for url: https://okdiario.com/feed - Interval: 300000
                                        [AMK2] Recipe is loaded: hide_and_show_all_modules.js
                                        [AMK2] Recipe is loaded: reboot.js
                                        [AMK2] Recipe is loaded: recipe.template.js
                                        [AMK2] Recipe is loaded: screen_onoff.js
                                        [AMK2] Recipe is loaded: shutdown.js
                                        [AMK2] Recipe is loaded: spotify.js
                                        [AMK2] Temporal storage directory is clearing.
                                        [HOTWORD] begins.
                                        [HOTWORD] Detector starts listening.
                                        [HOTWORD] stops.
                                        [HOTWORD] Final Result: { detected: false }
                                        [AMK2] assistant ready
                                        [AMK2] Conversation starts.
                                        [AMK2] Started with text query: brief today
                                        { requestId: ‘5deab96c-0000-2e12-9cee-f403043d40d8’ } { profileFile: ‘default.json’, lang: ‘es-ES’ }
                                        [AMK2] Device Action: { requestId: ‘5deab96c-0000-2e12-9cee-f403043d40d8’ }
                                        [AMK2] Assistant Text Response:
                                        [AMK2] Conversation Completed
                                        [HOTWORD] begins.
                                        [AMK2] Conversation Error: { Error: 14 UNAVAILABLE: Service unavailable.
                                        at Object.exports.createStatusError (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/common.js:91:15)
                                        at ClientDuplexStream._emitStatusIfDone (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js:233:26)
                                        at ClientDuplexStream._receiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js:211:8)
                                        at Object.onReceiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1306:15)
                                        at InterceptingListener._callNext (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:568:42)
                                        at InterceptingListener.onReceiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:618:8)
                                        at /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1123:18
                                        code: 14,
                                        metadata:
                                        Metadata { _internal_repr: { ‘content-disposition’: [Array] }, flags: 0 },
                                        details: ‘Service unavailable.’ }
                                        [HOTWORD] begins.
                                        code: 14,
                                        metadata:
                                        [HOTWORD] begins.
                                        ^C
                                          juantata @Guest
                                          @Sean
                                          Today’s summary works perfectly, but then the microphone does not listen and therefore there is no conversation.
                                          sh run-start.sh
                                          Loading config …
                                          Server started …
                                          [HOTWORD] begins.
                                          [HOTWORD] stops.
                                          [HOTWORD] begins.
                                          code: 14,
                                          metadata:
                                          [HOTWORD] begins.
                                          code: 14,
                                          metadata:
                                          [HOTWORD] begins.
                                          ^C
                                            A Former User @juantata
                                            @juantata
                                            Just remove useWelcomeMessage. That feature needs more configuration when using together MMM-Hotword. Not difficult but if you don’t understand what’s going on, just remove it.
                                            J 1 Reply Last reply
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 19 / 22
