    [MMM-awesome-alexa] Problems snowboy1.2.0
    4 Posts 2 Posters 1.7k Views 1 Watching
    • F Offline
      Feldker
      Hey,
      i habe some problems during the installation,
      here are the logs.
      pi@raspberrypi:~/MagicMirror/modules/MMM-awesome-alexa $ sudo npm install --only=prod
      snowboy@1.2.0 preinstall /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy
      npm install node-pre-gyp
      npm ERR! path /root/.npm/_logs
      npm ERR! code EACCES
      npm ERR! errno -13
      npm ERR! syscall scandir
      npm ERR! Error: EACCES: permission denied, scandir ‘/root/.npm/_logs’
      npm ERR! { [Error: EACCES: permission denied, scandir ‘/root/.npm/_logs’]
      npm ERR! stack:
      npm ERR! “Error: EACCES: permission denied, scandir ‘/root/.npm/_logs’”,
      npm ERR! errno: -13,
      npm ERR! code: ‘EACCES’,
      npm ERR! syscall: ‘scandir’,
      npm ERR! path: ‘/root/.npm/_logs’ }
      npm ERR!
      npm ERR! The operation was rejected by your operating system.
      npm ERR! It is likely you do not have the permissions to access this file as the current user
      npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check the
      npm ERR! permissions of the file and its containing directories, or try running
      npm ERR! the command again as root/Administrator (though this is not recommended).
      glob error { [Error: EACCES: permission denied, scandir ‘/root/.npm/_logs’]
      stack:
      errno: -13,
      code: ‘EACCES’,
      syscall: ‘scandir’,
      npm ERR! path /root/.npm/_cacache/index-v5/f6/d3/856f4e146dc3e8cb995652c4d6a1e16806d6bca7e87878fd9046e55ea74f
      npm ERR! errno -13
      npm ERR! syscall open
      npm ERR! Error: EACCES: permission denied, open ‘/root/.npm/_cacache/index-v5/f6/d3/856f4e146dc3e8cb995652c4d6a1e16806d6bca7e87878fd9046e55ea74f’
      npm ERR! { [Error: EACCES: permission denied, open ‘/root/.npm/_cacache/index-v5/f6/d3/856f4e146dc3e8cb995652c4d6a1e16806d6bca7e87878fd9046e55ea74f’]
      npm ERR! cause:
      npm ERR! { Error: EACCES: permission denied, open ‘/root/.npm/_cacache/index-v5/f6/d3/856f4e146dc3e8cb995652c4d6a1e16806d6bca7e87878fd9046e55ea74f’
      npm ERR! syscall: ‘open’,
      npm ERR! path:
      npm ERR! ‘/root/.npm/_cacache/index-v5/f6/d3/856f4e146dc3e8cb995652c4d6a1e16806d6bca7e87878fd9046e55ea74f’ },
      npm ERR! isOperational: true,
      npm ERR! stack:
      npm ERR! “Error: EACCES: permission denied, open ‘/root/.npm/_cacache/index-v5/f6/d3/856f4e146dc3e8cb995652c4d6a1e16806d6bca7e87878fd9046e55ea74f’”,
      npm ERR! path:
      npm ERR!
      npm ERR!
      npm ERR! code ELIFECYCLE
      npm ERR! errno 243
      npm ERR! snowboy@1.2.0 preinstall: npm install node-pre-gyp
      npm ERR! Exit status 243
      npm ERR!
      npm ERR! Failed at the snowboy@1.2.0 preinstall script.
      npm ERR! /root/.npm/_logs/2019-01-10T20_55_36_481Z-debug.log
        bhepler Module Developer
        I don’t think you need to use sudo to run the npm install routine. Looking at your error logs (and you really should be using the Markdown features), I would guess that you used the sudo command to clone the module.
        My suggestion is to delete the MMM-Awesome-Alexa folder and then follow the steps on the installation page.
        • F Offline
          Feldker @bhepler
          @bhepler : Tanks for your help. I have completely reinstalled it.
          Then it works.
          But i have a new Problem.
          > mmm-awesome-alexa@1.0.0 electron-rebuild /home/pi/MagicMirror/modules/MMM-awesome-alexa
          > electron-rebuild --pre-gyp-fix
          ✖ Rebuild Failed
          An unhandled error occurred inside electron-rebuild
          Could not detect abi for version 2.0.16 and runtime electron.  Updating "node-abi" might help solve this issue if it is a new release of electron
          Error: Could not detect abi for version 2.0.16 and runtime electron.  Updating "node-abi" might help solve this issue if it is a new release of electron
              at Object.getAbi (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/node-abi/index.js:43:9)
              at _callee6$ (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/electron-rebuild/lib/rebuild.js:152:37)
              at tryCatch (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/electron-rebuild/node_modules/regenerator-runtime/runtime.js:63:40)
              at Generator.invoke [as _invoke] (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/electron-rebuild/node_modules/regenerator-runtime/runtime.js:337:22)
              at Generator.prototype.(anonymous function) [as next] (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/electron-rebuild/node_modules/regenerator-runtime/runtime.js:96:21)
              at Generator.tryCatcher (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/bluebird/js/release/util.js:16:23)
              at PromiseSpawn._promiseFulfilled (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/bluebird/js/release/generators.js:97:49)
              at /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/bluebird/js/release/generators.js:201:15
              at _rebuild (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/electron-rebuild/lib/rebuild.js:613:18)
              at rebuild (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/electron-rebuild/lib/rebuild.js:624:28)
              at _callee$ (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/electron-rebuild/lib/cli.js:160:45)
          npm ERR! errno 255
          npm ERR! mmm-awesome-alexa@1.0.0 electron-rebuild: `electron-rebuild --pre-gyp-fix`
          npm ERR! Exit status 255
          npm ERR!
          npm ERR! Failed at the mmm-awesome-alexa@1.0.0 electron-rebuild script.
          npm ERR!     /home/pi/.npm/_logs/2019-01-14T18_21_44_749Z-debug.log
            My quick research indicates that there is a mismatch between the version of Electron and the abi. You can try this:
            npm update node-abi
            npm install
            Let me know how it goes. And thanks for using the Markdown.
