    Black screen after AssistantMk2 install.
    3 Posts 2 Posters 1.3k Views 2 Watching
    • M
      Marcreed48
      Re: MMM-GoogleAssistant and MMM-AssistantMk2 installation issues :(Hello, this is my first time asking a question in a forum. I’m having some compatibility issues between MagicMirror2 and MMM- AssistantMk2 running on raspbian stretch.
      I had no problems through the entire installation process. After asking the weather and getting a response in terminal, I closed the terminal, rebooted and added the default model to config.js, saved changes then got a black screen instead of my mirror.
      Does anyone have an idea of how to troubleshoot? Thanks.
        sdetweil @Marcreed48
        @marcreed48 press ctrl-shift-i (letter i) to open the dev console. Then select the console tab. You can scroll to see errors… u can also minimize the mirror app with alt-space and then n, this would allow u to see the terminal window if u start mm that way
        • M
          Marcreed48 @sdetweil
          @sdetweil Thanks, but it turns out my upgrade to Stretch didn’t take very well and I couldn’t update either. I flashed a fresh stretch and I’ll try the updated AssistantMk2.
