MMM-Pages not able to get it to be consistent all modules on page one
Hello All
Looking for some help I have an issue with Pages that I have been fighting for three days now.
First I’m new to MagicMirror.
I have dad some experience with Raspberry Pi before but not to much.
Running a Raspberry Pi 2 B
MagicMirror 2.4.1The issue is Pages is putting ever thing on the first page and neve switching.
If I get Pages to work like I have it in the config file it will only stay that way for that session.
I still developing the system so I’m shutting down the Pi at night.
If I have it working and shut down the system and restart Pages will work.
But if I shut down the system for overnight then the next day it will be confused again
And all the modules are on the first page again.I have looked at the log file and don’t see anything out of place that I know of.
Here is my config.js file.Any help would be outstanding and thank you.
var config = { address: "0.0.0.0", // Address to listen on, can be: // - "localhost", "127.0.0.1", "::1" to listen on loopback interface // - another specific IPv4/6 to listen on a specific interface // - "", "0.0.0.0", "::" to listen on any interface // Default, when address config is left out, is "localhost" port: 8080, ipWhitelist: [], // Set [] to allow all IP addresses was "127.0.0.1", "::ffff:127.0.0.1", "::1","::ffff:10.19.57.64/26" // or add a specific IPv4 of 192.168.1.5 : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"], // or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"], language: "en", timeFormat: 12, units: "imperial", modules: [ { module: "alert", }, { module: "updatenotification", position: "top_bar" }, { module: 'MMM-pages', config: { modules: [["calendar","weatherforecast","newsfeed"], ["MMM-NOAA","MMM-PushBulletNotifications","MMM-SystemStats","mmm-systemtemperature","MMM-NetworkConnection"], ["calendar"]], excludes: ["clock","currentweather","compliments","MMM-page-indicator"], animationTime: 8000, rotationTime: 20000 } }, { module: "clock", position: "top_left" }, { module: 'MMM-SystemStats', position: 'top_left', // This can be any of the regions. classes: 'small dimmed', // Add your own styling. Optional. config: { updateInterval: 10000, animationSpeed: 0, align: 'right', // align labels //header: 'System Stats', // This is optional } }, { module: 'mmm-systemtemperature', position: 'top_left', // This can be any of the regions. classes: 'small dimmed', // Add your own styling. Optional. config: { // See 'Configuration options' for more information. } }, { module: "calendar", header: "US Holidays", position: "top_left", config: { calendars: [ { symbol: "calendar-check-o ", url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics" } ] } }, { module: 'MMM-PushBulletNotifications', header: 'Notifications', position: 'top_left', // This can be any of the regions. config: { // See 'Configuration options' for more information. accessToken: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx", //PushBullet API Access Token numberOfNotifications: 3, filterTargetDeviceName: "", showPushesSentToAllDevices: true, onlyAllowCommandsFromSourceDevices: [], fetchLimitPushBullet: 50, showPushes: true, showPushesOnLoad: true, showDismissedPushes: true, showMirroredNotifications: true, showSMS: true, showMessage: true, showIcons: true, showDateTime: true, localesDateTime: 'nl-NL', playSoundOnNotificationReceived: true, soundFile: 'modules/MMM-PushBulletNotifications/sounds/new-message.mp3', maxMsgCharacters: 70, maxHeaderCharacters: 22, showModuleIfNoNotifications: true, noNotificationsMessage: "No new notifications", debugMode: false, } }, { module: "currentweather", position: "top_right", config: { location: "Newport,US", locationID: "4143871", //ID from http://www.openweathermap.org/help/city_list.txt appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx", showHumidity: true } }, { module: "weatherforecast", position: "top_right", header: "Weather Forecast", config: { location: "", locationID: "4141363", //ID from http://www.openweathermap.org/help/city_list.txt appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx", showRainAmount: true, colored: true } }, { module: 'MMM-NOAA', position: "top_right", config: { apiKey: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx", // https://www.wunderground.com/weather/api select the middle plan... airKey: "xxxxxxxxxxxxxxxx" // IF you want Air Quality Index } }, { module: "compliments", position: "lower_third" }, { module: "newsfeed", position: "bottom_bar", config: { feeds: [ { title: "Fox News", url: "http://feeds.foxnews.com/foxnews/latest", }, ], showSourceTitle: true, showPublishDate: true, } }, { module: 'MMM-NetworkConnection', position: 'bottom_bar', config: { } }, { module: 'MMM-page-indicator', position: 'bottom_bar', config: { pages: 3, } }, ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== "undefined") {module.exports = config;} -
i think there is an bug in the latest version of MMM-pages, see Issues.
I have the same behavior you described after updating MMM-pages today.
I restored the folder MMM-pages from my backup to an older version and now it is working again.
AxLED
H hahawoooooo referenced this topic on
