    Dependency Problems
    6 Posts 3 Posters 4.2k Views 3 Watching
    • N Offline
      negativeflare
      When running npm install on my raspberry pi 2, I encounter this error:
      magicmirror@2.0.0 prepublish /home/pi/MagicMirror
      npm run snyk-protect
      magicmirror@2.0.0 snyk-protect /home/pi/MagicMirror
      snyk protect
      Successfully applied Snyk patches
      npm ERR! peerinvalid The package grunt does not satisfy its siblings’ peerDependencies requirements!
      npm ERR! peerinvalid Peer grunt-eslint@19.0.0 wants grunt@>=0.4.0
      npm ERR! peerinvalid Peer grunt-yamllint@0.2.0 wants grunt@~0.4.0
      npm ERR! System Linux 4.4.21+
      npm ERR! command “/usr/bin/nodejs” “/usr/bin/npm” “install”
      npm ERR! cwd /home/pi/MagicMirror
      npm ERR! node -v v0.10.29
      npm ERR! npm -v 1.4.21
      npm ERR! code EPEERINVALID
      npm ERR!
      npm ERR! /home/pi/MagicMirror/npm-debug.log
      npm ERR! not ok code 0
      • T Offline
        tajno
        Did you install the package?
        npm install snyk-protect
        Try to run it:
        Does that work?
        • N Offline
          negativeflare
          This is what I get when I run npm install snky-protect:
          pi@raspberrypi:~/MagicMirror $ npm install snyk-protect
          npm ERR! 404 Not Found
          npm ERR! 404
          npm ERR! 404 ‘snyk-protect’ is not in the npm registry.
          npm ERR! 404 You should bug the author to publish it
          npm ERR! 404 It was specified as a dependency of ‘magicmirror’
          npm ERR! 404
          npm ERR! 404 Note that you can also install from a
          npm ERR! 404 tarball, folder, or http url, or git url.
          npm ERR! command “/usr/bin/nodejs” “/usr/bin/npm” “install” “snyk-protect”
          npm ERR! code E404
          npm ERR!
          • T Offline
            tajno @negativeflare
            @negativeflare
            Hm strange. Do you use npm version 0.10.29 on purpose?
            May you try to update:
            npm install npm -g
            npm update -g
            and also maybe clean cache:
            npm cache clean
            and than again to try install the package and his dependency.
            • N Offline
              negativeflare
              Thanks! That fixed it.
              • P Offline
                poutr
                npm install npm -g
                npm update -g
                install me npm version 4.1.2 which now only raises a warning for yamllint (since that package.json asked exactly for 0.4.0).
                Probably because of this : http://gruntjs.com/blog/2016-04-04-grunt-1.0.0-released#peer-dependencies
                No guarantee, but I think I have npm version 2 something before, which hard error on that issue.
