    3rd Party Addins not working
    1 Posts 1 Posters 763 Views 1 Watching
    • N
      neocleous
      Hi all,
      I have just set up my magic mirror and I have been able to alter the default modules to suite my region and preferences however I am having an issue with 3rd party addins. I must confess I am a bit of a Linux newb so I ahve done a fair amount of reading and copy pasting however I cannot get 3rd party modules to work.
      I am trying to run the web admin console and Spotify addin, I think I have configured both of them correctly and white listed my entire subnet however neither are working. I have missed something obvious in my config file shown below or done something else obvious?
      Thanks in advance.
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	ipWhitelist: ["127.0.0.1", "192.168.0.47", "::ffff:127.0.0.1", "::1", "::ffff:192.168.0.0/28"], // Set [] to allow all IP addresses
      	language: "en",
      	timeFormat: "12",
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
          			module: "MMM-Admin-Interface"
      			header: "UK Calendar",
      						symbol: "calendar-check-o ",
      						url: "https://www.calendarlabs.com/ical-calendar/ics/75/UK_Holidays.ics"
      			module: "compliments",
      			position: "lower_third"
      			module: "currentweather",
      				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
      				appid: "c3d0b9bf707df523a21cd2f3bbd32f38"
      			module: "weatherforecast",
      			header: "Weather Forecast",
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "BBC UK",
      						url: "http://feeds.bbci.co.uk/news/uk/rss.xml"
      				showSourceTitle: true,
      				showPublishDate: true
        			module: "MMM-NowPlayingOnSpotify",
        			position: "upper_third",
      				showCoverArt: "true",
      				clientID: "944d74d0c4ed40e6bc3c030512fc5da3",
          				clientSecret: "2519d1a6c42948d799a2a3e285a27246",
          				accessToken: "BQCgTm2SwfeQmulLWj8JyZL9bSZsCPfwtn9AtVMvQdVM-Ic2xsqZ8iBKM2ZAdmgdlLgPxnoTSeVllTkmnViLAHkS0dVvmeTNM9nxR1pN6RHl0o2yf8x-j40TkK74BQ7K6fIA6kWIqW4RvC87x883Iup3adaNLw",
          				refreshToken: "AQB14KZHEHIrNVyuHqUyrHr8b33IdvgpA8oeQ7T-T_xqCzdu08cpQ2m4QvCWsyuNTbeuK4IGTZANY2KdS-LDziWzyyts_vPr177fW4ru3zQsbVPrGebZTOOclUWo5gW46sR27w"
