    Rebuild Failed mmm-awesome-alexa
    1 Posts 1 Posters 615 Views 1 Watching
    • F
      Feldker
      I have some problems.
      I can not start the
      $ npm run electron-rebuild
      > mmm-awesome-alexa@1.0.0 electron-rebuild /home/pi/MagicMirror/modules/MMM-awesome-alexa
      > electron-rebuild --pre-gyp-fix
      ✖ Rebuild Failed
      An unhandled error occurred inside electron-rebuild
      Could not detect abi for version 2.0.16 and runtime electron.  Updating "node-abi" might help solve this issue if it is a new release of electron
      Error: Could not detect abi for version 2.0.16 and runtime electron.  Updating "node-abi" might help solve this issue if it is a new release of electron
          at Object.getAbi (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/node-abi/index.js:43:9)
          at _callee6$ (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/electron-rebuild/lib/rebuild.js:152:37)
          at tryCatch (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/electron-rebuild/node_modules/regenerator-runtime/runtime.js:63:40)
          at Generator.invoke [as _invoke] (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/electron-rebuild/node_modules/regenerator-runtime/runtime.js:337:22)
          at Generator.prototype.(anonymous function) [as next] (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/electron-rebuild/node_modules/regenerator-runtime/runtime.js:96:21)
          at Generator.tryCatcher (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/bluebird/js/release/util.js:16:23)
          at PromiseSpawn._promiseFulfilled (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/bluebird/js/release/generators.js:97:49)
          at /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/bluebird/js/release/generators.js:201:15
          at _rebuild (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/electron-rebuild/lib/rebuild.js:613:18)
          at rebuild (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/electron-rebuild/lib/rebuild.js:624:28)
          at _callee$ (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/electron-rebuild/lib/cli.js:160:45)
      npm ERR! code ELIFECYCLE
      npm ERR! errno 255
      npm ERR! mmm-awesome-alexa@1.0.0 electron-rebuild: `electron-rebuild --pre-gyp-fix`
      npm ERR! Exit status 255
      npm ERR!
      npm ERR! Failed at the mmm-awesome-alexa@1.0.0 electron-rebuild script.
      npm ERR!     /home/pi/.npm/_logs/2019-01-14T18_21_44_749Z-debug.log
