    MagicMirror will not start after update 2.5.0
    6 Posts 3 Posters 2.3k Views 2 Watching
      Blackmirror
      Hello all,
      My MagicMirror will not start after update the MagicMirror to v2.5.0.
      NPM run config:check said the config.js have no syntax error.
      Before the update the magicmirror works fine.
        Blackmirror
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/ch              okidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@              1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}              )
        > magicmirror@2.5.0 postinstall /home/pi/MagicMirror
        > sh installers/postinstall/postinstall.sh && npm run install-fonts
        MagicMirror installation successful!
        > magicmirror@2.5.0 install-fonts /home/pi/MagicMirror
        > cd fonts && npm install
        npm WARN postcss-html@0.12.0 requires a peer of postcss-less@>=1.1.0 but none wa              s installed.
        npm WARN postcss-html@0.12.0 requires a peer of postcss-scss@>=1.0.0 but none wa              s installed.
        npm WARN postcss-html@0.12.0 requires a peer of sugarss@>=1.0.0 but none was ins              talled.
        npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 bu              t none was installed.
        Afer npm install it comes this warnings
          Blackmirror
          No one will help me?
            AxLed Module Developer
            @Blackmirror
            Can you please post the output when you try to start the mirror by
            npm start
            in the magicmirror folder?
            Your post only shows the warnings after installing/updating your magicmirror.
            AxLED
              Blackmirror
              Here the output:
              Starting MagicMirror: v2.5.0
              Loading config ...
              Loading module helpers ...
              No helper found for module: MMM-Carousel.
              Module helper loaded: MMM-Buttons
              No helper found for module: MMM-ProfileSwitcher.
              Module helper loaded: MMM-Podcast
              Module helper loaded: MMM-DWD-WarnWeather
              Module helper loaded: MMM-Todoist
              Module helper loaded: MMM-FRITZ-Box-Callmonitor
              No helper found for module: MMM-Callmonitor-Current-Call.
              WARNING! Could not load config file. Starting with default configuration. Error        found: Error: The module '/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modul        es/node-dht-sensor/build/Release/node_dht_sensor.node'
              was compiled against a different Node.js version using
              NODE_MODULE_VERSION 50. This version of Node.js requires
              NODE_MODULE_VERSION 57. Please try re-compiling or re-installing
              the module (for instance, using `npm rebuild` or `npm install`).
              App threw an error during load
              Error: The module '/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/node        -dht-sensor/build/Release/node_dht_sensor.node'
                  at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:166:20)
                  at Object.Module._extensions..node (module.js:671:18)
                  at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:166:20)
                  at Module.load (module.js:561:32)
                  at tryModuleLoad (module.js:504:12)
                  at Function.Module._load (module.js:496:3)
                  at Module.require (module.js:586:17)
                  at require (internal/module.js:11:18)
                  at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_help        er.js:11:16)
                  at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_help        er.js:42:3)
              MagicMirror will not quit, but it might be a good idea to check why this happene        d. Maybe no internet connection?
              If you think this really is an issue, please open an issue on GitHub: https://gi        thub.com/MichMich/MagicMirror/issues
              Launching application.
              After ```
              NPM install
              Im Modul DHT-Sensor work all fine. Thanks
                sdetweil @Blackmirror
                @blackmirror u need to go to the MMM-DHT-Sensor folder and do npm install there too (and any other modules that have a package,json file supplied)
                the upgrade SHOULD do this for you, but appears not…
