    black screen with "node clientonly"
    2 Posts 1 Posters 2.6k Views 1 Watching
    • rudibaraniR Offline
      rudibarani Project Sponsor
      Hi everyone,
      I have a fresh install of MagicMirror 2.4.1 running on a Raspberry PI 3b and am try to connect it to a MM-instance that is running in a Docker on my Synology using node clientonly. I can access the MM2 Docker server-version at 192.0.0.95:9090 in the local network without problems from different browsers.
      If I start MM2 on the Raspberry Pi (locally via npm start or remotely via DISPLAY=:0 npm start), the local sample config.js-file runs fine with MM2 and pulls online information. I get no errors.
      If I execute DISPLAY=:0 node clientonly --address 192.0.0.95 --port 9090 via SSH (or the pendant locally), I get
      Client: Starting MagicMirror: v2.4.1
      Client: Launching application.
      Client: libGL error: Client: MESA-LOADER: failed to retrieve device information
      and a black screen afterwards. It would be great if anybody had an idea how to solve this.
      Thanks for your help!
      Config Info:
      Raspberry Pi 3b
      Node: v 10.10.0
      NPM: v 6.4.1
      Screensaver disabled
      /boot/config.txt contains dtoverlay=vc4-fkms-v3d
        I think I found the solution: When starting MM inside Docker, I cannot add the true address (172.1.0.9) into the config file but leave it like this:
        address: "", // Localhost
        I can open this Docker-hosted Magic Mirror Website directly using a browser without problem.
        I am not yet versed in JS, but I had a look at the config.js in the clientonly-folder: There is this section, where the config from the remote server is received and passed along as environment variable:
        getServerAddress();
        	(config.address && config.port) || fail();
        	// Only start the client if a non-local server was provided
        	if (["localhost", "127.0.0.1", "::1", "::ffff:127.0.0.1", undefined].indexOf(config.address) === -1) {
        		getServerConfig(`http://${config.address}:${config.port}/config/`)
        			.then(function (config) {
        				// Pass along the server config via an environment variable
        				var env = Object.create(process.env);
        				var options = { env: env };
        				config.address = config.address;
        				config.port = config.port;
        				env.config = JSON.stringify(config);
        It seems, that the address information received from the server (which is empty in my case) overwrites the config.address variable I passed along when starting node clientonly --address 192.0.0.95 --port 9090. I changed the code manually and it worked :slightly_smiling_face:
        @MichMich I have added a pull request on Github to help others with the same problem (https://github.com/MichMich/MagicMirror/pull/1403)
        PS: The error message describe above remains, but the Magic Mirror shows up without problem.
