    Unable to Run the Head first developing MM module for extreme beginners :(
    3 Posts 2 Posters 1.3k Views 2 Watching
      sunnykeerthi
      I’m absolute beginner to developing Magic Mirror Modules, but I’m ver keen and eager to learn and develop them. I started to follow the tutorial available at https://forum.magicmirror.builders/topic/8534/head-first-developing-mm-module-for-extreme-beginners. but the problem here I’m facing is as below. I did a git pull and installed the dependencies. when I did a node serveronly and firing up my chrome browser and heading to the localhost:8080, I’m able to see the clock, compliments, etc… (defaults provided). And as per the tutorial, I went till the getDom() step, and I tried running it, And when I went to my browser and refreshed the window, to my surprise, nothing is shown up, not even Hello, World!, I went to the developer console and searched for myContent , there is no such div created with such class name. :frowning_face:
      Config.js
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 24,
      	units: "metric",
      			module: "MMM-Test",
      			position: "top_left"
      MMM-Test.js
      Module.register("MMM-Timetable", {
        defaults: {},
        start: function () {},
      getDom: function() {
        var element = document.createElement("div")
        element.className = "myContent"
        element.innerHTML = "Hello, World!"
        return element
      notificationReceived: function() {},
        socketNotificationReceived: function() {},
      and my developer console output is as below.
      Initializing MagicMirror.
      Loading core translation file: translations/en.json
      Loading core translation fallback file: translations/en.json
      Load script: modules/MMM-Test//MMM-Test.js
      Module registered: MMM-Timetable
      Load stylesheet: css/custom.css
      All modules started!
      and below is my folder structure
      Please let me know where am I going wrong guys and please let me know on how can I fix this. Here are my codes.
      Thanks,
      Sunny
        sunnykeerthi
        Sorry for my dumbest question guys :frowning_face:. I got it working, changed Module.register("MMM-Timetable", to Module.register("MMM-Test", and its working fine.
        Thanks,
        Sunny
        • ? Offline
          A Former User @sunnykeerthi
          @sunnykeerthi It’s my fault. But I cannot edit that topic anymore. I don’t know why. -_-a
