mm2 error
Hello dear community
I have the following problems have my mirror had long in the corner and now continue with it
So I updated everything! all modules and raspi too
Now show me pm2 log mm
0|mm | at Class.playChime (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:42:10) 0|mm | at Class.prepareActivate (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:135:12) 0|mm | at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:98:12) 0|mm | at Socket. (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:113:11) code: 'MODULE_NOT_FOUND' } 0|mm | { Error: Cannot find module 'play-sound' 0|mm | at Module._resolveFilename (module.js:543:15) 0|mm | at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12) 0|mm | at Function.Module._load (module.js:473:25) 0|mm | at Module.require (module.js:586:17) 0|mm | at require (internal/module.js:11:18) 0|mm | at Class.play (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:24:20) 0|mm | at Class.playChime (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:42:10) 0|mm | at Class.prepareActivate (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:135:12) 0|mm | at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:98:12) 0|mm | at Socket. (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:113:11) code: 'MODULE_NOT_FOUND' }
I hope you can help me
I’m sorry about my english google translate
@timur87
You’ve failed on installation MMM-AssistantMk2. Read the instruction carefully.
only that? I had everything running in the past now I just made updates so I have to adjust something again?
0 info it worked if it ends with ok 1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ] 2 info using npm@6.2.0 3 info using node@v9.11.2 4 verbose run-script [ 'prestart', 'start', 'poststart' ] 5 info lifecycle magicmirror@2.6.0~prestart: magicmirror@2.6.0 6 info lifecycle magicmirror@2.6.0~start: magicmirror@2.6.0 7 verbose lifecycle magicmirror@2.6.0~start: unsafe-perm in lifecycle true 8 verbose lifecycle magicmirror@2.6.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin$ 9 verbose lifecycle magicmirror@2.6.0~start: CWD: /home/pi/MagicMirror 10 silly lifecycle magicmirror@2.6.0~start: Args: [ '-c', 'sh run-start.sh' ] 11 silly lifecycle magicmirror@2.6.0~start: Returned: code: 1 signal: null 12 info lifecycle magicmirror@2.6.0~start: Failed to exec start script 13 verbose stack Error: magicmirror@2.6.0 start: `sh run-start.sh` 13 verbose stack Exit status 1 13 verbose stack at EventEmitter. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:304:$ 13 verbose stack at EventEmitter.emit (events.js:180:13) 13 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:$ 13 verbose stack at ChildProcess.emit (events.js:180:13) 13 verbose stack at maybeClose (internal/child_process.js:936:16) 13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:220:5) 14 verbose pkgid magicmirror@2.6.0 15 verbose cwd /home/pi/MagicMirror 16 verbose Linux 4.14.79-v7+ 17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start" 18 verbose node v9.11.2 19 verbose npm v6.2.0 20 error code ELIFECYCLE 21 error errno 1 22 error magicmirror@2.6.0 start: `sh run-start.sh` 22 error Exit status 1 23 error Failed at the magicmirror@2.6.0 start script. 23 error This is probably not a problem with npm. There is likely additional logging output above. 24 verbose exit [ 1, true ]
Your first error log says just
play-sound
node module is not installed. It means, you’ve missed or failednpm install
step on installation of MMM-AssistantMk2
Your second error log is somewhat obvious, but I think you have a problem withnodeJS
ornpm
. I cannot assure but you seems to need a clean install of your nodeJS or npm from scratch.
