    • Topics 2
    • Posts 7
    M Offline
    2. mri_ice
    mri_ice
    @mri_ice
    mri_ice Unfollow Follow
    • node clientonly for Windows
      I’ve recently acquired a few Intel Compute Sticks and as a result am changing from a single Raspberry PI to a distributed architecture where I run the server within a Proxmox LXC and then use the Compute Stick (Windows) to connect to it.
      The server side is done and running but I can’t figure out how to get the client to work.
      With the “full” setup, there is the windows switch:
      npm run start:windows
      What’s the equivalent setting for the client only? I can’t find it in docs or forum posts. When I run
      node clientonly --address x.x.x.x --port 8080
      I’m getting
      Error: Requires environment variable WAYLAND_DISPLAY or DISPLAY, none is provided.
      Any hints greatly appreciated.
      posted in General Discussion
      mri_ice
    • RE: MMM-ImmichSlideShow not showing within MMM-Carousel
      Not convinced it’s the right solution yet, but I have it working how I want it, at last.
      I store my photos in Immich on an NFS mount.
      I applied storage template that stores by album, then created another NFS export for that folder which I then mounted into the ./uploads folder within the MMM-ImagesPhotos module.
      Because I’m running MM within an unprivileged LXC container, NFS mounts from inside the container directly are not possible, but this worked for me: I’m a link (essentially mounting to the Proxmox server, then using a bind mode to expose to the container)
      Everything seems to working OK so far.
      mri_ice
      Ok, so to a large degree of this was my misunderstanding.
      I hadn’t fully grasped that this is based on MMM-BackgroundSlideshow with BACKGROUND being the imperative word. The position needs to be
      fullscreen_below
      and the photo does span the entire screen.
      It does work as designed but…I don’t really want the photo to be displayed fullscreen.
      Has anybody found a way of integrating Immich-hosted photos that are bound to a region rather than full-screen?
      mri_ice
    • MMM-ImmichSlideShow not showing within MMM-Carousel
      I’m using MMM-Carousel, specifically https://github.com/shbatm/MMM-Carousel.
      I’m trying to get MMM-ImmichSlideShow to work, but it just will not show any images when loaded within the Carousel.
      I know that MMM-ImmichSlideSlow itself works, as when I disable MMM-Carousel images DO show (although quite large).
      Has anybody had success in integrating MMM-ImmichSlideShow into a Carousel?
      I’m wondering whether it’s the display size of images (??) but I cannot find any way to control display size in MMM-ImmichSlideShow.
      No errors in MMM debug logs or Developer Console.
      I previously used MMM-ImagesPhotos in the same carousel and that works fine, it just seems to be a problem with MMM-ImmichSlideShow.
      Grateful for any pointers.
      Here are the relevant parts of my config:
      			module: 'MMM-ImmichSlideShow',
      			position: 'bottom_center',
      			immichConfigs: [
      				apiKey: 'xxxxxx',
      				url: 'xxx.xxx.xxx.xxx',
      				mode: 'album',
      				albumName: 'xxxxx',
      				validImageFileExtensions: 'jpg,jpeg,png,gif,bmp,heic',
      				slideshowSpeed: 30000
      			sortImagesBy: 'taken',
      			sortImagesDescending: true,
      			slideshowSpeed: 30000,
      			backgroundSize: 'contain',
      			animations: [
      			'slide'
      			module: "MMM-Carousel",
      			position: "bottom_bar", // Required only for navigation controls
      			  transitionInterval: 0,
      			  showPageIndicators: true,
      			  showPageControls: true,
      			  ignoreModules: ["weather", "MMM-MyBMW","calendar","clock","alert"],
      			  mode: "slides",
      			  slides: {
      				main: ["MMM-ImmichSlideShow"],
      				"Slide 2": [
      					"MMM-MonthlyCalendar"
      			  keyBindings: {
      				enabled: true,
      				map: {
      				  NextSlide: "ArrowRight",
      				  PrevSlide: "ArrowLeft",
      				  Pause: "ArrowDown",
      				  Slide0: "Home"
      				mode: "DEFAULT"
      mri_ice
    • RE: node clientonly for Windows
      This is what I’ve ended up doing for now, thank you.
      mri_ice
      Yup, the stick is windows-based.
      Is there a :windows parameter similar to when you run the full npm start:windows?
      mri_ice
      @sdetweil said in node clientonly for Windows:
      “WAYLAND_DISPLAY=”${WAYLAND_DISPLAY:=wayland-1}"
      Hi Sam, many thanks.
      I’m confused. I thought Wayland was a *nix-thing?
      I’m trying to run the client on Windows 10.
      Do I need to set this up as an Environment Variable?
      mri_ice
      I’m getting
      mri_ice
