    Calendar 'Loading...' issue with iCloud
    1 Posts 1 Posters 1.5k Views 1 Watching
    • N Offline
      nigel-daniels
      I have seen a problem when using an iCloud url with the calendar module that I thought I’d post in case anyone else runs into the issue.
      Symptoms
      The symptom is the calendar sticks with the ‘Loading…’ message but never loads. On the command line I saw the following error:
      Ready to go! Please point your browser to: http://localhost:8080
      Create new calendar fetcher for url: http://p02-calendarws.icloud.com/ca/subscribe/1/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx - Interval: 300000
      [Error: Invalid UNTIL value: 20160730T115959]
      Cause
      With Mitchs support the problem has been traced to the rrule library which handles recurring calendar events. There is an open issue on the library here:
      https://github.com/jkbrzt/rrule/issues/145
      It seems the library is strictly following RFC2445 detailing how UTC dates work, but it seems not every calendar provider is structuring the dates per RFC2445 when they are set to a local time.
      I’ve added the problem I’m seeing to the issue 145. I hope that helps anyone else encountering the same issue.
