    Can't install / Error with NPM / Electron not found
    6 Posts 2 Posters 3.5k Views 2 Watching
      mdhenriksen
      Hey guys,
      (I’m using Linux 18.10, doing a manual install)
      So I have installed MagicMirror before and had no trouble with it that I couldn’t fix. But I just tried installing it on another computer, and I keep getting this error now:
      > magicmirror@2.6.0 start /home/magicmirror/new/MagicMirror
      > sh run-start.sh
      /home/magicmirror/new/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libgconf-2.so.4: cannot open shared object file: No such file or directory
      npm ERR! file sh
      npm ERR! code ELIFECYCLE
      npm ERR! errno ENOENT
      npm ERR! syscall spawn
      npm ERR! magicmirror@2.6.0 start: `sh run-start.sh`
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the magicmirror@2.6.0 start script.
      npm ERR!     /home/magicmirror/.npm/_logs/2019-01-02T15_23_49_977Z-debug.log
      I have tried re-installing several times and tried older suggestions here on the forum. Might it be because of the new release? Any ideas?
        sdetweil
        @mdhenriksen said in Can't install / Error with NPM / Electron not found:
        libgconf-2.so.4
        a google search for ‘error while loading shared libraries: libgconf-2.so.4’
        see https://github.com/electron/electron/issues/1518
        M 1 Reply Last reply Reply Quote 2
          mdhenriksen @sdetweil
          @sdetweil I’ve tried that. It just says the following:
          Reading package lists... Done
          Building dependency tree
          Reading state information... Done
          E: Unable to locate package libconf-2-4
            sdetweil
            note the missing g
            libconf-2-4
            should be
            libgconf-2-4
              @sdetweil said in Can't install / Error with NPM / Electron not found:
              note the missing g
              libconf-2-4
              should be
              libgconf-2-4
              Hah! Sorry, such a dummy. Works now, thanks buddy!!
                sdetweil
                cool… can u mark your issue as solved
