    npm dependencies not installed on fresh MM2 installation
    10 Posts 3 Posters 3.8k Views 3 Watching
      MWel1977
      Because I was having problems with some modules I decided to format my micro SD card and start all over again with my test enviroment on the Pi 3A+ (My working mirror runs on my Pi 3B+ :winking_face: )
      However I just run the installation of the MM2 command bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)" but when it got to “Installing dependencies” it run into an error:
      bash: line 112: npm: command does not exist. Unable to install dependencies!
      (well it’s translated from Dutch. Could also be “Command not found”)
      anybody got an idea what is going on?
        MWel1977
        UPDATE:
        SUCCES!!! YES!!!:smiling_face_with_open_mouth_smiling_eyes: :smiling_face_with_open_mouth_smiling_eyes: :smiling_face_with_open_mouth_smiling_eyes: :smiling_face_with_open_mouth_smiling_eyes: :smiling_face_with_open_mouth_smiling_eyes:
        I just had to install npm in the MagicMirror folder!
        My test bed for the MagicMirror is running again! :face_with_stuck-out_tongue_winking_eye: :face_with_stuck-out_tongue_winking_eye: :face_with_stuck-out_tongue_winking_eye:
          sdetweil
          yes, some of the platforms (Pi Stretch for example) are not installing npm and/or node as part of their initial installs…
          see here https://www.battlehillmedia.com/installing-node-js-and-npm-on-raspberry-pi-3/
          • Sandy2503S Offline
            Sandy2503
            have you installed the full raspian jessie or the lite version ?
              MWel1977 @Sandy2503
              @sandy2503 I’ve used: Raspbian Stretch with desktop and recommended software.
              and I’m just up and running again. Meaning I’ve Rasbian setup on my Pi 3A+ and typing this in the Chromium browser.
              First I’ll try to install the MagicMirror. Yesterday I installed it at work via an open network (guest login)
              and at random times one is thrown out of it. So that could also be an issue.
              Now I’m at home in my own network.
              So fingers crossed!
                MWel1977
                NOPE! It’s not due to poor geust network at work. I still can’t install the Dependencies.
                I do have Node because node -v is resulting in v8.11.1.
                but it can’t find npm. so I’ll install npm meself.
                  MWel1977
                  I’m starting to get angry!!!
                  pi@raspberrypi:~/MagicMirror $ git pull
                  Already up-to-date.
                  > magicmirror@2.6.0 start /home/pi/MagicMirror
                  > sh run-start.sh
                  run-start.sh: 4: run-start.sh: electron: not found
                  npm ERR! file sh
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno ENOENT
                  npm ERR! syscall spawn
                  npm ERR! magicmirror@2.6.0 start: `sh run-start.sh`
                  npm ERR! spawn ENOENT
                  npm ERR!
                  npm ERR! Failed at the magicmirror@2.6.0 start script.
                  npm WARN Local package.json exists, but node_modules missing, did you mean to install?
                  npm ERR!     /home/pi/.npm/_logs/2019-01-17T22_37_37_361Z-debug.log
                  Now it can’t find Electron. :face_with_steam_from_nose: :face_with_steam_from_nose: :angry_face:
                    MWel1977
                    UPDATE:
                    Found that npm i electron in the folder “MagicMirror” does the trick.
                    But now it “ENOENT” that’s causing problems!
                      sdetweil @MWel1977
                      @mwel1977 said in npm dependencies not installed on fresh MM2 installation:
                      ENOENT is file not found…
                      can u post the full error…
                        MWel1977
                        UPDATE:
                          sdetweil
                          great news… thanks for the feedback
