    Local LCD not showing Weather module
    1 Posts 1 Posters 683 Views 1 Watching
      12wsx
      Hello. I have installed MagicMirror on rasberry pi zero.
      When I connect lcd monitor or tv i can’t see weather module. When i connect to Magic Mirror via computer everything is ok.
      My config file
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	address: "", // Address to listen on, can be:
      	port: 8080,
      	ipWhitelist: [], // Set [] to allow all IP addresses
      	language: "pl",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "clock",
      			position: "top_left"
      						symbol: "calendar-check-o ",
      						url: "https://calendar.google.com/calendar/ical/"
      			module: "MMM-Solartemp",
      			position: "bottom_left",
      			header: "Solartemp",
      				baseURL: "http://solartemp.no-i",
      				key: "",
      				group: "",
          			module: 'MMM-Remote-Control'
          			// uncomment the following line to show the URL of the remote control on the mirror
          			// , position: 'bottom_left'
          			// you can hide this module afterwards from the remote control itself
      			 module: 'MMM-NOAA3',
      				position: 'top_right',
             				provider: "darksky", // From list above
             				apiKey: "",        // From one of the providers listed above
             				airKey: "YOUR API KEY",
             				css: "NOAA3",                   // THIS MUST CONTAIN A CSS STYLE NAME
         				userlat: "delete for security ", //MUST HAVE BOTH
             				userlon: "delete for security"  //MUST HAVE BOTH
      I have installed server version and midori browser.
      I never had this problem and don’t know how to solve it.
