    [RasPi2] Application not starting when OpenGL is enabled
    4 Posts 2 Posters 1.9k Views 2 Watching
    • C Offline
      chsamuelHU
      Hello. I recently installed MagicMirror2 on my Raspberry Pi 2.
      I installed it via the bash install script and I use the most recent node.js/npm binaries from their website. Installation and everything went smoothly w/o/ any errors, and everything looked nice.
      Then, I’ve read in the github wiki that electron will generate lots of load on cpu, and that I should enable OpenGL via boot config text file or raspi-config.
      I’ve tried out both methods, and there seems to be no problems, except for MagicMirror not showing up. Here’s a console output:
      > magicmirror@2.4.1 start /home/pi/MagicMirror
      > sh run-start.sh
      Starting MagicMirror: v2.4.1
      Loading config ...
      Loading module helpers ...
      Module helper loaded: email
      All module helpers loaded.
      Server started ...
      Connecting socket for: email
      email helper started ...
      Starting module: newsfeed
      Launching application.
      Could anyone help me please?
        MarkusBe
        I have exactly the same issue. :(
        Any idea on what to do?
          MarkusBe @MarkusBe
          @markusbe Ok, I checked the locks and found out, that the MMM-PIR-Sensor module got an error message, it was build against another node.js version. A npm rebuild and npm install did not resolve the problem. I disabled the PIR Sensor in config.js, did an sudo apt-get update and sudo apt-get upgrade, and now my MagicMirror is working again. But I still have to figure out what happened to the PIR-Module.
          • C Offline
            chsamuelHU
            I don’t have the MMM-PIR-Sensor, also, node is up to date. Wonder whether it has to do with system upgrades…
