    Current version(!) of PIR-Sensor caused black screen
    2 Posts 2 Posters 969 Views 1 Watching
    • K
      Klinge
      Hello,
      my PIR-Sensor caused a black screen.
      It worked fine until a few days ago.
      Then the MM started and after a few hours the monitor switched off and does not switched on again.
      Today I installed the PIR module (https://github.com/paviro/MMM-PIR-Sensor) again with the old PIN-settings. But now, when the MM start, there is only a black screen.
      Thats the config
                      module: 'MMM-PIR',
                      position: 'bottom_center',
                              sensorPIN: 4,
                              delay: 30000,
                              turnOffDisplay: true,
                              showCountdown: true,
      Does anyone have a good idea?
      I would be very grateful.
      Thank you in advance.
      Lars
      • A
        AxLed Module Developer
        @Klinge
        For using Paviros module MMM-PIR-Sensor your config is wrong.
        Instead of
        module: 'MMM-PIR',
        you have to use
        module: 'MMM-PIR-Sensor',
        Also the options “delay”, “turnOffDisplay” and “showCountdown” are not part of the module MMM-PIR-Sensor and so there are not working.
        AxLED
