    Current weather not displaying
    2 Posts 2 Posters 1.8k Views 2 Watching
    • H Offline
      henryluyu
      Hi this is my config.js:
      *I have removed appid
      weather forecast works fine but current weather does not show. I did not change anything in the module (downloaded from https://github.com/MichMich/MagicMirror#configuration), I only changed city name, appid and position.
      Also I noticed in the video (https://www.youtube.com/watch?v=pcmjht0Hqvw&t=680s), at 10.29 there also isn’t a current weather showing.
      Can anyone help please?
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 24,
      	units: "Metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			module: "compliments",
      			position: "lower_third"
      			module: "currentweather",
      				locationID: "2643123",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
      				appid: "REMOVED"
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				locationID: "2643123",  //ID from https://openweathermap.org/city
      				appid: "REMOVED"
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "BBC",
      						url: "http://feeds.bbci.co.uk/news/rss.xml"
      				showSourceTitle: true,
      				showPublishDate: true
      • Z Offline
        ZitoMD
        @henryluyu Try removing , GB from the location line of Current Weather module.
