    Calendar module is not loaded
    2 Posts 1 Posters 775 Views 1 Watching
    • Z Offline
      zaphbbrox
      My Setup:
      Raspberry Pi 2
      Raspbian: 9.4
      node: 10.9.0
      npm: 6.2.0
      MagicMirror: 2.4.1
      Since I didn’t get electron to work, I’m using MM in the serveronly mode. After my RPi boots and the graphical env is loaded, the following commands are executed from ~/.config/lxsession/LXDE/autostart:
      sh /home/pi/mm.sh
      The mm.sh file contains:
      exec > /var/log/mm.log
      exec 2>&1
      cd /opt/MagicMirror
      node serveronly &
      sleep 180
      epiphany --profile /home/pi/.config -a http://localhost:8080 &
      sleep 60
      DISPLAY=:0 xte 'key F11'
      When i access MM from my laptop everything is fine, but from the RPi the calendar module seems not to be loaded.
      In the logfile /var/log/mm.log I see the following messages:
      ** Message: console message: [native code] @0: Starting module: alert
      ** Message: console message: [native code] @0: Start updatenotification
      ** Message: console message: [native code] @0: Starting module: clock
      ** Message: console message: [native code] @0: Starting module: currentweather
      ** Message: console message: [native code] @0: Starting module: weatherforecast
      ** Message: console message: [native code] @0: Starting module: newsfeed
      ** Message: console message: [native code] @0: All modules started!
      Does anyone has a clue why the calendar module is not loading?
      EDIT: I changed the script so that it contains all the commands.
      • Z Offline
        zaphbbrox
        I narrowed it down. The problem seems to be the epiphany-browser. I switched to chromium and now all modules are being loaded.
