    MM-Calendar Module - iCloud Public Calendar not working
    7 Posts 2 Posters 3.1k Views 2 Watching
    • Thorn2910T Offline
      Thorn2910
      I’ve been running the MM-Calendar modul for over 1 1/2 years now -
      Magic Mirror Version
      Starting MagicMirror: v2.16.0
      Calendar Module Integration
      			header: "Events",
      			maximumEntries: "3",
      				colored: true,
      				tableClass: "medium",
      						symbol: "fas fa-trash",
      						color: "rgb(185, 62, 38)",
      						maximumEntries: "2",
      						url: "https://calendar.google.com/calendar/ical/xxxxx/public/basic.ics"
                                                      symbol: "far fa-calendar-alt",
                                                      color: "rgb(250, 253, 140)",
                                                      url: "https://p44-caldav.icloud.com/published/2/xxxx"
                                                      symbol: "fas fa-house-user",
                                                      color: "rgb(121, 0, 86)",
                                                      url: "https://calendar.google.com/calendar/ical/xxxx/basic.ics"
      MM currently cannot fetch the iCloud calendar - and I did not change a single line of code. The Google calendars still work like a charm.
      I get this Error Message
      [06.03.2022 09:15.52.234] [ERROR] Calendar Error. Could not fetch calendar:  https://p44-caldav.icloud.com/published/2/xxx Error: Service Unavailable
          at NodeHelper.checkFetchStatus (/home/pi/MagicMirror/js/node_helper.js:121:9)
          at processTicksAndRejections (internal/process/task_queues.js:97:5)
      I beleive Apple changed something - or the service is down - but I did not find anything on the Status pages.
      Anyone has the same issues?
      JerryPJ 1 Reply Last reply Reply Quote 0
      • JerryPJ Offline
        JerryP @Thorn2910
        @thorn2910
        and now u use the p44-caldev if u chance the server to p49
        HTTP 503 is a temporary error code (“Service unavailable”) indicating iCloud servers aren't responding correctly to requests from your devices. The error typically gets resolved as GoodNotes automatically retries, but we're getting many reports of the error lingering on, causing sync failures.
        Thorn2910T 1 Reply Last reply Reply Quote 0
        • JerryPJ Offline
          JerryP @Thorn2910
          @thorn2910
          Goodmorning
          			header: "Jerry",
          			symbol: "calendar-check",
          			maximumNumberOfDays: '3',
          			maximumEntries:'3',
          			url: "webcal://p49-caldav.icloud.com/published/2/blablablabla"					}
          I see that you use https:// and I’m using webcam:// her it’s running fine
            Thorn2910 @JerryP
            @jerryp
            Tried this as well - every possbile way - webcal / http and https
            I get the same error message (with webcal it reverts back to http)
                                                            url: "http://p44-caldav.icloud.com/published/2/xxx"
                                                            url: "https://p44-caldav.icloud.com/published/2/xxx"
                                                            url: "webcal://p44-caldav.icloud.com/published/2/xxx"
            • JerryPJ Offline
              JerryP @Thorn2910
              @thorn2910
              And the web url is 100% correct at your iCloud account. for sharing you Ical…
                Thorn2910 @JerryP
                @jerryp
                Checked it on the iCloud page again - yes.
                One problem remains if I copy the link which iCloud is giving me an I copy it in Firefox - it wants to open Chrome which gives me nothing
                If i change the webcal to http or https i get a HTTP error 503
                I even tried a new public calendar … same issues
                • JerryPJ Offline
                  JerryP @Thorn2910
                  @thorn2910
                    Thorn2910 @JerryP
                    @jerryp
                    Woha!!!
                    I just unchecked the Public calendar in iCloud and rechecked it again - this changed the link to
                    webcal://p102-caldav.icloud.com/published/2/xxx
                    and now it works again!
                    Changing to solved!
