    Noob need help
    11 Posts 5 Posters 4.0k Views 5 Watching
      Muzziboy @sdetweil
      @sdetweil thank you for pointing that out it autostarts now. Well twice so far. Thanks
      • CyruS1337C Offline
        CyruS1337 Project Sponsor
        So I do not directly have the same problem with dimming. But with me it is so that with one mirror the writing is brighter and with the other mirror darker, although it concerns identical Montiore. Can you adjust the brightness in the general menu?
          One of my TV’s have some kind of automatic dimming based on the total brightness of what’s shown. Looks a bit like your video. So look in the settings/manual of the screen and see if you can find anything about this and if you can turn it off.
            Muzziboy @CyruS1337
            @CyruS1337 I tried auto brightness previously. But after reading your response I went and turned everything auto off. Although I don’t know which feature was the problem it solved my dimming problem. Thank you.
              Muzziboy @retroflex
              @retroflex I tried auto brightness previously. But after reading your response I went and turned everything auto off. Although I don’t know which feature was the problem it solved my dimming problem. Thank you.
                Muzziboy
                Just wanted say a quick thank you for the fast responses for my MM. Now time for customizing!
                  retroflex Project Sponsor Module Developer @Muzziboy
                  @Muzziboy Great that it worked out! :)
