MagicMirror² v2.14.0 is available! For more information about this release, check out this topic.
MMM-AssistantMk2 problems 'npm install'
speaker can not be installed.
odroid@odroid:~/MagicMirror/modules/MMM-AssistantMk2$ npm install > grpc@1.14.0 install /home/odroid/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc > node-pre-gyp install --fallback-to-build --library=static_library node-pre-gyp WARN Using request for node-pre-gyp https download [grpc] Success: "/home/odroid/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/node-v57-linux-arm-glibc/grpc_node.node" is installed via remote > speaker@0.4.1 install /home/odroid/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker > node-gyp rebuild make: 디렉터리 '/home/odroid/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/build' 들어감 CC(target) Release/obj.target/output/deps/mpg123/src/output/alsa.o ../deps/mpg123/src/output/alsa.c: In function ‘rates_match’: ../deps/mpg123/src/output/alsa.c:53:22: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] return actual * 100 > desired * (100 - AUDIO_RATE_TOLERANCE) && ^ ../deps/mpg123/src/output/alsa.c:54:22: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] actual * 100 < desired * (100 + AUDIO_RATE_TOLERANCE); ^ ../deps/mpg123/src/output/alsa.c: In function ‘initialize_device’: ../deps/mpg123/src/output/alsa.c:78:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] for (i = 0; i < NUM_FORMATS; ++i) { ^ ../deps/mpg123/src/output/alsa.c: In function ‘get_formats_alsa’: ../deps/mpg123/src/output/alsa.c:201:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] for (i = 0; i < NUM_FORMATS; ++i) { ^ AR(target) Release/obj.target/deps/mpg123/liboutput.a COPY Release/liboutput.a CXX(target) Release/obj.target/binding/src/binding.o ../src/binding.cc: In function ‘void {anonymous}::write_after(uv_work_t*)’: ../src/binding.cc:86:31: warning: ‘v8::Local Nan::Callback::Call(int, v8::Local*) const’ is deprecated [-Wdeprecated-declarations] wreq->callback->Call(1, argv); ^ In file included from ../src/node_pointer.h:6:0, from ../src/binding.cc:5: ../../nan/nan.h:1618:3: note: declared here Call(int argc, v8::Local argv[]) const { ^~~~ ../src/binding.cc: In function ‘void {anonymous}::Initialize(v8::Handle)’: ../src/binding.cc:113:8: warning: ‘Nan::Maybe Nan::ForceSet(v8::Local, v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated [-Wdeprecated-declarations] Nan::ForceSet(target, ^~~~~~~~ In file included from ../../nan/nan.h:197:0, from ../src/node_pointer.h:6, from ../src/binding.cc:5: ../../nan/nan_maybe_43_inl.h:130:35: note: declared here NAN_DEPRECATED inline Maybe ForceSet( ^~~~~~~~ ../src/binding.cc:115:64: warning: ‘Nan::Maybe Nan::ForceSet(v8::Local, v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated [-Wdeprecated-declarations] Nan::New(mpg123_output_module_info.api_version)); ^ In file included from ../../nan/nan.h:197:0, from ../src/node_pointer.h:6, from ../src/binding.cc:5: ../../nan/nan_maybe_43_inl.h:130:35: note: declared here NAN_DEPRECATED inline Maybe ForceSet( ^~~~~~~~ ../src/binding.cc:116:8: warning: ‘Nan::Maybe Nan::ForceSet(v8::Local, v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated [-Wdeprecated-declarations] Nan::ForceSet(target, ^~~~~~~~ In file included from ../../nan/nan.h:197:0, from ../src/node_pointer.h:6, from ../src/binding.cc:5: ../../nan/nan_maybe_43_inl.h:130:35: note: declared here NAN_DEPRECATED inline Maybe ForceSet( ^~~~~~~~ ../src/binding.cc:118:74: warning: ‘Nan::Maybe Nan::ForceSet(v8::Local, v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated [-Wdeprecated-declarations] Nan::New(mpg123_output_module_info.name).ToLocalChecked()); ^ In file included from ../../nan/nan.h:197:0, from ../src/node_pointer.h:6, from ../src/binding.cc:5: ../../nan/nan_maybe_43_inl.h:130:35: note: declared here NAN_DEPRECATED inline Maybe ForceSet( ^~~~~~~~ ../src/binding.cc:119:8: warning: ‘Nan::Maybe Nan::ForceSet(v8::Local, v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated [-Wdeprecated-declarations] Nan::ForceSet(target, ^~~~~~~~ In file included from ../../nan/nan.h:197:0, from ../src/node_pointer.h:6, from ../src/binding.cc:5: ../../nan/nan_maybe_43_inl.h:130:35: note: declared here NAN_DEPRECATED inline Maybe ForceSet( ^~~~~~~~ ../src/binding.cc:121:81: warning: ‘Nan::Maybe Nan::ForceSet(v8::Local, v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated [-Wdeprecated-declarations] Nan::New(mpg123_output_module_info.description).ToLocalChecked()); ^ In file included from ../../nan/nan.h:197:0, from ../src/node_pointer.h:6, from ../src/binding.cc:5: ../../nan/nan_maybe_43_inl.h:130:35: note: declared here NAN_DEPRECATED inline Maybe ForceSet( ^~~~~~~~ ../src/binding.cc:122:8: warning: ‘Nan::Maybe Nan::ForceSet(v8::Local, v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated [-Wdeprecated-declarations] Nan::ForceSet(target, ^~~~~~~~ In file included from ../../nan/nan.h:197:0, from ../src/node_pointer.h:6, from ../src/binding.cc:5: ../../nan/nan_maybe_43_inl.h:130:35: note: declared here NAN_DEPRECATED inline Maybe ForceSet( ^~~~~~~~ ../src/binding.cc:124:78: warning: ‘Nan::Maybe Nan::ForceSet(v8::Local, v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated [-Wdeprecated-declarations] Nan::New(mpg123_output_module_info.revision).ToLocalChecked()); ^ In file included from ../../nan/nan.h:197:0, from ../src/node_pointer.h:6, from ../src/binding.cc:5: ../../nan/nan_maybe_43_inl.h:130:35: note: declared here NAN_DEPRECATED inline Maybe ForceSet( ^~~~~~~~ ../src/binding.cc:133:8: warning: ‘Nan::Maybe Nan::ForceSet(v8::Local, v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated [-Wdeprecated-declarations] Nan::ForceSet(target, Nan::New("formats").ToLocalChecked(), Nan::New(ao.get_formats(&ao))); ^~~~~~~~ In file included from ../../nan/nan.h:197:0, from ../src/node_pointer.h:6, from ../src/binding.cc:5: ../../nan/nan_maybe_43_inl.h:130:35: note: declared here NAN_DEPRECATED inline Maybe ForceSet( ^~~~~~~~ ../src/binding.cc:133:92: warning: ‘Nan::Maybe Nan::ForceSet(v8::Local, v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated [-Wdeprecated-declarations] Nan::ForceSet(target, Nan::New("formats").ToLocalChecked(), Nan::New(ao.get_formats(&ao))); ^ In file included from ../../nan/nan.h:197:0, from ../src/node_pointer.h:6, from ../src/binding.cc:5: ../../nan/nan_maybe_43_inl.h:130:35: note: declared here NAN_DEPRECATED inline Maybe ForceSet( ^~~~~~~~ ../src/binding.cc:140:8: warning: ‘Nan::Maybe Nan::ForceSet(v8::Local, v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated [-Wdeprecated-declarations] Nan::ForceSet(target, Nan::New(#value).ToLocalChecked(), Nan::New(value), \ ^ ../src/binding.cc:143:3: note: in expansion of macro ‘CONST_INT’ CONST_INT(MPG123_ENC_FLOAT_32); ^~~~~~~~~ In file included from ../../nan/nan.h:197:0, from ../src/node_pointer.h:6, from ../src/binding.cc:5: ../../nan/nan_maybe_43_inl.h:130:35: note: declared here NAN_DEPRECATED inline Maybe ForceSet( ^~~~~~~~ ../src/binding.cc:141:58: warning: ‘Nan::Maybe Nan::ForceSet(v8::Local, v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated [-Wdeprecated-declarations] static_cast(ReadOnly|DontDelete)); ^ ../src/binding.cc:143:3: note: in expansion of macro ‘CONST_INT’ CONST_INT(MPG123_ENC_FLOAT_32); ^~~~~~~~~ In file included from ../../nan/nan.h:197:0, from ../src/node_pointer.h:6, from ../src/binding.cc:5: ../../nan/nan_maybe_43_inl.h:130:35: note: declared here NAN_DEPRECATED inline Maybe ForceSet( ^~~~~~~~ ../src/binding.cc:140:8: warning: ‘Nan::Maybe Nan::ForceSet(v8::Local, v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated [-Wdeprecated-declarations] Nan::ForceSet(target, Nan::New(#value).ToLocalChecked(), Nan::New(value), \ ^ ../src/binding.cc:144:3: note: in expansion of macro ‘CONST_INT’ CONST_INT(MPG123_ENC_FLOAT_64); ^~~~~~~~~ In file included from ../../nan/nan.h:197:0, from ../src/node_pointer.h:6, from ../src/binding.cc:5: ../../nan/nan_maybe_43_inl.h:130:35: note: declared here NAN_DEPRECATED inline Maybe ForceSet( ^~~~~~~~ ../src/binding.cc:141:58: warning: ‘Nan::Maybe Nan::ForceSet(v8::Local, v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated [-Wdeprecated-declarations] static_cast(ReadOnly|DontDelete)); ^ ../src/binding.cc:144:3: note: in expansion of macro ‘CONST_INT’ CONST_INT(MPG123_ENC_FLOAT_64); ^~~~~~~~~ In file included from ../../nan/nan.h:197:0, from ../src/node_pointer.h:6, from ../src/binding.cc:5: ../../nan/nan_maybe_43_inl.h:130:35: note: declared here NAN_DEPRECATED inline Maybe ForceSet( ^~~~~~~~ ../src/binding.cc:140:8: warning: ‘Nan::Maybe Nan::ForceSet(v8::Local, v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated [-Wdeprecated-declarations] Nan::ForceSet(target, Nan::New(#value).ToLocalChecked(), Nan::New(value), \ ^ ../src/binding.cc:145:3: note: in expansion of macro ‘CONST_INT’ CONST_INT(MPG123_ENC_SIGNED_8); ^~~~~~~~~ In file included from ../../nan/nan.h:197:0, from ../src/node_pointer.h:6, from ../src/binding.cc:5: ../../nan/nan_maybe_43_inl.h:130:35: note: declared here NAN_DEPRECATED inline Maybe ForceSet( ^~~~~~~~ ../src/binding.cc:141:58: warning: ‘Nan::Maybe Nan::ForceSet(v8::Local, v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated [-Wdeprecated-declarations] static_cast(ReadOnly|DontDelete)); ^ ../src/binding.cc:145:3: note: in expansion of macro ‘CONST_INT’ CONST_INT(MPG123_ENC_SIGNED_8); ^~~~~~~~~ In file included from ../../nan/nan.h:197:0, from ../src/node_pointer.h:6, from ../src/binding.cc:5: ../../nan/nan_maybe_43_inl.h:130:35: note: declared here NAN_DEPRECATED inline Maybe ForceSet( ^~~~~~~~ ../src/binding.cc:140:8: warning: ‘Nan::Maybe Nan::ForceSet(v8::Local, v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated [-Wdeprecated-declarations] Nan::ForceSet(target, Nan::New(#value).ToLocalChecked(), Nan::New(value), \ ^ ../src/binding.cc:146:3: note: in expansion of macro ‘CONST_INT’ CONST_INT(MPG123_ENC_UNSIGNED_8); ^~~~~~~~~ In file included from ../../nan/nan.h:197:0, from ../src/node_pointer.h:6, from ../src/binding.cc:5: ../../nan/nan_maybe_43_inl.h:130:35: note: declared here NAN_DEPRECATED inline Maybe ForceSet( ^~~~~~~~ ../src/binding.cc:141:58: warning: ‘Nan::Maybe Nan::ForceSet(v8::Local, v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated [-Wdeprecated-declarations] static_cast(ReadOnly|DontDelete)); ^ ../src/binding.cc:146:3: note: in expansion of macro ‘CONST_INT’ CONST_INT(MPG123_ENC_UNSIGNED_8); ^~~~~~~~~ In file included from ../../nan/nan.h:197:0, from ../src/node_pointer.h:6, from ../src/binding.cc:5: ../../nan/nan_maybe_43_inl.h:130:35: note: declared here NAN_DEPRECATED inline Maybe ForceSet( ^~~~~~~~ ../src/binding.cc:140:8: warning: ‘Nan::Maybe Nan::ForceSet(v8::Local, v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated [-Wdeprecated-declarations] Nan::ForceSet(target, Nan::New(#value).ToLocalChecked(), Nan::New(value), \ ^ ../src/binding.cc:147:3: note: in expansion of macro ‘CONST_INT’ CONST_INT(MPG123_ENC_SIGNED_16); ^~~~~~~~~ In file included from ../../nan/nan.h:197:0, from ../src/node_pointer.h:6, from ../src/binding.cc:5: ../../nan/nan_maybe_43_inl.h:130:35: note: declared here NAN_DEPRECATED inline Maybe ForceSet( ^~~~~~~~ ../src/binding.cc:141:58: warning: ‘Nan::Maybe Nan::ForceSet(v8::Local, v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated [-Wdeprecated-declarations] static_cast(ReadOnly|DontDelete)); ^ ../src/binding.cc:147:3: note: in expansion of macro ‘CONST_INT’ CONST_INT(MPG123_ENC_SIGNED_16); ^~~~~~~~~ In file included from ../../nan/nan.h:197:0, from ../src/node_pointer.h:6, from ../src/binding.cc:5: ../../nan/nan_maybe_43_inl.h:130:35: note: declared here NAN_DEPRECATED inline Maybe ForceSet( ^~~~~~~~ ../src/binding.cc:140:8: warning: ‘Nan::Maybe Nan::ForceSet(v8::Local, v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated [-Wdeprecated-declarations] Nan::ForceSet(target, Nan::New(#value).ToLocalChecked(), Nan::New(value), \ ^ ../src/binding.cc:148:3: note: in expansion of macro ‘CONST_INT’ CONST_INT(MPG123_ENC_UNSIGNED_16); ^~~~~~~~~ In file included from ../../nan/nan.h:197:0, from ../src/node_pointer.h:6, from ../src/binding.cc:5: ../../nan/nan_maybe_43_inl.h:130:35: note: declared here NAN_DEPRECATED inline Maybe ForceSet( ^~~~~~~~ ../src/binding.cc:141:58: warning: ‘Nan::Maybe Nan::ForceSet(v8::Local, v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated [-Wdeprecated-declarations] static_cast(ReadOnly|DontDelete)); ^ ../src/binding.cc:148:3: note: in expansion of macro ‘CONST_INT’ CONST_INT(MPG123_ENC_UNSIGNED_16); ^~~~~~~~~ In file included from ../../nan/nan.h:197:0, from ../src/node_pointer.h:6, from ../src/binding.cc:5: ../../nan/nan_maybe_43_inl.h:130:35: note: declared here NAN_DEPRECATED inline Maybe ForceSet( ^~~~~~~~ ../src/binding.cc:140:8: warning: ‘Nan::Maybe Nan::ForceSet(v8::Local, v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated [-Wdeprecated-declarations] Nan::ForceSet(target, Nan::New(#value).ToLocalChecked(), Nan::New(value), \ ^ ../src/binding.cc:149:3: note: in expansion of macro ‘CONST_INT’ CONST_INT(MPG123_ENC_SIGNED_24); ^~~~~~~~~ In file included from ../../nan/nan.h:197:0, from ../src/node_pointer.h:6, from ../src/binding.cc:5: ../../nan/nan_maybe_43_inl.h:130:35: note: declared here NAN_DEPRECATED inline Maybe ForceSet( ^~~~~~~~ ../src/binding.cc:141:58: warning: ‘Nan::Maybe Nan::ForceSet(v8::Local, v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated [-Wdeprecated-declarations] static_cast(ReadOnly|DontDelete)); ^ ../src/binding.cc:149:3: note: in expansion of macro ‘CONST_INT’ CONST_INT(MPG123_ENC_SIGNED_24); ^~~~~~~~~ In file included from ../../nan/nan.h:197:0, from ../src/node_pointer.h:6, from ../src/binding.cc:5: ../../nan/nan_maybe_43_inl.h:130:35: note: declared here NAN_DEPRECATED inline Maybe ForceSet( ^~~~~~~~ ../src/binding.cc:140:8: warning: ‘Nan::Maybe Nan::ForceSet(v8::Local, v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated [-Wdeprecated-declarations] Nan::ForceSet(target, Nan::New(#value).ToLocalChecked(), Nan::New(value), \ ^ ../src/binding.cc:150:3: note: in expansion of macro ‘CONST_INT’ CONST_INT(MPG123_ENC_UNSIGNED_24); ^~~~~~~~~ In file included from ../../nan/nan.h:197:0, from ../src/node_pointer.h:6, from ../src/binding.cc:5: ../../nan/nan_maybe_43_inl.h:130:35: note: declared here NAN_DEPRECATED inline Maybe ForceSet( ^~~~~~~~ ../src/binding.cc:141:58: warning: ‘Nan::Maybe Nan::ForceSet(v8::Local, v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated [-Wdeprecated-declarations] static_cast(ReadOnly|DontDelete)); ^ ../src/binding.cc:150:3: note: in expansion of macro ‘CONST_INT’ CONST_INT(MPG123_ENC_UNSIGNED_24); ^~~~~~~~~ In file included from ../../nan/nan.h:197:0, from ../src/node_pointer.h:6, from ../src/binding.cc:5: ../../nan/nan_maybe_43_inl.h:130:35: note: declared here NAN_DEPRECATED inline Maybe ForceSet( ^~~~~~~~ ../src/binding.cc:140:8: warning: ‘Nan::Maybe Nan::ForceSet(v8::Local, v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated [-Wdeprecated-declarations] Nan::ForceSet(target, Nan::New(#value).ToLocalChecked(), Nan::New(value), \ ^ ../src/binding.cc:151:3: note: in expansion of macro ‘CONST_INT’ CONST_INT(MPG123_ENC_SIGNED_32); ^~~~~~~~~ In file included from ../../nan/nan.h:197:0, from ../src/node_pointer.h:6, from ../src/binding.cc:5: ../../nan/nan_maybe_43_inl.h:130:35: note: declared here NAN_DEPRECATED inline Maybe ForceSet( ^~~~~~~~ ../src/binding.cc:141:58: warning: ‘Nan::Maybe Nan::ForceSet(v8::Local, v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated [-Wdeprecated-declarations] static_cast(ReadOnly|DontDelete)); ^ ../src/binding.cc:151:3: note: in expansion of macro ‘CONST_INT’ CONST_INT(MPG123_ENC_SIGNED_32); ^~~~~~~~~ In file included from ../../nan/nan.h:197:0, from ../src/node_pointer.h:6, from ../src/binding.cc:5: ../../nan/nan_maybe_43_inl.h:130:35: note: declared here NAN_DEPRECATED inline Maybe ForceSet( ^~~~~~~~ ../src/binding.cc:140:8: warning: ‘Nan::Maybe Nan::ForceSet(v8::Local, v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated [-Wdeprecated-declarations] Nan::ForceSet(target, Nan::New(#value).ToLocalChecked(), Nan::New(value), \ ^ ../src/binding.cc:152:3: note: in expansion of macro ‘CONST_INT’ CONST_INT(MPG123_ENC_UNSIGNED_32); ^~~~~~~~~ In file included from ../../nan/nan.h:197:0, from ../src/node_pointer.h:6, from ../src/binding.cc:5: ../../nan/nan_maybe_43_inl.h:130:35: note: declared here NAN_DEPRECATED inline Maybe ForceSet( ^~~~~~~~ ../src/binding.cc:141:58: warning: ‘Nan::Maybe Nan::ForceSet(v8::Local, v8::Local, v8::Local, v8::PropertyAttribute)’ is deprecated [-Wdeprecated-declarations] static_cast(ReadOnly|DontDelete)); ^ ../src/binding.cc:152:3: note: in expansion of macro ‘CONST_INT’ CONST_INT(MPG123_ENC_UNSIGNED_32); ^~~~~~~~~ In file included from ../../nan/nan.h:197:0, from ../src/node_pointer.h:6, from ../src/binding.cc:5: ../../nan/nan_maybe_43_inl.h:130:35: note: declared here NAN_DEPRECATED inline Maybe ForceSet( ^~~~~~~~ SOLINK_MODULE(target) Release/obj.target/binding.node COPY Release/binding.node make: 디렉터리 '/home/odroid/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/build' 나감 > protobufjs@6.8.8 postinstall /home/odroid/MagicMirror/modules/MMM-AssistantMk2/node_modules/protobufjs > node scripts/postinstall npm WARN MMM-AssistantMk2@1.0.1 No repository field. added 276 packages from 177 contributors and audited 648 packages in 26.488s found 0 vulnerabilities odroid@odroid:~/MagicMirror/modules/MMM-AssistantMk2$
@wireshark
As I know, those are not error-messages.
However, you should rebuid some binaries to match electron version.cd ~/MagicMirror/modules/MMM-AssistantMk2 npm install --save-dev electron-rebuild ./node_modules/.bin/electron-rebuild
