omxplayer with open-gl?
Re: [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras
Hi, I have problems with the activation of the open-gl driver which is advised for MM 2.4.1. Without dtoverlay=vc4-kms-v3d everything works as expected. With open-gl enabled in config.txt I got no Picture, even on terminal with omxplayer directly…
solved: [https://github.com/michmich/magicmirror/wiki/configuring-the-raspberry-pi#enable-the-open-gl-driver-to-decrease-electrons-cpu-usage](link url) --> ```
As was mentioned in the forums you can also use the fake kms driver instead.And add the following line to /boot/config.txt:
dtoverlay=vc4-fkms-v3d
