    MMM-AssistantMk2
    421 Posts 61 Posters 581.2k Views 57 Watching
    • ? Offline
      A Former User @Cr4z33
      @cr4z33
      Try this.
        module: "MMM-AssistantMk2",
          record: {
            recordProgram: "arecord",
            device: null        // or device: "hw:0,0"
          play: {
            playProgram: "mpg321",
      • citizendevpiC Offline
        citizendevpi @Guest
        @sean sweet i added a bunch of outher modules and now get a memory error how do i update to the newer version so hopefully these errors sort themselvs out
          citizendevpi
          !!! { audioFormat: 1,
          endianness: ‘LE’,
          channels: 1,
          sampleRate: 16000,
          byteRate: 32000,
          blockAlign: 2,
          bitDepth: 16,
          signed: true }
          mmap() failed: Cannot allocate memory
          Failed to create permanent mapping for memfd region with ID = 3246537711
          Ignoring received block reference with non-registered memfd ID = 3246537711
          ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Protocol error
          […/deps/mpg123/src/output/alsa.c:165] error: cannot open device default
          Error: open() failed: -1
          at Speaker._open (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:106:13)
          at Speaker._write (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:183:23)
          at doWrite (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:428:64)
          at writeOrBuffer (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:417:5)
          at Speaker.Writable.write (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:334:11)
          at Reader. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:287:17)
          at emitNone (events.js:111:20)
          at Reader.emit (events.js:208:7)
          at /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/wav/node_modules/readable-stream/lib/_stream_readable.js:934:16
          at _combinedTickCallback (internal/process/next_tick.js:131:7)
          Some error happens. Try again.
          Whoops! There was an uncaught exception…
          TypeError: this.sendSocketNotification is not a function
          at Reader. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:296:20)
          at process._tickCallback (internal/process/next_tick.js:180:9)
          ya looks like speaker error
          • Cr4z33C Offline
            Cr4z33 @Guest
            @Sean
            If I use null I get a black MMM screen.
            If I use hw:0,0 I get the config.js message.
            Finally if I use "hw:0,0" (with quotes) I get a black MM screen again.
            :smiling_face_with_open_mouth_cold_sweat:
            • ? Offline
              @cr4z33
              Ok… Are you using Telegram?
              I can give more direct help on Telegram. My id is @eouia.
              Here is not so good place to talk these things.
              • Cr4z33C Offline
                Cr4z33 @Guest
                @Sean
                Yep adding you right now. :)
                  citizendevpi
                  so i updated and did not change config (yet) no vidieo or pics are showing up
                  • ? Offline
                    A Former User @citizendevpi
                    @citizendevpi
                    :) You can also talk on Telegram. I prefer that then talking here. :)
                    • Cr4z33C Offline
                      Cr4z33 @Cr4z33
                      I want to thank @Sean publicly for having helped me privately into solving the issue! :clapping_hands_medium-light_skin_tone: :thumbs_up_medium-light_skin_tone:
                        citizendevpi
                        i cannot get hotword to detect any sound ?
                        • 14
                        • 15
                        • 16
                        • 17
                        • 18
                        • 42
                        • 43
                        • 16 / 43
