MM stopped loading after updating pi (error log included)
Fresh install of pi, tested and MM runs. Added the modules I want, tested, they all load and everything works. Ran updates on the pi, rebooted, MM won’t load.
PM2 log files show:
Error: ENOENT: no such file or directory, open 'package.json' at Object.fs.openSync (fs.js:660:18) at Object.fs.readFileSync (fs.js:565:33) at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:15:32) at Module._compile (internal/modules/cjs/loader.js:654:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:665:10) at Module.load (internal/modules/cjs/loader.js:566:32) at tryModuleLoad (internal/modules/cjs/loader.js:506:12) at Function.Module._load (internal/modules/cjs/loader.js:498:3) at Module.require (internal/modules/cjs/loader.js:598:17) at require (internal/modules/cjs/helpers.js:11:18)That log repeats as long as PM2 tries to keep loading MM.
running
find . -name package.json -maxdepth 2 -execdir npm install \;
doesn’t fix it.MM files are up to date (git pull), and the config file is good (npm run config:check)
Not sure where to go from here.
