    'snyk-protect' is not in the npm registry.
    1 Posts 1 Posters 1.6k Views 1 Watching
    • D
      DarrellJones
      So i installed from the script and when it finished there were 3 WARN messages saying
      npm WARN prefer global coffee-script@1.10.0 should be installed with -g
      npm WARN prefer global colorguard@1.2.0 should be installed with -g
      npm WARN prefer global jsonlint@1.6.2 should be installed with -g
      so i reimnstalled those using -g and that went ok. renamed the config file and did npm start. no dice. i got
      magicmirror@2.0.0 start /home/pi/MagicMirror
      electron js/electron.js
      fs.js:557
      return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
      Error: ENOENT: no such file or directory, open ‘/home/pi/MagicMirror/node_modules/electron-prebuilt/path.txt’
      at Object.fs.openSync (fs.js:557:18)
      at Object.fs.readFileSync (fs.js:467:33)
      at Object. (/home/pi/MagicMirror/node_modules/electron-prebuilt/index.js:4:42)
      at Module._compile (module.js:573:32)
      at Object.Module._extensions…js (module.js:582:10)
      at Module.load (module.js:490:32)
      at tryModuleLoad (module.js:449:12)
      at Function.Module._load (module.js:441:3)
      at Module.require (module.js:500:17)
      at require (internal/module.js:20:19)
      npm ERR! Linux 4.4.30-v7+
      npm ERR! argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
      npm ERR! node v7.0.0
      npm ERR! npm v4.0.2
      npm ERR! code ELIFECYCLE
      npm ERR! magicmirror@2.0.0 start: electron js/electron.js
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.0.0 start script ‘electron js/electron.js’.
      npm ERR! If you do, this is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR! electron js/electron.js
      npm ERR! npm bugs magicmirror
      npm ERR! Or if that isn’t available, you can get their info via:
      npm ERR! npm owner ls magicmirror
      npm ERR! /home/pi/MagicMirror/npm-debug.log
      after seeing someone else here having issues relating to snyk-protect i tried
      pi@raspberrypi:~/MagicMirror $ sudo npm update -g
      pi@raspberrypi:~/MagicMirror $ sudo npm cache clean
      pi@raspberrypi:~/MagicMirror $ sudo npm install snyk-protect
      npm ERR! argv “/usr/local/bin/node” “/usr/local/bin/npm” “install” “snyk-protect”
      npm ERR! npm v3.10.9
      npm ERR! code E404
      npm ERR! 404 Registry returned 404 for GET on https://registry.npmjs.org/snyk-protect
      npm ERR! 404
      npm ERR! 404 ‘snyk-protect’ is not in the npm registry.
      npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
      npm ERR! 404
      npm ERR! 404 Note that you can also install from a
      npm ERR! 404 tarball, folder, http url, or git url.
      sorry for the wall of text, can anyone help
