    MMM-Wunderground - 2 locations gives duplicate data from the first location
    13 Posts 6 Posters 9.0k Views 4 Watching
      jamielola
      Thanks @Francopacks now I know it is achievable I will have another crack at it tonight, if you have any tips that you think would be helpful I would love to hear them.
        jamielola
        So I got home and was determined to get this resolved, this is the last part of the mirror and i’ll be dammed if I fail here.
        1. Switched Raspberry PI on
        2. waited for MM to load
        3. Looked on in astonishment that the module that I renamed to MMM-WunderGround2 was working and not stuck in ‘Loading’
        As I had made all them changes above to MMM-WunderGround2 including the socket name changes I Pulled MMM-WunderGround from github into the modules folder so I would have a fresh orginal copy for the 2nd instance.
        I wrote the new instance into the config file and refreshed the MM, low and behold…‘Loading’ for that new instance. However I knew what I needed to do…the oldest trick in the IT book, switch the Raspberry PI off and switch it back on again, hey presto - they both loaded fine showing separate data.
        I’d like to thank @RedNax and @Francopacks
        TLDR: make sure you carry out a restart when you change the names in the main.js and nodehelper file if they are stuck in loading.
        • brobergB Offline
          broberg Project Sponsor @jamielola
          @jamielola
          the node_helper will only load when the mirror is actually started, modifications to a modules node_helper will require a full restart of the mirror software, not just a reload. Which I discovered when modifying the stock newsfeed module :D
