MM Update - GIT error
17 Posts 4 Posters 6.0k Views 3 Watching
    justjim1220 Module Developer @Pakmann
    @pakmann
    OR…
    Rename your MagicMirror folder to MM-BAK
    then git clone MagicMirror for a fresh install
    Then move your modules folder, config.js, and custom.css files over to the fresh install
    might also need to move the package.json and package-lock.json files from the bak to the fresh install
    And, anytime I have dealt with anything like this, I always have to rebuild, or reboot, or both
    Jim Hallock - 1995
      mochman Module Developer
      Maybe this was the issue.
      https://www.geekwire.com/2018/github-recovering-widespread-outage-caused-networking-database-issues/
      J 1 Reply Last reply Oct 23, 2018, 10:06 PM Reply Quote 1
        justjim1220 Module Developer @mochman
        @mochman
        Yeah, it’s possible if the update was retrieved during that time.
        Jim Hallock - 1995
        • P Offline
          Pakmann
          @justjim1220
          so i did it. After that i try to make the npm install. Suprise… the next issues. What a hard MM update! Maybe you have any idea ?
           git pull && npm install
          Bereits aktuell.
          (node:1893) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
          npm ERR! Error: Method Not Allowed
          npm ERR!     at errorResponse (/usr/share/npm/lib/cache/add-named.js:260:10)
          npm ERR!     at /usr/share/npm/lib/cache/add-named.js:203:12
          npm ERR!     at saved (/usr/share/npm/node_modules/npm-registry-client/lib/get.js:167:7)
          npm ERR!     at FSReqWrap.oncomplete (fs.js:135:15)
          npm ERR! If you need help, you may report this *entire* log,
          npm ERR! including the npm and node versions, at:
          npm ERR!     <http://github.com/npm/npm/issues>
          npm ERR! System Linux 4.14.71-v7+
          npm ERR! command "/usr/bin/node" "/usr/bin/npm" "install"
          npm ERR! cwd /home/pi/MagicMirror
          npm ERR! node -v v8.11.1
          npm ERR! npm -v 1.4.21
          npm ERR! code E405
          npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@npmjs.com for more info.
          > phantomjs-prebuilt@2.1.16 install /home/pi/MagicMirror/node_modules/jshint/node_modules/phantomjs-prebuilt
          > node install.js
          PhantomJS not found on PATH
          Unexpected platform or architecture: linux/arm
          It seems there is no binary available for your platform/architecture
          Try to install PhantomJS globally
          npm WARN This failure might be due to the use of legacy binary "node"
          npm WARN For further explanations, please read
          /usr/share/doc/nodejs/README.Debian
          > electron-chromedriver@1.6.0 install /home/pi/MagicMirror/node_modules/spectron/node_modules/electron-chromedriver
          > node ./download-chromedriver.js
          npm WARN optional dep failed, continuing phantomjs-prebuilt@2.1.16
          npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
          npm WARN deprecated browserslist@2.11.3: Browserslist 2 could fail on reading Browserslist >3.0 config used in other tools.
          npm ERR!
          npm ERR! not ok code 0
          J 2 Replies Last reply Oct 23, 2018, 10:40 PM Reply Quote 0
            @pakmann
            GEEZ!!!
            I literally just installed a fresh MagicMirror to an Ubuntu OS, and had zero issues.
            I did a manual install of Browserlist…
            npm install Browserlist@3.0 -g
            then I also did a manual install of PhantomJS…
            sudo npm insall PhantomJS@latest -g
            Then I made sure I had updated versions of npm, node, and electron
            npm install npm@latest -g
            npm install node@ latest -g
            sudo npm electron@latest -g
            Jim Hallock - 1995
              @pakmann
              I’m not using pi, so I don’t really know if this will help or not… could be different
              Jim Hallock - 1995
              • P Offline
                Pakmann
                hmm… it looks like my system is broken. npm makes a lot of problems too.
                I decide to reset the systems completely. Fresh OS and a new MM installation. It was easier as to find the root cause. Now everythink is running up again.
                Thanks a lot for your ideas and your help
                2 / 2
