    MMM-voice ugly hdmi banner
    Scheduled Pinned Locked Moved Feature Requests
    42 Posts 3 Posters 22.7k Views 3 Watching
      dazza120
      Is there anyway to stop the hdmi no signal banner when you put the screen to sleep via voice, for some reason this can’t switch the tv that I’m using on and off it only cuts the Pi signal via hdmi, on my other Samsung tv it turns it completely off and on standby, but for now I just want the ugly banner removed and then I’ll probably install the screen buttons in the frame to turn it on from standby worst case scenario.
        mdhenriksen @dazza120
        @dazza120 Hey Dazza! I’ve read somewhere on here, that you might be able the change it in the TV-settings somewhere. Try to grab your remote and see if there is something you can do on the TV firstly.
          @dazza120 It could also be because your monitor doesn’t support CEC or it isn’t enabled. Try Googling CEC + your monitor brand and model.
          D 3 Replies Last reply Reply Quote 0
            dazza120 @mdhenriksen
            @mdhenriksen hi thanks my monitor is actually a tv samsung ue32j510AKXXU
              @mdhenriksen it switches on via my Apple TV, but not from the Pi, the sceen knows it’s there I have it linked as a settop box so it should be using the hdmi as it does with the Apple TV, for now just need the ugly no signal turning off
                @mdhenriksen so I think I’m boned on this point it can put it to sleep ie just turning off the Pi hdmi rather than the signal to monitor not sure if that’s because I’m using the fork by @cowboysdude? Which I don’t think is the case, I’ll have to look into this some more but now I can actually revive it from no input detected, but the sleep and wake is what I’m after. The TV has a DVI hdmi connection and that is what I have used to rescue it from the HDMI no signal that I couldn’t revive it from.
                  sdetweil @dazza120
                  @dazza120 the tv is an energystar device. which will show the ugly no input screen until the energyStar timeout (15 minutes) and then power off…
                  that is what the HIDE setting on my MMM-SleepWake module does. it blanks the screen, instead of turn off the signal.
                    dazza120 @sdetweil
                    @sdetweil cheers but I had to leave MMM-SleepWake as I didn’t have a clue how to install the motion project, the more I looked at it the more my tiny brain 🧠 started to smoke 🤯
                      sdetweil @dazza120
                      @dazza120 https://motion-project.github.io/motion_build.html
                      To install via apt, open up a terminal window and type: sudo apt-get install motion
                        dazza120 @sdetweil
                        @sdetweil said in MMM-voice ugly hdmi banner:
                        Your joking! So is that the packaged installed with that command? As what I was looking at was totally different to this. Thanks for your help.
                          sdetweil @dazza120
                          @dazza120 from github project page
                          Motion, a software motion detector. Home page: https://motion-project.github.io/
                          click documentation and then
                          https://motion-project.github.io/motion_guide.html
                            dazza120 @sdetweil
                            @sdetweil i have followed it as best as i could i have the package installed and have located the motion folder in my user directory but for the life of me i cant find this motion.conf file to insert your script.
                              sdetweil
                              motion config is done in /etc/motion/motion.conf
                              i just added a line in the readme about that
                                dazza120 @sdetweil
                                @sdetweil thank you, i have located it with your help, ill work on this when im not at work thanks, so its just a case of adding one of your scripts? think ill just use the start one
                                  sdetweil @dazza120
                                  @dazza120 its just one script… external_motion… you pass it a parm, started or ended
                                  you need to configue both started and ended, else it can’t sleep thinking motion is still going on
                                  note that because it is in the /etc folder tree, you must use sudo in front of your editor to get write permission
                                    dazza120 @sdetweil
                                    @sdetweil motion.conf won’t let me edit it, or rather the pi won’t any way around this?
                                      sdetweil
                                      sudo nano /etc/motion/motion.conf
                                      nano or whatever editor you choose…
                                        sdetweil
                                        also just noticed that the execute bit is not set on the script… SO
                                        cd modules/MMM-SleepWake
                                        chmod +x external_motion
                                          dazza120 @sdetweil
                                          @sdetweil so is it just this part i need to put on_event_start /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion started
                                            sdetweil @dazza120
                                            @dazza120 correct… and right below it the same with ended as the parm for the motion ended notice
                                            • 3 / 3
