    issue with installing MMM-awesome-alexa
    1 Posts 1 Posters 841 Views 1 Watching
    • J
      jmartin1009
      Everything was working with Awesome-Alexa until i got to the command:
      $ npm install --only=prod
      once i put this in, i got a huge error message, that i dont even know where to start or what to do as this is my first mirror. Here is the output:
      pi@raspberrypi:~/MagicMirror/modules/MMM-awesome-alexa $ npm install --only=prod
      > snowboy@1.2.0 preinstall /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy
      > npm install node-pre-gyp
      npm WARN deprecated cryptiles@2.0.5: This version is no longer maintained. Please upgrade to the latest version.
      npm WARN deprecated boom@2.10.1: This version is no longer maintained. Please upgrade to the latest version.
      npm WARN deprecated hoek@2.16.3: This version is no longer maintained. Please upgrade to the latest version.
      npm notice created a lockfile as package-lock.json. You should commit this file.
      + node-pre-gyp@0.6.39
      added 114 packages from 78 contributors and audited 268 packages in 17.795s
      found 8 moderate severity vulnerabilities
        run `npm audit fix` to fix them, or `npm audit` for details
      > snowboy@1.2.0 install /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy
      > node-pre-gyp install --fallback-to-build
      node-pre-gyp ERR! Tried to download(403): https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.2.0/Release/snowboy-v1.2.0-node-v64-linux-arm.tar.gz
      node-pre-gyp ERR! Pre-built binaries not found for snowboy@1.2.0 and node@10.15.1 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
      node-pre-gyp ERR! Tried to download(undefined): https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.2.0/Release/snowboy-v1.2.0-node-v64-linux-arm.tar.gz
      make: Entering directory '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/build'
        CXX(target) Release/obj.target/snowboy/swig/Node/snowboy.o
      In file included from ../../nan/nan.h:192:0,
                       from ../swig/Node/snowboy.cc:1:
      ../../nan/nan_maybe_43_inl.h: In function ‘Nan::Maybe<bool> Nan::ForceSet(v8::Local<v8::Object>, v8::Local<v8::Value>, v8::Local<v8::Value>, v8::PropertyAttribute)’:
      ../../nan/nan_maybe_43_inl.h:112:15: error: ‘class v8::Object’ has no member named ‘ForceSet’
         return obj->ForceSet(isolate->GetCurrentContext(), key, value, attribs);
      In file included from ../swig/Node/snowboy.cc:1:0:
      ../../nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’:
      ../../nan/nan.h:835:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
               v8::Isolate::GetCurrent(), target, func, argc, argv);
      In file included from ../../nan/nan.h:49:0,
      /home/pi/.node-gyp/10.15.1/include/node/node.h:177:50: note: declared here
                       NODE_EXTERN v8::Local<v8::Value> MakeCallback(
      /home/pi/.node-gyp/10.15.1/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’
           __attribute__((deprecated(message))) declarator
      ../../nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’:
      ../../nan/nan.h:850:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
               v8::Isolate::GetCurrent(), target, symbol, argc, argv);
      /home/pi/.node-gyp/10.15.1/include/node/node.h:170:50: note: declared here
      ../../nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’:
      ../../nan/nan.h:865:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
               v8::Isolate::GetCurrent(), target, method, argc, argv);
      /home/pi/.node-gyp/10.15.1/include/node/node.h:163:50: note: declared here
      ../../nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::Callback::Call_(v8::Isolate*, v8::Local<v8::Object>, int, v8::Local<v8::Value>*) const’:
      ../../nan/nan.h:1479:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
      snowboy.target.mk:107: recipe for target 'Release/obj.target/snowboy/swig/Node/snowboy.o' failed
      make: *** [Release/obj.target/snowboy/swig/Node/snowboy.o] Error 1
      make: Leaving directory '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/build'
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
      gyp ERR! stack     at ChildProcess.emit (events.js:189:13)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
      gyp ERR! System Linux 4.14.79-v7+
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node" "--module_name=snowboy" "--module_path=/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm"
      gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy
      gyp ERR! node -v v10.15.1
      gyp ERR! node-gyp -v v3.8.0
      gyp ERR! not ok
      node-pre-gyp ERR! build error
      node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node --module_name=snowboy --module_path=/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm' (1)
      node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
      node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:189:13)
      node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:970:16)
      node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
      node-pre-gyp ERR! System Linux 4.14.79-v7+
      node-pre-gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
      node-pre-gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy
      node-pre-gyp ERR! node -v v10.15.1
      node-pre-gyp ERR! node-pre-gyp -v v0.6.39
      node-pre-gyp ERR! not ok
      gyp ERR! not ok
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! snowboy@1.2.0 install: `node-pre-gyp install --fallback-to-build`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the snowboy@1.2.0 install script.
      npm ERR!     /home/pi/.npm/_logs/2019-02-25T03_06_52_362Z-debug.log
      If ANYONE is able to help it would be GREATLY appreciated. Thank you
