    Exiting GPU process due to errors during initialization
    5 Posts 4 Posters 10.6k Views 4 Watching
    • I Offline
      Ivanov_d
      Hi all! I have installed a fresh copy of MagicMirror. It runs with the default config for testing purposes. However every other minute, the app restarts and that is what I see in the logs.
      Has anybody else had the same issue?
      0|MagicMirror  | [22.03.2022 08:05.49.841] [LOG]   Shutting down server...
      0|MagicMirror  | [22.03.2022 08:05.49.846] [LOG]   Stopping module helper: updatenotification
      0|MagicMirror  | [22.03.2022 08:05.49.848] [LOG]   Stopping module helper: calendar
      0|MagicMirror  | [22.03.2022 08:05.49.851] [LOG]   Stopping module helper: newsfeed
      0|MagicMirror  | [3597:0322/080549.911892:ERROR:network_service_instance_impl.cc(916)] Network service crashed, restarting service.
      0|MagicMirror  | [3597:0322/080549.948086:ERROR:zygote_communication_linux.cc(276)] Failed to send GetTerminationStatus message to zygote
      0|MagicMirror  | [3597:0322/080549.951955:ERROR:zygote_communication_linux.cc(276)] Failed to send GetTerminationStatus message to zygote
      0|MagicMirror  | [3597:0322/080549.991850:ERROR:gpu_process_host.cc(962)] GPU process launch failed: error_code=1002
      0|MagicMirror  | [3597:0322/080549.998793:ERROR:gpu_process_host.cc(962)] GPU process launch failed: error_code=1002
      0|MagicMirror  | [3597:0322/080550.004524:ERROR:gpu_process_host.cc(962)] GPU process launch failed: error_code=1002
      0|MagicMirror  | > magicmirror@2.18.0 start
      0|MagicMirror  | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
      0|MagicMirror  | [22.03.2022 08:05.58.334] [LOG]
      0|MagicMirror  | Starting MagicMirror: v2.18.0
      0|MagicMirror  | [22.03.2022 08:05.58.358] [LOG]
      0|MagicMirror  | Loading config ...
      0|MagicMirror  | [22.03.2022 08:05.58.375] [LOG]
      0|MagicMirror  | Loading module helpers ...
      0|MagicMirror  | [22.03.2022 08:05.58.385] [LOG]
      0|MagicMirror  | No helper found for module: alert.
      0|MagicMirror  | [22.03.2022 08:05.58.425] [LOG]
      0|MagicMirror  | Initializing new module helper ...
      0|MagicMirror  | [22.03.2022 08:05.58.433] [LOG]
      0|MagicMirror  | Module helper loaded: updatenotification
      0|MagicMirror  | [22.03.2022 08:05.58.443] [LOG]
      0|MagicMirror  | No helper found for module: clock.
      0|MagicMirror  | [22.03.2022 08:05.58.738] [LOG]
      0|MagicMirror  | [22.03.2022 08:05.58.746] [LOG]
      0|MagicMirror  | Module helper loaded: calendar
      0|MagicMirror  | [22.03.2022 08:05.58.749] [LOG]   No helper found for module: compliments.
      0|MagicMirror  | [22.03.2022 08:05.58.753] [LOG]   No helper found for module: weather.
      0|MagicMirror  | [22.03.2022 08:05.58.797] [LOG]
      0|MagicMirror  | [22.03.2022 08:05.58.798] [LOG]   Module helper loaded: newsfeed
      0|MagicMirror  | [22.03.2022 08:05.58.800] [LOG]   All module helpers loaded.
      0|MagicMirror  | [22.03.2022 08:05.59.004] [LOG]
      0|MagicMirror  | Starting server on port 8080 ...
      0|MagicMirror  | [22.03.2022 08:05.59.033] [LOG]
      0|MagicMirror  | Server started ...
      0|MagicMirror  | [22.03.2022 08:05.59.036] [LOG]   Connecting socket for: updatenotification
      0|MagicMirror  | [22.03.2022 08:05.59.038] [LOG]   Starting module helper: updatenotification
      0|MagicMirror  | [22.03.2022 08:05.59.041] [LOG]   Connecting socket for: calendar
      0|MagicMirror  | [22.03.2022 08:05.59.043] [LOG]   Starting node helper for: calendar
      0|MagicMirror  | [22.03.2022 08:05.59.044] [LOG]   Connecting socket for: newsfeed
      0|MagicMirror  | [22.03.2022 08:05.59.047] [LOG]   Starting node helper for: newsfeed
      0|MagicMirror  | [22.03.2022 08:05.59.048] [LOG]   Sockets connected & modules started ...
      0|MagicMirror  | Fontconfig warning: ignoring UTF-8: not a valid region tag
      0|MagicMirror  | [22.03.2022 08:05.59.496] [LOG]
      0|MagicMirror  | Launching application.
      0|MagicMirror  | [3805:0322/080600.430740:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
      0|MagicMirror  | [3847:0322/080600.709029:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
      0|MagicMirror  | [22.03.2022 08:06.03.253] [LOG]
      0|MagicMirror  | Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
      0|MagicMirror  | [22.03.2022 08:06.03.349] [LOG]
      0|MagicMirror  | Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
      0|MagicMirror  | [22.03.2022 08:06.03.438] [INFO]
      0|MagicMirror  | Checking git for module: default
      0|MagicMirror  | [22.03.2022 08:06.04.245] [INFO]
      0|MagicMirror  | Newsfeed-Fetcher: Broadcasting 62 items.
      0|MagicMirror  | [22.03.2022 08:06.04.525] [INFO]
      0|MagicMirror  | Calendar-Fetcher: Broadcasting 10 events.
      0|MagicMirror  | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGTERM
      0|MagicMirror  | [22.03.2022 08:07.29.120] [LOG]
      0|MagicMirror  | [22.03.2022 08:07.29.145] [LOG]
      0|MagicMirror  | [22.03.2022 08:07.29.162] [LOG]
      0|MagicMirror  | [22.03.2022 08:07.29.173] [LOG]
      0|MagicMirror  | [22.03.2022 08:07.29.212] [LOG]
      0|MagicMirror  | [22.03.2022 08:07.29.220] [LOG]
      0|MagicMirror  | [22.03.2022 08:07.29.230] [LOG]
      0|MagicMirror  | [22.03.2022 08:07.29.529] [LOG]
      0|MagicMirror  | [22.03.2022 08:07.29.538] [LOG]
      0|MagicMirror  | [22.03.2022 08:07.29.547] [LOG]
      0|MagicMirror  | No helper found for module: compliments.
      0|MagicMirror  | [22.03.2022 08:07.29.555] [LOG]
      0|MagicMirror  | No helper found for module: weather.
      0|MagicMirror  | [22.03.2022 08:07.29.600] [LOG]
      0|MagicMirror  | [22.03.2022 08:07.29.601] [LOG]   Module helper loaded: newsfeed
      0|MagicMirror  | [22.03.2022 08:07.29.603] [LOG]   All module helpers loaded.
      0|MagicMirror  | [22.03.2022 08:07.29.800] [LOG]
      0|MagicMirror  | [22.03.2022 08:07.29.828] [LOG]
      0|MagicMirror  | [22.03.2022 08:07.29.831] [LOG]
      0|MagicMirror  | Connecting socket for: updatenotification
      0|MagicMirror  | [22.03.2022 08:07.29.833] [LOG]   Starting module helper: updatenotification
      0|MagicMirror  | [22.03.2022 08:07.29.835] [LOG]   Connecting socket for: calendar
      0|MagicMirror  | [22.03.2022 08:07.29.837] [LOG]   Starting node helper for: calendar
      0|MagicMirror  | [22.03.2022 08:07.29.839] [LOG]   Connecting socket for: newsfeed
      0|MagicMirror  | [22.03.2022 08:07.29.841] [LOG]   Starting node helper for: newsfeed
      0|MagicMirror  | [22.03.2022 08:07.29.843] [LOG]   Sockets connected & modules started ...
      0|MagicMirror  | [22.03.2022 08:07.30.266] [LOG]
      0|MagicMirror  | [3972:0322/080731.149506:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
      0|MagicMirror  | [4012:0322/080731.425367:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
      0|MagicMirror  | [22.03.2022 08:07.33.874] [LOG]
      0|MagicMirror  | [22.03.2022 08:07.33.945] [LOG]
      0|MagicMirror  | [22.03.2022 08:07.34.020] [INFO]
      0|MagicMirror  | [22.03.2022 08:07.35.040] [INFO]
      0|MagicMirror  | [22.03.2022 08:07.35.333] [INFO]
      0|MagicMirror  | [22.03.2022 08:08.59.890] [LOG]
      0|MagicMirror  | [22.03.2022 08:08.59.903] [LOG]   Loading config ...
      0|MagicMirror  | [22.03.2022 08:08.59.915] [LOG]
      0|MagicMirror  | [22.03.2022 08:08.59.920] [LOG]   No helper found for module: alert.
      0|MagicMirror  | [22.03.2022 08:08.59.953] [LOG]
      0|MagicMirror  | [22.03.2022 08:08.59.956] [LOG]   Module helper loaded: updatenotification
      0|MagicMirror  | [22.03.2022 08:08.59.959] [LOG]   No helper found for module: clock.
      0|MagicMirror  | [22.03.2022 08:09.00.255] [LOG]
      0|MagicMirror  | [22.03.2022 08:09.00.258] [LOG]
      0|MagicMirror  | [22.03.2022 08:09.00.262] [LOG]
      0|MagicMirror  | [22.03.2022 08:09.00.265] [LOG]   No helper found for module: weather.
      0|MagicMirror  | [22.03.2022 08:09.00.308] [LOG]
      0|MagicMirror  | [22.03.2022 08:09.00.310] [LOG]   Module helper loaded: newsfeed
      0|MagicMirror  | [22.03.2022 08:09.00.311] [LOG]   All module helpers loaded.
      0|MagicMirror  | [22.03.2022 08:09.00.505] [LOG]
      0|MagicMirror  | [22.03.2022 08:09.00.534] [LOG]
      0|MagicMirror  | [22.03.2022 08:09.00.536] [LOG]   Connecting socket for: updatenotification
      0|MagicMirror  | [22.03.2022 08:09.00.538] [LOG]   Starting module helper: updatenotification
      0|MagicMirror  | [22.03.2022 08:09.00.540] [LOG]
      0|MagicMirror  | Connecting socket for: calendar
      0|MagicMirror  | [22.03.2022 08:09.00.542] [LOG]   Starting node helper for: calendar
      0|MagicMirror  | [22.03.2022 08:09.00.543] [LOG]   Connecting socket for: newsfeed
      0|MagicMirror  | [22.03.2022 08:09.00.544] [LOG]   Starting node helper for: newsfeed
      0|MagicMirror  | [22.03.2022 08:09.00.545] [LOG]   Sockets connected & modules started ...
      0|MagicMirror  | [22.03.2022 08:09.00.962] [LOG]
      0|MagicMirror  | [4127:0322/080901.889231:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
      0|MagicMirror  | [4168:0322/080902.203933:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
      0|MagicMirror  | [22.03.2022 08:09.04.598] [LOG]
      0|MagicMirror  | [22.03.2022 08:09.04.664] [LOG]
      0|MagicMirror  | [22.03.2022 08:09.04.733] [INFO]
      0|MagicMirror  | [22.03.2022 08:09.05.534] [INFO]
      0|MagicMirror  | [22.03.2022 08:09.05.791] [INFO]
      • I Offline
        Ivanov_d
        Seems that this is a know bug and not the cause of the restart.
        • G Offline
          gernst48 @Ivanov_d
          @gernst48
          Why do you think this problem is solved ?
          Yes, it is not the cause of reset, but it is still a open question
          and no one is willing to give an answer about this problem.
            sdetweil @gernst48
            @gernst48 said in Exiting GPU process due to errors during initialization:
            no one KNOWS what the answer IS…
            you can try to turn off use of the gpu
            by adding --disable_gpu
            like this in package.json
            on the start clause
             "start": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron --disable-gpu js/electron.js",
            • karsten13K Offline
              karsten13 @sdetweil
              this seems to be an electron bug which is already fixed but not released, see this issue for more info.
