MMM-Screencast Position
8 Posts 4 Posters 1.4k Views 4 Watching
    poucedeleon
    Have installed MMM-Screencast on my MagicMirror2 and it works great. I am trying to position the screen in a specific position on my monitor. My Monitor is portrait, and I want the screen at middle point hormonally on the right side. It is an area where I don’t have anything on the screen. I have added x: and y: to my config.js, but no matter what numbers I type the screen does not move. Has anyone been able to move the screen, and maybe tell me what I am doing wrong.
    module: "MMM-Screencast",
    position: "top_right", // This position is for hidden <div /> ect.
    config:   {
                   height:   300,
                   width:   500,
                   x:   -700,
                   y:   0,
    J 1 Reply Last reply Mar 19, 2022, 6:28 AM Reply Quote 0
      JerryP @poucedeleon
      @poucedeleon
      Possible values are top_bar , top_left , top_center , top_right , upper_third , middle_center , lower_third , bottom_left , bottom_center , bottom_right , bottom_bar , fullscreen_above , and fullscreen_below
              config:  {
                     position:   " ", //Possible values are top_bar , top_left , top_center , top_right , upper_third , middle_center , lower_third , bottom_left , bottom_center , bottom_right , bottom_bar , fullscreen_above , and fullscreen_below
                     height:   300,
                     width:   500,
                     x:   -700,
                     y:   0,
        poucedeleon
        This is from the config option section
        Configuration options for MMM-Screencast
        Option Description
        position Required The position of the screencast window.
        Options: [‘bottomRight’, ‘bottomCenter’, ‘bottomLeft’, ‘center’, ‘topRight’, ‘topCenter’, ‘topLeft’]
        Type: string
        Note: This module config actual sets the location, not the magic mirror position config. NOTE
        x Optional (required if y is used) Window’s left offset from screen. Takes precedence over position.
        Type: number (pixels)
        y Optional (required if x is used) Window’s left offset from screen. Takes precedence over position.
        Type: number (pixels)italicised text
        P 1 Reply Last reply Mar 20, 2022, 6:30 PM Reply Quote 0
          poucedeleon @poucedeleon
          @poucedeleon Maybe I should take “position:” out if I am using x & y?
          S 1 Reply Last reply Mar 20, 2022, 6:38 PM Reply Quote 0
            sdetweil @poucedeleon
            @poucedeleon note that there are TWO position settings
            from the readme
                           module: "MMM-ScreenCast",
            		position: 'bottom_right', // This position is for a hidden <div /> and not the screencast window
            			position: 'bottomRight',
            the 1st one is thee MM position, there MUST be something, else NO content will be displayed
            as MM doesn’t know where to put it.,.
            the second (different spelling) is the modules private info… don’t know how it uses that
            P 1 Reply Last reply Mar 23, 2022, 7:40 PM Reply Quote 0
              ramisthand76
              this is really helpful post for me, thank you for your comments
                poucedeleon @sdetweil
                @sdetweil I know spelling is critical. On your example position: :“bottomRight” is this spelling correct?
                S 1 Reply Last reply Mar 23, 2022, 8:16 PM Reply Quote 0
                  @poucedeleon
                  that is a MMM-ScreenCast property… not MagicMirror
                  but, yes whatever way the module expects, exact syntax is important, including upper/lower case.
