Having trouble with pyaudio for MMM-awesome-alexa
i was able to do the setup for the line of
sudo apt-get install swig3.0 python-pyaudio python3-pyaudio soxbut when i tried to do
pip install pyaudioi got a large error message saying:
pi@raspberrypi:~ $ pip install pyaudio Collecting pyaudio Downloading https://files.pythonhosted.org/packages/ab/42/b4f04721c5c5bfc196ce156b3c768998ef8c0ae3654ed29ea5020c749a6b/PyAudio-0.2.11.tar.gz Building wheels for collected packages: pyaudio Running setup.py bdist_wheel for pyaudio ... error Complete output from command /usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-iJzkjw/pyaudio/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/tmpTyBzJLpip-wheel- --python-tag cp27: running bdist_wheel running build running build_py creating build creating build/lib.linux-armv7l-2.7 copying src/pyaudio.py -> build/lib.linux-armv7l-2.7 running build_ext building '_portaudio' extension creating build/temp.linux-armv7l-2.7 creating build/temp.linux-armv7l-2.7/src arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-Ub3vap/python2.7-2.7.13=. -fstack-protector-strong -Wformat -Werror=format-security -fPIC -I/usr/include/python2.7 -c src/_portaudiomodule.c -o build/temp.linux-armv7l-2.7/src/_portaudiomodule.o src/_portaudiomodule.c:29:23: fatal error: portaudio.h: No such file or directory #include "portaudio.h" ^ compilation terminated. error: command 'arm-linux-gnueabihf-gcc' failed with exit status 1 ---------------------------------------- Failed building wheel for pyaudio Running setup.py clean for pyaudio Failed to build pyaudio Installing collected packages: pyaudio Running setup.py install for pyaudio ... error Complete output from command /usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-iJzkjw/pyaudio/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-UfXgaL-record/install-record.txt --single-version-externally-managed --compile --user --prefix=: running install running build running build_py creating build creating build/lib.linux-armv7l-2.7 copying src/pyaudio.py -> build/lib.linux-armv7l-2.7 running build_ext building '_portaudio' extension creating build/temp.linux-armv7l-2.7 creating build/temp.linux-armv7l-2.7/src arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-Ub3vap/python2.7-2.7.13=. -fstack-protector-strong -Wformat -Werror=format-security -fPIC -I/usr/include/python2.7 -c src/_portaudiomodule.c -o build/temp.linux-armv7l-2.7/src/_portaudiomodule.o src/_portaudiomodule.c:29:23: fatal error: portaudio.h: No such file or directory #include "portaudio.h" ^ compilation terminated. error: command 'arm-linux-gnueabihf-gcc' failed with exit status 1 ---------------------------------------- Command "/usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-iJzkjw/pyaudio/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-UfXgaL-record/install-record.txt --single-version-externally-managed --compile --user --prefix=" failed with error code 1 in /tmp/pip-build-iJzkjw/pyaudio/how do i fix this?
nevermind figured it out but idk how to mark as solved, had to get python dev stuff, heres a link if anyone else has issues:
SOLUTION
