    MMM-AssistantMk2
    421 Posts 61 Posters 741.3k Views 57 Watching
      raedonlpa @Guest
      @Sean said in MMM-AssistantMk2:
      set pauseOnYoutube:false.
      Hello.
      -Where do I set this parameter? “set pauseOnYoutube:false”
      • T Offline
        teitlebot
        @Sean
        Is there anyway to have a Google home show its results on the magic mirror?
          [[global:former-user]] @teitlebot
          @teitlebot
          do you mean real google home? In other words, you have already a real google home, and you can command it by voice, and you want to display the result from your google home to MagicMirror. right?
          Sorry, it is not possible.
          If you make some specific command for your google Home through IFTTT or google Action, in that case, your result could be transferred to MagicMirror(and be shown).
          But the usual and random commands - like “What time is it?”, “My next schedule”,… couldn’t
          • T Offline
            teitlebot @Guest
            @Sean thanks for responding. I assume this is a limitation on Google ends? Also how would I tell ifttt to show on magic mirror?
              @teitlebot
              There are several posts in this forum. search “ifttt” and read them
                @teitlebot
                https://forum.magicmirror.builders/topic/10917/guide-control-mm-via-google-home
                • T Offline
                  teitlebot @Guest
                  @Sean thanks that looks awesome. Going to save it for a rainy day to install.
                  • W Offline
                    wellwhatever
                    Hello @Sean I’ve successfully rebuild the module but when I tried to activate it in the config, the module doesn’t load. The log says ‘No helper found for module: MMM-AssistantMk2’ (pretty sure the file is there inside the module folder). Have any idea whats the cause of this problem?
                    Thanks in advance!
                      [[global:former-user]] @wellwhatever
                      @wellwhatever
                      Never seen that kind. Loading node_helper.js is MM’s job itself. If there is the file, regardless it has some errors or not, MM should try to load that file. (And if it has an error, it would spit out the error)
                      • W Offline
                        wellwhatever @Guest
                          acimail01
                          How can I stop a video?
                          config is
                          youtubeAutoplay	: true,
                          pauseOnYoutube : false,
                          But it does not help.
                            [[global:former-user]] @acimail01
                            @acimail01
                            with these options, you can re activate hotword again, and then, the current YT player will stop and be hidden.
                            Anyway, I’ll remove YT related feature on next updates.
                            • K Offline
                              Keith
                              I’m trying to create a recipe that with a single command will hide “module A” and show “module B”. Another command will reverse this action. I can hide and show single modules or all modules but I can’t figure out hide one and show another. Any suggestions would be appreciated.
                              • T Offline
                                tanvir586
                                hi everyone,
                                how to get my YOUR_MODEL_ID. couldn’t find it any ware.
                                  [[global:former-user]] @Keith
                                  @Keith
                                  Almost same. :D
                                  command: {
                                    "HIDE_A_REVEAL_B": {
                                      moduleExec: {
                                        module: [], // For all modules,
                                        exec: (module, params, key) => {
                                          if (module.name == "MODULE_A") { // if module name is...
                                            module.hide()
                                          if (module.name == "MODULE_B") {
                                            module.show()
                                  Not tested code, but I believe you can catch the idea.
                                  K 2 Replies Last reply Reply Quote 0
                                    [[global:former-user]] @tanvir586
                                    @tanvir586
                                    Read this doc.
                                    https://developers.google.com/assistant/sdk/guides/service/python/embed/register-device
                                    • T Offline
                                      tanvir586
                                      Ive already registered. But now i can’t find the model id.
                                        @tanvir586
                                        T J 2 Replies Last reply Reply Quote 0
                                        • T Offline
                                          tanvir586 @Guest
                                          @Sean thanks for reply.
                                          My screen is like this.!0_1575303692872_Screenshot_20191202-162015_Samsung Internet.jpg
                                          I don’t have registration section.
                                            sdetweil @tanvir586
                                            @tanvir586 back a couple pages, you created an application, right?
                                            at https://console.actions.google.com/u/0/?pli=1
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 19 / 22
