    MMM-AssistantMk2
    421 Posts 61 Posters 779.4k Views 57 Watching
    • T
      tanvir586
      hi everyone,
      how to get my YOUR_MODEL_ID. couldn’t find it any ware.
        A Former User @Keith
        @Keith
        I can hide and show single modules or all modules but I can’t figure out hide one and show another
        Almost same. :D
        command: {
          "HIDE_A_REVEAL_B": {
            moduleExec: {
              module: [], // For all modules,
              exec: (module, params, key) => {
                if (module.name == "MODULE_A") { // if module name is...
                  module.hide()
                if (module.name == "MODULE_B") {
                  module.show()
        Not tested code, but I believe you can catch the idea.
        K 2 Replies Last reply Reply Quote 0
          A Former User @tanvir586
          @tanvir586
          Read this doc.
          https://developers.google.com/assistant/sdk/guides/service/python/embed/register-device
          • T
            tanvir586
            Ive already registered. But now i can’t find the model id.
              @tanvir586
              T J 2 Replies Last reply Reply Quote 0
              • T
                tanvir586 @Guest
                @Sean thanks for reply.
                My screen is like this.!0_1575303692872_Screenshot_20191202-162015_Samsung Internet.jpg
                I don’t have registration section.
                  sdetweil @tanvir586
                  @tanvir586 back a couple pages, you created an application, right?
                  at https://console.actions.google.com/u/0/?pli=1
                  • T
                    tanvir586
                    Sorry guys i think i didn’t register it.
                    I followed this video https://youtu.be/UBgH5hejYtM.
                    • K
                      Keith @Guest
                      @Sean I’ll give that a try and let you know. Thanks
                      • K
                        Keith @Guest
                        @Sean I got it working, thanks for your help. The code that worked for me is below
                        command: {
                              "HIDECALENDAR": {
                                  moduleExec: {
                                       module:()=>{
                              return []
                            }, // For all modules,
                                          if (module.name == "MMM-GooglePhotos") { // if module name is...
                                              module.show()
                                          if (module.name == "MMM-CalendarExt2") {
                                              module.hide()
                              "SHOWCALENDAR": {
                                  moduleExec: {
                                       module:()=>{
                              return []
                                              module.hide()
                                              module.show()
                        • T
                          tanvir586
                          Is it possible to make AssistantMk2 to show my ip camera feed? If i ask AssistantMk2 to show my front door, it says to select output display.
                            juantata
                              juantata
                              Good. I have a problem, it has started happening today.
                              magicmirror@2.8.0 start /home/pi/MagicMirror
                              sh run-start.sh
                              Starting MagicMirror: v2.8.0
                              Loading config …
                              Loading module helpers …
                              Module helper loaded: MMM-GoogleMapsTraffic
                              No helper found for module: MMM-YouTube.
                              No helper found for module: MMM-connection-status.
                              Module helper loaded: MMM-Remote-Control
                              Module helper loaded: MMM-Hotword
                              Module helper loaded: MMM-AssistantMk2
                              Module helper loaded: MMM-Spotify
                              All module helpers loaded.
                              Starting server on port 8080 …
                              You’re using a full whitelist configuration to allow for all IPs
                              Server started …
                              Connecting socket for: MMM-GoogleMapsTraffic
                              Starting node_helper for module: MMM-GoogleMapsTraffic
                              Starting module: newsfeed
                              Connecting socket for: MMM-Remote-Control
                              Starting node helper for: MMM-Remote-Control
                              Connecting socket for: MMM-Hotword
                              [HOTWORD] MMM-Hotword starts
                              Connecting socket for: MMM-AssistantMk2
                              Connecting socket for: MMM-Spotify
                              [SPOTIFY_AUTH] Token is fresh.
                              Sockets connected & modules started …
                              Launching application.
                              ERROR! Could not find main module js file for pir
                              Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/juanan+++ioiglesias21%40gmail.com/private-225241cce3b9ecf***011ef3193f0934/basic.ics - Interval: 300000
                              Working notification system. Notification: MMM-GOOGLE_MAPS_TRAFFIC-GET payload: { style: ‘standard’ }
                              Create new news fetcher for url: https://okdiario.com/feed - Interval: 300000
                              [AMK2] Recipe is loaded: hide_and_show_all_modules.js
                              [AMK2] Recipe is loaded: reboot.js
                              [AMK2] Recipe is loaded: recipe.template.js
                              [AMK2] Recipe is loaded: screen_onoff.js
                              [AMK2] Recipe is loaded: shutdown.js
                              [AMK2] Recipe is loaded: spotify.js
                              [AMK2] Temporal storage directory is clearing.
                              [HOTWORD] begins.
                              [HOTWORD] Detector starts listening.
                              [HOTWORD] stops.
                              [HOTWORD] Final Result: { detected: false }
                              [AMK2] assistant ready
                              [AMK2] Conversation starts.
                              [AMK2] Started with text query: brief today
                              { requestId: ‘5deab96c-0000-2e12-9cee-f403043d40d8’ } { profileFile: ‘default.json’, lang: ‘es-ES’ }
                              [AMK2] Device Action: { requestId: ‘5deab96c-0000-2e12-9cee-f403043d40d8’ }
                              [AMK2] Assistant Text Response:
                              [AMK2] Conversation Completed
                              [HOTWORD] begins.
                              [AMK2] Conversation Error: { Error: 14 UNAVAILABLE: Service unavailable.
                              at Object.exports.createStatusError (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/common.js:91:15)
                              at ClientDuplexStream._emitStatusIfDone (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js:233:26)
                              at ClientDuplexStream._receiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js:211:8)
                              at Object.onReceiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1306:15)
                              at InterceptingListener._callNext (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:568:42)
                              at InterceptingListener.onReceiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:618:8)
                              at /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1123:18
                              code: 14,
                              metadata:
                              Metadata { _internal_repr: { ‘content-disposition’: [Array] }, flags: 0 },
                              details: ‘Service unavailable.’ }
                              [HOTWORD] begins.
                              code: 14,
                              metadata:
                              [HOTWORD] begins.
                              ^C
                                juantata @Guest
                                @Sean
                                Today’s summary works perfectly, but then the microphone does not listen and therefore there is no conversation.
                                sh run-start.sh
                                Loading config …
                                Server started …
                                [HOTWORD] begins.
                                [HOTWORD] stops.
                                [HOTWORD] begins.
                                code: 14,
                                metadata:
                                [HOTWORD] begins.
                                code: 14,
                                metadata:
                                [HOTWORD] begins.
                                ^C
                                  A Former User @juantata
                                  @juantata
                                  Just remove useWelcomeMessage. That feature needs more configuration when using together MMM-Hotword. Not difficult but if you don’t understand what’s going on, just remove it.
                                    juantata @Guest
                                    @Sean
                                    Thanks for the reply. But one question, if there has never been a problem with the daily summary, why now?
                                      @juantata
                                      Just random.
                                      When using useWelcomMessage, MMM-Hotword’s Mic should be closed. But by physical limitation, Sometimes MMM-Hotword’s mic was not completely closed when MMM-AssistantMk2 activation started. It’s not unpredictable. On the next version, it will be solved.
                                        juantata @Guest
                                        @Sean
                                        Hi. Thanks for the reply, but I still have the same error
                                          juantata @Guest
                                          @Sean
                                          Hi. Sorry for the insistence. I also show you the MMM-Hotword
                                            @juantata
                                            What are you using as Mic? That error happens when your mic is not working properly.
                                            Show me the result of arecord -l. Did you something on ALSA setup?
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 19 / 22
