    HTTP Server for streaming podcasts / news / volume
    1 Posts 1 Posters 728 Views 1 Watching
    • Y Offline
      yep_DD
      Dear fellow Mirror Designers,
      I wasn’t sure where to put this so I will post it here. From various sources I created a small python httpserver that changes the mirrors volume, starts a podcast (100 Seconds german news, when brushing your teeth:grimacing_face: ) or opens a live stream. This is the code, nothing special but may be helpful for some of you.
      I use FHEM and Philips Hue Dimmer Switches to control it:
      Uses:
      python3, livestreamer, omxplayer
      #!/usr/bin/python3 -u
      host_name = '10.0.1.49'  # Change this to your Raspberry Pi IP address
      host_port = 8000
      proc = ''
      import RPi.GPIO as GPIO
      from pathlib import Path
      import os
      import subprocess
      import signal
      from subprocess import call
      from time import sleep
      from http.server import BaseHTTPRequestHandler, HTTPServer
      class MyServer(BaseHTTPRequestHandler):
          def do_HEAD(self):
              self.send_response(200)
              self.send_header('Content-type', 'text/html')
              self.end_headers()
          def do_GET(self):
              global proc
              html = '''
                 <html>
                 <body style="width:960px; margin: 20px auto;">
                 <h1>Magic Mirror Control</h1>
                 <p>Current GPU temperature is {}</p>
                 <p>Podcast: <a href="/play">Play</a> <a href="/stop">Stop</a></p>
                 <p>ARD Livestream: <a href="/ard">Play</a> <a href="/stop">Stop</a></p>
                 <p>Volume: <a href="/down">down</a> <a href="/up">up</a></p>
                 <p>System: <a href="/shutdown">Shutdown</a> <a href="/restart">Restart</a></p>
                 <div id="podcast-status"></div>
                 <script>
                     document.getElementById("podcast-status").innerHTML="{}";
                 </script>
                 </body>
                 </html>
              temp = os.popen("/opt/vc/bin/vcgencmd measure_temp").read()
              self.do_HEAD()
              status = ''
              if self.path=='/':
                  #GPIO.setmode(GPIO.BCM)
                  #GPIO.setwarnings(False)
                  #GPIO.setup(17, GPIO.IN)
                  status='nothing'
              elif self.path=='/play':
                  if proc=='':
                      my_file = Path("/home/pi/MagicMirror/video.mp4")
                      if my_file.is_file():
                          statinfo = os.stat('/home/pi/MagicMirror/video.mp4')
                          if statinfo.st_size > 0:
                              proc = subprocess.Popen(["omxplayer", "-o", "alsa:hw:ALSA", "--no-osd", "/home/pi/MagicMirror/video.mp4"], preexec_fn=os.setsid)
                              status='Playing Podcast'
                          else:
                              proc = subprocess.Popen(["omxplayer", "-o", "alsa:hw:ALSA", "--no-osd", "/home/pi/MagicMirror/Loading.mp4"], preexec_fn=os.setsid)
                              status='Not yet available'
                      else:
                  else:
                      status='Stopping Podcast'
                      os.killpg(os.getpgid(proc.pid), signal.SIGTERM)
                      proc=''
              elif self.path=='/ard':
                  if proc=='':
                      proc = subprocess.Popen(["livestreamer", "hlsvariant://daserste_live-lh.akamaihd.net/i/daserste_de@91204/master.m3u8", "best", "-vnp", "omxplayer -o alsa:hw:ALSA --no-osd --timeout 20"], preexec_fn=os.setsid)
                      status='Playing ARD Livestream'
                  else:
                      status='Stopping Stream'
                      proc=''
              elif self.path=='/stop':
                  if proc!='':
                      proc=''
                  else:
                      status='Nothing to stop'
              elif self.path=='/shutdown':
                  status='Shutdown'
                  subprocess.Popen(["sudo", "shutdown", "-h", "now"], preexec_fn=os.setsid)
              elif self.path=='/restart':
                  status='Restart'
                  subprocess.Popen(["sudo", "reboot"], preexec_fn=os.setsid)
              elif self.path=='/down':
                  status='Volume down'
                  subprocess.Popen(["amixer", "set", "Master", "12%-"], preexec_fn=os.setsid)
              elif self.path=='/up':
                  status='Volume up'
                  subprocess.Popen(["amixer", "set", "Master", "12%+"], preexec_fn=os.setsid)
              self.wfile.write(html.format(temp[5:], status).encode("utf-8"))
      if __name__ == '__main__':
          http_server = HTTPServer((host_name, host_port), MyServer)
          print("Server Starts - %s:%s" % (host_name, host_port))
          try:
              http_server.serve_forever()
          except KeyboardInterrupt:
              http_server.server_close()
