    Need help from a developer, little code, but need solution
    3 Posts 2 Posters 1.8k Views 2 Watching
    • T Offline
      THeStigh
      Hi all,
      I need help from a developer to find a way to stop using the microphone by PocketSphinx.
      This should be stopped by receiving a notification.
      The module which I am working on is a tweak of MMM-voice, using PocketSphinx.
      It does not contain any way to stop using the microphone.
      I want to achieve this so the microphone is available to other modules.
      Thanx,
      TheStigh
        sdetweil @THeStigh
        @thestigh we exchanged info on this, and have solved the problem…
        T 1 Reply Last reply Reply Quote 2
        • T Offline
          THeStigh @sdetweil
          @sdetweil That is correct; you are a very skilled developer @sdetweil !
          Thank you for all your help :)
