    MMM-AssistantMk2
    421 Posts 61 Posters 761.7k Views 57 Watching
      smarthome @smarthome
      And other question is, if I ask a command that Google can not find the suitable answer, there’s no response while google home speaker give a promise answer? Is there any configure to do that?
        A Former User @smarthome
        @smarthome
        Can we make a command exec to mpg21 to stop blayback google response?
        Ideally, might be possible. But not only playing sound is the issue related. So, currently not so easy.
        Currently, No.
        Anyway, I’m building a new updates. It might have possibility of solving your issue. I’m planning to remove dependencies about sound out. It might become more controllable about voice response.
        But due to my vacation, and new RPI4, Raspiban Buster and other many things which I should concern besides make its release somewhat lately. sorry.
          smarthome @Guest
            smarthome @Guest
            @Sean
            How can I remove “Repeat after me” whenever ask ASSISTANT _SAY to speech text?
              @smarthome Impossible. ASSISTANT_SAY is not perfect solution to make mirror saying something. At any time it could be changed by Google how it works. When I implement that feature at first time, there is no additional “Repeat after me” spoken phrase, but Google changed it’s working way. So I didn’t recommend using it. Use real TTS solution to make your mirror say something.
                smarthome @Guest
                @Sean
                I’ also active billing account to enable Google Cloud text to Speech API to use your MMM Google-TTS Module
                But, this can not speak my local language (Vietnamese) like ASSISTANT_SAY can
                How to do that?
                  @smarthome
                  Sorry, Vietnamese is not supported (https://cloud.google.com/text-to-speech/docs/voices)
                    smarthome @Guest
                    @Sean
                    After your answer, I’m looking for google cloud amd find out the way to make it support, hi
                    Not only Vietnamese language, a wide range of local language, like assistant language
                    That’ now MMM Google TTS work ok with vietnamese language
                    Tks!
                    • T Offline
                      t.architecture99
                      How can google TTS respond to the answers I have prepared? eg :
                      • “smart mirror, I want to drink something.” - Me
                      • “This is your drink.” - Smart mirror answers.
                        So how to do that?
                        I have successfully installed the api and modules, but i dont know how…
                        Sorry i am newbie
                        A Former User @t.architecture99
                        @t-architecture99
                        Recommending beverage is not the job of this module.
                        But if you have MMM-RecommendDrinks (Of course, currently it exists not), You can make an order of I want to drink something to MMM-AssistantMk2 then, AMK2 would transfer your order to that RD module, and RD can RESPONSE with voice via TTS module.
                        So, that feature is for developers not for end-users directly.
                        • T Offline
                          t.architecture99 @Guest
                          @Sean i mean i want to set default question and answers with voice response (using google TTS. I dont know how to command to create . :(
                            @t-architecture99
                            By default, If the response could be handled by Assistant itself, it can response with voice. (e.g : “How’s the weather today?” - “It’s rainy blah blah…”)
                            So what is your default question? hmmm… It’s better to tell me “YOUR REAL INTENTION or SCENARIO” - what you want.
                            In case that you need some extended response from MM & modules
                            By example,
                            • if you want to get a response “Yes, sir!” when you order “Shut down now” (by your custom command),
                              • Use custom action instead transcriptionHook on making a command. custom action can handle a simple static voice response.(around 150 words)
                            • But more complex dynamic conversation like - “Read me first article of news module” then “New york times said blah blah…”
                              • You should modify news module to speak somethings, and at that time TTS solution be needed.
                              • And the role of AMK2 is just sending “Read first article” order to news module. That is the way how it works.
                            • E Offline
                              EstoyMejor
                              Hello guys, i hope someone can help me here. I found several people with the same problem but all got fixed by the Troubleshooting in the README, mine doesnt (or maybe i did something wrong?!)
                              My problem is this error:
                              Error: Failed to load gRPC binary module because it was not installed for the current system
                              Expected directory: electron-v3.1-linux-arm-glibc
                              Found: [node-v72-linux-arm-glibc]
                              Full start sequence log:
                              pi@InfoDisplayPi:~/MagicMirror $ npm start
                              > magicmirror@2.8.0 start /home/pi/MagicMirror
                              > sh run-start.sh
                              Starting MagicMirror: v2.8.0
                              Loading config ...
                              Loading module helpers ...
                              WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
                              This problem can often be fixed by running "npm rebuild" on the current system
                              Original error: Cannot find module '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v3.1-linux-arm-glibc/grpc_node.node'
                              App threw an error during load
                                  at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:53:17)
                                  at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:64:3)
                                  at Module._compile (internal/modules/cjs/loader.js:711:30)
                                  at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
                                  at Module.load (internal/modules/cjs/loader.js:620:32)
                                  at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
                                  at Function.Module._load (internal/modules/cjs/loader.js:551:3)
                                  at Module.require (internal/modules/cjs/loader.js:658:17)
                                  at require (internal/modules/cjs/helpers.js:20:18)
                                  at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:144:12)
                              { Error: Failed to load gRPC binary module because it was not installed for the current system
                                  at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:144:12) code: 'MODULE_NOT_FOUND' }
                              Launching application.
                              Shutting down server...
                              Stopping module helper: updatenotification
                              Stopping module helper: calendar
                              Stopping module helper: newsfeed
                              I Feel like i just oversee something really easy here…
                                A Former User @EstoyMejor
                                @EstoyMejor
                                Your electron-rebuild was failed on installation.
                                If your gcc version is 8, downgrade to 7 and reinstall again.
                                • W Offline
                                  witty11
                                  hello Guy, i would like to ask you about mmm GAction Register ,i have to do that when i installed MMM assistantmk2 does i need to do it again or skip to step scp ~/Downloads/client_secret_client-id.json pi@raspberry-pi-ip-address:/home/pi/
                                    A Former User @witty11
                                    @witty11
                                    Hmmm…? I don’t think you need that step. Where did you read that step is needed? Are you following https://github.com/eouia/MMM-AssistantMk2/wiki/gAction?
                                    • Z Offline
                                      Zoltan
                                      Hi all
                                      I would like to activate one of the GPIO pins the moment Hotword/Assistant listen and/or speaks. The idea is to switch a relay to lit up two LED strips at the back of the mirror. It should be easy using the recipes but my knowledge is very limited when it comes to this. Any one out there that has done it or can point me in the right direction
                                        A Former User @Zoltan
                                        @Zoltan
                                        Have you already some external program or script to turn on/off LED strips?
                                        Z 1 Reply Last reply Reply Quote 0
                                        • Z Offline
                                          Zoltan @Guest
                                          @Sean
                                          Hi Sean
                                          I only have ideas that i have seen on other sites where Google home has been installed on a Raspberry. There is a file In the link below at Step 7 that one might used as an idea on how to manage it. Not sure if i am allowed to post links to other sites other than Github and this forum?
                                          https://medium.com/@kevalpatel2106/turn-your-raspberry-pi-into-homemade-google-home-9e29ad220075
                                          And then there is also in the middle of the following page a way of doing it with a heading
                                          “Bonus: Voice Activated GPIO”
                                          https://www.makeuseof.com/tag/diy-google-home-assistant-raspberry-pi/
                                          My slate is clean other than this :-(
                                          ? 1 Reply Last reply Reply Quote -1
                                            @Zoltan
                                            To say clear, the job of MMM-AssistantMk2 is understanding your vocal phrase. Turning on/off GPIO thing is others job. If you have or find program/script/command or module which can turn on/off GPIO, MMM-ASSITANTMK2 can translate your vocal phrase to execution trigger for them. So you’d better find one at first.
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 21
                                            • 22
                                            • 16 / 22
